Wiring light bar relay trigger into high beam wire without premium LED lights
Discussion in '3rd Gen Tundras (2022+)' started by Reubenski, Mar 21, 2025.
  1. Mar 23, 2025 at 7:31 PM
    Reubenski
    Reubenski [OP] New Member
    2025 Limited CM, TRD Off-road package, 3" lift
    It would probably be clear to you if you read my original post. Obviously you just skimmed through it And didn't key into the part about using a can bus interface because you didn't know what it was. I referenced can bus and simply asked if I can still tap into the high beam wire and if so where is it. I'm trying to see if there are other options. If you had read it, and comprehended what you read, and knew what a canbus interface is, your first post would have been "No. You need a canm8 interface." But you're the troglodite still reaching for buttons at the bottom of the dash.
    I guess my first response to you was spot on. There are many ways to do this so your stance that it cant be done clearly is incorrect. If you do some research, which you did, you will see. And you did. But at first that hurt your feelings and you responded with a childish, "Maybe you should do some research."
    Guy. At this point, I'm just putting you on ignore. You have added nothing productive.
  2. Mar 23, 2025 at 7:50 PM
    Reubenski
  3. Mar 23, 2025 at 8:24 PM
    kjinxx2
    kjinxx2 New Member
    One other helpful tip may be to paperclip the plug - can usually get an unfolded paper clip down the front or back of the plug and then use the multimeter on the paper clip - then you can test to see if you have the headlight wire.
    Reubenski[QUOTED][OP] likes this.
