Woke to an alarm under hood
Discussion in '1st Gen Tundras (2000-2006)' started by Trapperpete52, Dec 16, 2022.
  1. Dec 16, 2022 at 8:12 AM
    Trapperpete52
    Trapperpete52 [OP] New Member
    Pete
    2002 Tundra
    High pitch noise under the hood. Found goes off when pull EFI 1 fuse. It hasn't been driven in about a week. From my internet searches have found is a common problem but not seeing any solutions.
  2. Dec 16, 2022 at 8:18 AM
    Your friend, the piezo. You'll find it between the master cylinder and the driver's fender. Round thing, wrapped in foam. Unplug. Replace.
    Mr.bee and Trapperpete52[OP] like this.
  3. Dec 16, 2022 at 8:20 AM
  4. Dec 16, 2022 at 8:57 AM
    Trapperpete52
    Pete
    2002 Tundra
    Pulled it out and that did the trick. Peeled the foam off but no part number. On the black lead found this SP609LX5-15V-1001. Don't think will bother to replace it as we don't have a fob anyway. Thanks for saving me a lot of grief tracking that down.
    NewImprovedRon and Jack McCarthy like this.
  5. Dec 16, 2022 at 9:02 AM
    Not a problem @Trapperpete52
    You can get a replacement on scAmazon. I think the thread I linked has links to the part, or something similar. The Toyota part for 2000-2004 Tundras is this one.
    Based on pics I found online, that may be a splice-in solution. Not sure. I think the same part on scAmazon is like ... $18 or less.
    NewImprovedRon likes this.
  6. Dec 16, 2022 at 9:08 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Mine hasn’t buzzed again in a long time, knock on wood.
  7. Dec 16, 2022 at 6:05 PM
    Sometimes all you gotta do is blow em out real good, or shake the water out of them.
