Wobble with new method wheels and cooper tires
Discussion in 'Wheels & Tires' started by cdmagor, Sep 4, 2018.
  1. Sep 4, 2018 at 12:29 PM
    cdmagor
    cdmagor [OP] @tundra4by4
    Clayton
    Denver Colorado
    2017 Tundra
    Toytec 3/1 Eibach Lift Coachbuilder +2 Shackels 285/75/18 Nitto Tires Method Racing Wheels
    After installing method con 6’s wheels 18X9 +18 offset and cooper discovered a/t3 xlt all terrain tires my truck has a wobble. The steering wheel starts to wobble at about 54 mph and continues until I get to about 65 mph. The wobble gets more intense when I brake from 65 down to 53.
    I took the tires and wheels back and they said they were off balance. Got them balanced by their “best balancer” and the wobble is still there. Any idea what it could be? It didn’t start until I changed wheels and tires so I’m assuming it has to be them. Is this common with tundras?
  2. Sep 4, 2018 at 1:01 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    No, if it started when you changed wheels and tires, why would it be a tundra issue? You’re sure they didn’t change anything else? If the wheels and tires are balanced and you still have an issue, rotate them. If you still have the issue, then they may have tightened the lugs too tight and warped the brakes. To confirm this, throw the stock wheels/tires back on and check. If it’s still there, someone introduced an issue into your truck. If it goes away, tell them to road force balance your wheels/tires and/or have them replace the tires.
  3. Sep 4, 2018 at 1:05 PM
    reaper3030
    reaper3030 New Member
    Charles
    Tundra 2018 SR5 4X4 Concrete Crewcab
    Rock star wheels, off road tires, LED interior lights, LED fog lights, and .50 cal antenna.
    I have those exact tires on mine and its a smooth ride at any speed. You might take them to a new place and have them balance them to see it that fixes the issue.
  4. Sep 4, 2018 at 1:16 PM
    cdmagor
    Clayton
    Denver Colorado
    2017 Tundra
    The stock wheels and tires aren’t balanced anymore because I swapped the sensors. Any other way to check the brakes?
  5. Sep 4, 2018 at 2:05 PM
    Rica25
    Ricardo
    Tulare
    Need to ge them ROAD FORCE BALANCE
  6. Sep 4, 2018 at 2:17 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Road force balancing is a good idea but it didn’t solve my issue. I replied to you in another thread.
    TXRailRoadBandit73 and Rica25 like this.
  7. Sep 4, 2018 at 2:23 PM
    Rica25
    Ricardo
    Tulare
    That fixes most issues in most cases but I have seen where balancing machines will go bad and throw everything off and the technicians wont even know until they come to calibrate the machine.......
    BTBAKER likes this.
  8. Sep 4, 2018 at 2:29 PM
    cdmagor
    Clayton
    Denver Colorado
    2017 Tundra
    They’ve been road force twice now.
    BTBAKER and Rica25[QUOTED] like this.
  9. Sep 4, 2018 at 2:30 PM
    Did you get new tires with wheels Road Force Balanced?
    BTBAKER and Rica25 like this.
  10. Sep 4, 2018 at 2:31 PM
    Rica25
    Ricardo
    Tulare
    Claro que si ARamires73
    TXRailRoadBandit73 likes this.
  11. Sep 4, 2018 at 2:32 PM
    Maybe defect in tires???
    Rica25 likes this.
  12. Sep 4, 2018 at 2:32 PM
    Rica25
    Ricardo
    Tulare
  13. Sep 4, 2018 at 2:33 PM
    Are you lifted? Carrier bearing spacer?
    Rica25 likes this.
  14. Sep 4, 2018 at 2:45 PM
    cdmagor
    Clayton
    Denver Colorado
    2017 Tundra
    Yeah I’m lifted. What’s a carrier bearing spacer?
  15. Sep 4, 2018 at 2:49 PM
    Some guys on here have felt this vibrating feeling when taking off or on highway they are metal spacers that go above the drive shaft carrier bearing, they eliminate this wobble
  16. Sep 4, 2018 at 3:01 PM
    cdmagor
    Clayton
    Denver Colorado
    2017 Tundra
    I will add this to the list. I still think it’s mostly the wheels or tires. It’s not necessarily when speeding up though. It’s just in between about 53-65. And I feel it even more when braking in that speed range.
  17. Sep 4, 2018 at 3:02 PM
    Maybe defect in tires or wheels :notsure:
  18. Sep 4, 2018 at 3:17 PM
    cdmagor
    Clayton
    Denver Colorado
    2017 Tundra
    Is this really that easy to do? Is there a way to have the brakes inspected to see this?
  19. Sep 4, 2018 at 3:20 PM
    reaper3030
    Charles
  20. Sep 4, 2018 at 4:45 PM
    cdmagor
    Clayton
    Denver Colorado
    2017 Tundra
    Went back in to check the alignment, the toe on the front passenger side was off. The front 2 tires were balanced good though. They fixed the alignment and now the truck drives much more straight. I would say the wobble reduced about 60-70 percent. So I think that was a big piece of it.
    No more severe shaking when braking and only moderate every once in a while between 55-65. I could just be really picky about it now too because I’m so focused on it. I still think maybe the tires are a little rough riding. So I might have discount swap out the tires for a smoother riding one and I’m going to install the carrier spacer.
  21. Sep 4, 2018 at 4:58 PM
    reaper3030
    Charles
    Glad it worked out for you.
  22. Sep 4, 2018 at 4:59 PM
    cdmagor
    Clayton
    Denver Colorado
    2017 Tundra
    Well we will see. It’s still not 100%
    reaper3030[QUOTED] likes this.
  23. Sep 4, 2018 at 5:04 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Are you lifted in the rear? If not I wouldn't bother with a carrier bearing drop kit.
    joonbug likes this.
  24. Sep 4, 2018 at 5:18 PM
    cdmagor
    Clayton
    Denver Colorado
    2017 Tundra
    I’m lifted an inch. Toytec’s main mechanic said it can’t hurt and could get rid of some wobble. It’s only a 1/2 inch drop.
    Casper3[QUOTED] likes this.
  25. Sep 4, 2018 at 5:22 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    It's usually a vibration that you can feel in the driveline and not a wobble, especially during accelerating. But yeah, if you're lifted a inch it can't hurt.
  26. Sep 4, 2018 at 5:24 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Skipped through a lot of this but I had a set of BFF ko2’s. Always had great luck w bfg’s. This last set would not balance, no matter what. 1 tire was bad. 2015 Silverado turned out to be a lemon anyway and Chevy bought it back. I ate the cost of the rims n tires. But..... it got me into a tundra.
    My next tires are going to be coopers or general at2’s.
  27. Sep 4, 2018 at 6:41 PM
    cdmagor
    Clayton
    Denver Colorado
    2017 Tundra
    Not sure I’m going to check tomorrow. I think I’ll swap them out for nitto too! Heard lots of people say they’re very smooth and easier to balance.
    Watt maker likes this.
  28. Sep 4, 2018 at 8:50 PM
    Rica25
    Ricardo
    Tulare
    I had issues with my cooper at3s also and swapped for toyos then 2 months later swapped for my nittos and love them
  29. Sep 4, 2018 at 8:58 PM
    cdmagor
    Clayton
    Denver Colorado
    2017 Tundra
    Good to hear! I’m doing this tomorrow!
    Sas and Rica25[QUOTED] like this.
  30. Sep 4, 2018 at 10:20 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Great. I just ordered a set of Cooper at3 xlt's and sounds like they may have balancing issues.
    Rica25 likes this.
