Wonder if this thread can get 1 post from every member?
Discussion in 'General Tundra Discussion' started by TokerJoker, May 14, 2020.
  1. May 14, 2020 at 5:26 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Sloppy seconds??
  2. May 14, 2020 at 5:29 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    not much to add, other than a post in this thread
    TokerJoker[OP] likes this.
  3. May 14, 2020 at 5:30 PM
    Mountains49
    Mountains49 New Member
    2018 White Platinum
    What was the question?
  4. May 14, 2020 at 5:42 PM
    degs
    degs New Member
    2020 MGM Crewmax
    will it fit on a 2020 CM?
  5. May 14, 2020 at 5:44 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
  6. May 14, 2020 at 5:47 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    OK, I'll bite.
    Old truck:
    Current truck:
    SomeGuy4, Ostrich, jewsNbrews and 8 others like this.
  7. May 14, 2020 at 5:49 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Sure, why not.
  8. May 14, 2020 at 5:50 PM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
  9. May 14, 2020 at 5:54 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Nope
  10. May 14, 2020 at 5:58 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Where's BEEF?
    Black Wolf and TokerJoker[OP] like this.
  11. May 14, 2020 at 6:26 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Guess I'll hop on the bandwagon.
    Tundyfundy and TokerJoker[OP] like this.
  12. May 14, 2020 at 6:32 PM
    backinblack
    backinblack New Member
    James
  13. May 14, 2020 at 6:34 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  14. May 14, 2020 at 6:57 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
  15. May 14, 2020 at 6:58 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    #representthefirstgens
    bmf4069 and TokerJoker[OP] like this.
  16. May 14, 2020 at 7:11 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
  17. May 14, 2020 at 7:13 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    you ruined it! You have two posts!!!
  18. May 14, 2020 at 7:14 PM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Poop
  19. May 14, 2020 at 7:15 PM
    #49
    TokerJoker
    TokerJoker [OP] ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Nothing says it has to be once!
    Tundyfundy likes this.
  20. May 14, 2020 at 7:15 PM
    #50
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Not me
  21. May 14, 2020 at 7:17 PM
    #51
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Maybe I read into to too much.
  22. May 14, 2020 at 7:35 PM
    #52
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    This thread is as exciting as watching paint dry
  23. May 14, 2020 at 7:35 PM
    #53
    TaquitoBandito
    Joel (AKA Bif)
  24. May 14, 2020 at 7:40 PM
    #54
  25. May 14, 2020 at 7:44 PM
    #55
    SIXSEVENONE
    SIXSEVENONE Island BASTRD
    Shane
    East Bay, CA
    2015 Super White CM Limited
    Hafa Adai.
  26. May 14, 2020 at 7:56 PM
    #56
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    I'm bored, so I'll contribute.
    TXMiamiFan and TokerJoker[OP] like this.
  27. May 14, 2020 at 8:27 PM
    #57
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Only 43,500 or so to go!!
  28. May 14, 2020 at 8:34 PM
    #58
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
  29. May 14, 2020 at 8:37 PM
    #59
    Flightmech65
    Flightmech65 New Member
    Bucks County, PA
    2015 Crew 1794 & 2016 SR5
    TRD duals and cold air
    Who’s gonna count/keep tabs?
  30. May 14, 2020 at 8:42 PM
    #60
    biebs96
    PA
    I’m in...
    ...with a fun fact... paint can openers have pressed dimples on the handle to make them bottle openers.
