Wiring Issues!
Discussion in '1st Gen Tundras (2000-2006)' started by Tebo77, Mar 7, 2020.
  1. Mar 7, 2020 at 2:21 PM
    Tebo77
    Tebo77 [OP] New Member
    Karen
    2001 Tundra SRT
    Hi, first post, new to the forum. I had some wiring issues with my 01 Tundra SR5 and a fuse box with a lot of corrosion. Possibly leaky windshield. Anyhow, I bought a brand new fuse box and I still had some things not working, like the blower and parking lights. Bought a used body wire harness. It had some extras, it may have been from a TRD which mine is not, but everything from my truck had a place to plug in. NOW it won't even start. I turn the key and the only thing that happens is the 4hi light blinks, no other dash lights no crank. The parking lights and blower work! I'm wondering if I have something connected wrong, or if just changing wiring may have set the security. The dealer didn't seem to think so. Of course then again all they said was to check the fuses:/. There are some connectors from the engine harness that would fit the fuse box in front where the green one goes, and there are two connectors that fit the ignition. I've tried all the various connections with these, and made sure I hadn't blown any fuses after.
    Any help would be greatly appreciated.
  2. Mar 7, 2020 at 2:43 PM
    Professional Hand Model
    Hand Protectors
    This is a tough one. Hopefully, someone will come along and answer.
    We’ve had a few come through here with a similar problem that started from a leak. Can you confirm the leak was from windshield or maybe the pillar gasket clips?
    theblurry1 likes this.
  3. Mar 7, 2020 at 3:05 PM
    Tebo77
    Karen
    2001 Tundra SRT
    I can check the gasket and clips in the daylight tomorrow. I was assuming windshield because it has been changed, even though it was Safelite never can tell.
  4. Mar 7, 2020 at 3:11 PM
    Hand Protectors
    Safelite replaced my shield, but did not do any repairs to the gaskets. Repair Guy was cool and pointed it out to me said that they aren’t responsible for that. I ended up doing a repair to the pillar after he was finished.
  5. Mar 7, 2020 at 3:40 PM
    Tebo77
    Karen
    2001 Tundra SRT
    Oh, I see now. I will surely check that out tomorrow, when I get back out there to beat my head against the dash some more trying to figure out this wiring:)!
  6. Mar 7, 2020 at 3:45 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Having never dealt with a wiring harness change, this thought might be easier said than done but I would remove used harness and put original back in. Then start troubleshooting again from that point with things that are not working.
  7. Mar 8, 2020 at 7:46 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
  8. Mar 8, 2020 at 4:33 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Was everything working before the swap out? I'd take a look and see if anything else is corroded.
