Wiring rear bumper LEDs to a different switch?
Discussion in 'Lighting' started by JC303, Jun 13, 2017.
  1. Jun 13, 2017 at 4:51 PM
    JC303
    JC303 [OP] Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I need help. I purchased led lights for my rear bumper and it came with a wiring harness and a switch. I wanted to change the switch to the AOB Toyota switch from SDHQ. This way it is a nice clean look and no cutting of the dash is involved. The switch that came with the harness has 3 wires. Blue white and black and the Toyota switch has 4 wires. Blue black red and green. The first 2 pics are the switch that was included and the last is the Toyota switch. What do I do?
    doubletimebluz and Bob like this.
  2. Jun 13, 2017 at 5:02 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    You only actually need the switch input and output wires to be connected. The other wires are to power the LED indicators in the switch. The manufacturer should have supplied a diagram with the switch stating which wire is which. Something to note is that switch is only rated for 3A so it can't supply much power. It's really only designed to actuate a relay so you should find another switch if you aren't interested in using a relay (which is only necessary for inductive loads).
  3. Jun 13, 2017 at 5:44 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Sorry to butt in but can you please explain why the relay is needed? I'm in the same boat and am wondering why the switch will not work as the one provided. I've already installed the provided switch and it looks clean. It's a different switch than OP showed. I was given a dressier switch but am reluctant to install it because I don't want to purchase anything else.
    Thanks for any guidance you may show me
  4. Jun 13, 2017 at 6:17 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Is that why I blew out my aironboard switch? So a relay will prevent the same with a replacement switch?
  5. Jun 13, 2017 at 6:31 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Relays have two parts, the coil and the contacts, one connected to the power source (battery) and one connected to the load (LED). When the coil is energized, the contacts are closed and current begins to flow. The contacts are used to pass all the current to drive LED's.
    The coil takes little very little current to operate (usually milliamps) so this is what you want to switch with your switch. This prevents a large amount of current being switched and prevents arcing between the two poles.
    And @computeruser6 is absolutely correct on the toyota switch is designed to operate a relay and is only rated for low amperage. Just by looking at the first switch you can see the heavier guage wire than the Toyota one. This tells me there is no relay and it is switching all the current for the LED's.
  6. Jun 13, 2017 at 6:52 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    There is a relay and I did figure it out. Thanks for all the direction. Trial and error helped as well. Pics coming soon.
  7. Jun 13, 2017 at 7:01 PM
    Eclipsed & Floating
    Voluptuous Whitey
    GREAT RESPONSE!! Very helpful. So, can I assume that the higher guage (smaller wire) would be suitable in my current setup because it's not conducting a hugger amperage? But, that the Toyota switch is requiring a higher amperage so the lower guage higher wire and a relay is necessary?
    By the way, your explanation was great for someone that has little electrical knowledge.
    JC303[OP] and mdavis[QUOTED] like this.
  8. Jun 13, 2017 at 7:21 PM
    computeruser6
    Dirk
    Escondido
    I personally only bother to use relays for inductive loads (motors) since there is a starting surge of up to 6 to 8 times the normal running current. For something like LED lights it's not really necessary. I prefer to use a switch like this since it is rated for 20A. @Almaboy If you are using the AOB switch to directly power anything other than a very small load (<3A) the switch will fail and you should use a relay to pass the load power and the switch to simply actuate the relay.
    NewImprovedRon and JC303[OP] like this.
  9. Jun 13, 2017 at 7:21 PM
    mdavis
    Michael
    Rock Hill, SC
    Can't really comment on your setup as I don't know what you have going on but as you can see in the OP's picture of the OE switch, it has what looks to me 22awg wire, this is only good for low amperage so assume it would be for energizing a coil.
  10. Jun 13, 2017 at 7:25 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Gotcha. Originally I stated I had the same dilemma, when I should have stated I have the exact same setup...just a different light being pushed. I should have been more specific. You answered my questions. Thank you sir!
    mdavis[QUOTED] and JC303[OP] like this.
  11. Jun 13, 2017 at 7:28 PM
    Eclipsed & Floating
    Voluptuous Whitey
    You know, it's been a while but I remember now, there was a relay built into the harness. At least that's what I assume to be the relay.
    JC303[OP] likes this.
  12. Jun 13, 2017 at 7:34 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Well, are you gonna tell us the solution?? C'mon man, you know how this works :cheers:
  13. Jun 13, 2017 at 8:37 PM
    Eclipsed & Floating
    Voluptuous Whitey
    @JC303 where's your pics homie???
    Lights and all...we want em
  14. Jun 13, 2017 at 8:39 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    The harness has a relay included. I had to extend the harness to the battery and to the lights. To get the Toyota switch to work I had to hook up the Toyota
    Black to black. Toyota green to blue. Toyota blue and red goes to white. I did run the power directly to the battery so it will have constant power. I may change that so the lights are not lit up constantly. How much will this drain the battery as it will have Power even with the truck off?
    doubletimebluz likes this.
  15. Jun 13, 2017 at 8:40 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Can't you switch the lights off?
  16. Jun 13, 2017 at 8:42 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    IMG_4145.jpg IMG_4149.jpg IMG_4148.jpg Teaser pics. More on my build tomorrow when I'm at work. I'll need something to do.
    Eclipsed & Floating likes this.
  17. Jun 13, 2017 at 8:42 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    The lights go off but the lights on the switch stay on.
  18. Jun 13, 2017 at 8:44 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Ahhhhhh!!! Come on. That was weak! Tag me when they're uploaded
    JC303[QUOTED][OP] likes this.
  19. Jun 13, 2017 at 8:46 PM
    computeruser6
    Dirk
    Escondido
    I have added several switches with LED indicators in my truck that are always on and have had no problems with the battery draining. The electrical load is very small (about 3-4 mA according to my regulated DC power supply) and will take a very long time to drain the battery.
  20. Jun 13, 2017 at 8:46 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    You get to see it on the 24th. No pictures for you! :stirthepot:
  21. Jun 13, 2017 at 8:46 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Thanks this is what I was thinking.
  22. Jun 14, 2017 at 5:50 AM
    Eclipsed & Floating
    Voluptuous Whitey
    :bananadead: :fistbump::boink::ballchain::argue::frusty::duel::quickdraw::smack::violent::worthless:
  23. Jun 14, 2017 at 6:29 AM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Ron, I may do this. I'm a newbie when it comes to electrical. This was my first attempt and I'm open to all suggestions. It seems like it may make more sense for me to wire into the headlights. I originally thought about wiring into the reverse lights but then decided I wanted a switch so I could have light anytime not just when I'm in reverse. So I decided to run straight to the battery. After completing the wiring I realized that the switch lights will be illuminated all the time.
  24. Jun 15, 2017 at 8:10 AM
    Eclipsed & Floating
    Voluptuous Whitey
    @JC303
    where are them lights, boy!!!!
  25. Jun 15, 2017 at 9:09 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Yeah JC, plug them Hid' s in. Let's see the light show.
  26. Jun 15, 2017 at 11:23 AM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I started off thinking I was going to take pictures of the entire install. Maybe even do my first DIY. Then once it started taking me multiple nights I was only working on the truck, drinking beer and not taking pictures. Here are the few that I have. The kit I bought on amazon included the LED's and the wire harness with a switch and a relay. I used a grinder, drill and a jig saw to cut the holes in the bumper. My friend David helped with most of the install. I had to purchase my own hardware and extend the harness to the lights. Bought 21 feet of wire conduit, roll of electrical tape, more zip ties, 16g wire, heat shrink wire wrap and some connectors. Had to use a wire hanger to get the harness through the fire wall and also used it to run the wires under the truck.
    rear lights.jpg rear lights 2.jpg rear lights 3.jpg Rear bumper.jpg rear bumper 2.jpg bumper 3.jpg bumper 4.jpg bumper 2.jpg bumper 1.jpg
    1 person likes this.
