Wiring/Fuse box questions
Discussion in 'General Tundra Discussion' started by Electonicsfanatic, Mar 5, 2020.
  1. Mar 5, 2020 at 11:30 AM
    Electonicsfanatic
    Electonicsfanatic [OP] New Member
    Wesley
    2017 Tundra Crewmax Limited 4x4
    Hello I have a 2017 Toyota Tundra Crewmax and I want to hard wire my dash camera to the interior fuse box. Which fuse and number would be best? I just need one that has continual power as the dash camera will shut off if the battery gets down to 11.4 volts.
  2. Mar 5, 2020 at 12:46 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    You can much more easily hardwire the dash cam into the dome light wiring just inches away from where your camera will be mounted. No need to run wire all the way down to a fuse panel.
