wondering if I should even do the 1.75 RC level or just get 295/60/20r and call it day?
Discussion in '3rd Gen Tundras (2022+)' started by vbobxSurf, Oct 5, 2022.
  1. Oct 5, 2022 at 4:35 PM
    vbobxSurf
    vbobxSurf [OP] New Member
    2023 SR5 TRD- OR Tundra
    Toyota Tonneau Cover
    Does it sit up enough and look aggressive enough?
  2. Oct 6, 2022 at 1:44 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    research spacer lifts, there is a reason they cost what they do vs a coilover. If you off road, Id skip it and do a lifted suspension later. If you are on road only, spacer could be fine for you. Just depends on how you use your truck and how you want it to ride and handle. Check out the stickies in the suspension forum- guide to different types of lifts.
  3. Oct 6, 2022 at 6:05 PM
    Fooyotatundra
    Fooyotatundra New Member
    2022 sr5 trd 4x4
    Looks pretty level in my opinion, if you plan on doing a full suspension set up later down the road and you can clear the set up you want then I would just skip it.
    that being said, I have a brand new rough country 1.75” level kit up for sale. Asking $80 in SoCal
  4. Oct 6, 2022 at 10:36 PM
    joeboo
    joeboo New Member
    2022 Crew Max TRD
    Is it the composite spacer or the welded steel one? I just received a welded one in the mail but wanted the other as this looks poorly made. Where are you located? I’m in Long Beach.
  5. Oct 6, 2022 at 11:54 PM
    Fooyotatundra
    2022 sr5 trd 4x4
    Tbh I don’t know which material it is, I bought it probably 2 months ago can’t remember exactly. Didn’t even open the box. I’m in Anaheim
  6. Oct 7, 2022 at 1:26 AM
    joeboo
    joeboo New Member
    2022 Crew Max TRD
    If it’s the composite one, I’ll buy it from you.
  7. Oct 7, 2022 at 9:41 AM
    Fooyotatundra
    2022 sr5 trd 4x4
    Forsure I’ll open it today and let you know
  8. Oct 7, 2022 at 10:05 AM
    Fooyotatundra
    2022 sr5 trd 4x4
    Mine are the welded ones too, I’m assuming the composite ones are the ones where you don’t need to cut the stock studs?
  9. Oct 7, 2022 at 3:45 PM
    Fooyotatundra
    2022 sr5 trd 4x4
    Talked to rough country today and they take returns within 90 days of purchase. I just filled out the return form request so we’ll see what happens.
