Ultimate TUNDRA Wiring Diagrams Collection
Discussion in 'Electrical' started by RainMan_PNW, Jan 12, 2021.
  1. Jan 12, 2021 at 1:59 PM
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Got a Sequoia? We've got you covered (or will soon). Head on over to this thread.
    Over the years, I've managed to find, download, and stash away a variety of different "complete" (or mostly complete) diagrams for various years of Tundras. Most of it has been a result of me wanting to "upgrade" something on my truck to be like a higher trim level or a newer truck year when I had my 2008 SR5 - things like installing the Optitron gage cluster, doing the Auto AC Climate Control upgrade, or even swapping out my 2008 JBL head unit for one from a 2010 in order to add the BT streaming audio and USB media port. Over time, I've come to get to know how these diagrams work pretty well, and have used the information to troubleshoot or tinker a lot of other things as well.
    So, I'd like to share what I have...which now includes the complete set of Tundra diagrams. Some are more detailed than others - for example, when I recently pulled down the information for the 2021 (which also includes data for everything 2016+), I decided to pull down every single connector data sheet as well (there are 520+ of them). The PDFs I have here are not quite as user friendly to use as the live TIS site, but they are as functional as a single PDF file can be without me spending hours trying to actually hyperlink things the way the TIS site does.
    The 2021 EWD contains all of the information for MY 2016 and newer (I focused on MY 2021, but made sure to include any EWD-specific pages that were for older MY's in the same group), with individual EWDs denoted by references such as "Before Aug 2017 Production" to indicate MY 2017 or older, and "After Aug 2017 Production" to indicate MY 2018 and newer (remember that production for a new model year typically starts around August of the prior calendar year).
    General Manuals and Info:
    Gen 1 (2000-2006) Tundra:
    Gen 2 (2007-2013) Tundra:
    • 2007 Tundra EWD - EM04E0U
      • Includes System Circuits (by original file name), Location & Routing, and Fuse Lists
      • 705 pages
    • 2008 Tundra EWD - EM08H0U
      • Includes System Circuits (grouped by category), Location & Routing, and Fuse Lists
      • 655 pages
    • 2009 Tundra EWD - EM11A0U
      • Includes only System Circuits (listed alphabetically by first "system"), Location & Routing, and Fuse Lists
      • 690 pages
    • 2010 Tundra EWD - EM12D0U
      • 703 pages
    • 2011 Tundra EWD - EM16G0U
      • Includes System Circuits (by original file name), Location & Routing, Fuse Lists, and Overall EWDs
      • 764 pages
    • 2012 Tundra EWD - EM18N0U
      • 761 pages
    • 2013 Tundra EWD - EM22Z0U
      • 761 pages
    Gen 2.5 (2014-2021) Tundra:
    • 2014 Tundra EWD - EM24W0U
      • 771 pages
    • 2015 Tundra EWD - EM26B0U
      • Includes System Circuits (grouped by category), Location & Routing, Fuse Lists, and Overall Diagrams
      • 778 pages
    Gen 3 (2022+) Tundra:
    Some other notes:
    These are set up to use the bookmarks feature in most PDF viewers, and I have removed duplicate "source" diagrams where the same diagram is used in several different bookmarks (Cruise Control, Electronically Controlled Transmission, and Engine Control in the 2021 EWD is an example). This reduces file size, but will mean that if you just hit "print" on the whole document you will end up with something that may not be in the same order that as the list in the table of contents.
    newtoyo, fytedapowr, SUNOCO and 128 others like this.
  2. Jan 12, 2021 at 2:07 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Thanks for sharing!
    RainMan_PNW[OP] likes this.
  3. Jan 13, 2021 at 8:20 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Updated original post with attachments for the 2021 (covers 2016-2021) and the 2009. 2021 has been separated out into sections to work with the file size limits, and I still need to work on getting the full connector data sheets small enough to upload.
    ZappBrannigan, NMTRUCKER and NIOSH like this.
  4. Jan 13, 2021 at 8:52 AM
    RainMan_PNW
    Casey
    Clark County, WA
    OK - 2008 and 2010 up now as well.
    And 2015...that's all I've got for EWDs.
    NMTRUCKER and (deleted member) like this.
  5. Jan 13, 2021 at 9:53 AM
    RainMan_PNW
    Casey
    Clark County, WA
    All Connector data sheets for 2016-2021 uploaded (had to split into four files).
    Also uploaded wire harness repair manuals for 1991-2005, and for 2007.
    And I had a Connector Part Numbers document for 2005 (but not the rest of that manual).
  6. Jan 13, 2021 at 10:08 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    You ROCK Casey! Thanks for sharing!
  7. Jan 13, 2021 at 11:27 AM
    TRD_FanMan
    TRD_FanMan New Member
    2021 Tundra SR5 4x4 OffRoad
    Fantastic. Thank you!
  8. Jan 13, 2021 at 12:59 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I'm going to throw it out there, just as an FYI. These are provided for you to use, troubleshoot, and determine what to do with them to the best of your ability. I can't offer any specific advice or information on how to perform specific mods using these diagrams (and don't want this thread to be used for that). If it isn't already obvious by the fact that there are over 500 pages worth of wiring diagrams for any given model year (and over 500 possible connectors in the 2021 truck depending on trim and cab configuration), these vehicles have complex and inter-dependent wiring systems controlling them in addition to the computers that keep the whole thing functioning. Tapping, cutting, splicing, re-directing, or otherwise tampering with anything that was put there by Toyota in a specific way is entirely your responsibility.
    :thumbsup:
  9. Jan 17, 2021 at 7:53 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Thanks for putting all of this together! Downloaded all applicable files in case I need them one day :).
  10. Feb 9, 2021 at 12:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Just dropped a Valentine's special for all you Gen 1 owners - 2000 through 2006 EWD's are live above.
    I'm going to try and make sure I've got 2011-2013 covered, and that will take care of all current-production Tundras.
    Tom's Tundra, mtntop, shifty` and 4 others like this.
  11. Feb 9, 2021 at 1:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    OK - reorganized the OP a bit to make it easier to find (and hyperlinked the attachments).
  12. Feb 9, 2021 at 1:12 PM
    Sunnier
    Sunny
    San Diego, CA
    Great Valentine’s Day gift! Thank you! :woot:
  13. Feb 9, 2021 at 6:01 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Before the end of the week, I’ll have all the remaining years covered as well.
    iHacker likes this.
  14. Feb 9, 2021 at 6:40 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    :benchpress: You are the man! I appreciate your time and donation. Thanks.
    Ptundra and RainMan_PNW[OP] like this.
  15. Feb 9, 2021 at 7:08 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Bakershack and RainMan_PNW[OP] like this.
  16. Feb 9, 2021 at 9:10 PM
  17. Feb 9, 2021 at 9:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    OK - so I just discovered a little "gotcha" on the TIS site that I'm 99% sure affects every EWD I've got posted on here for 2006 and newer. In the "Location and Route" section, they actually have multiple "views" for some of the Position diagrams - for instance, most of the engine bay diagrams actually have four separate position diagrams in order to call out ALL the different connectors in there.
    I've got all the missing ones pulled down, but I am going to have to get them inserted into the PDF files and then re-uploaded and re-linked. That means that anyone that has pulled down the complete diagrams, or the "Location and Routing" section from the 2016-2021 manual will need to re-download them AFTER I post in here stating I've got them updated and re-uploaded.
    Sorry about that - it was a pure fluke that I even caught it, and looking at the ones I've previously downloaded off the internet (that were not originally downloaded by me), I'm not the only one that didn't catch it.
    Stay tuned...
    Tacopashka and ryanwgregg like this.
  18. Feb 10, 2021 at 6:52 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks for the heads up and the update!
    eddly likes this.
  19. Feb 10, 2021 at 8:14 AM
    RainMan_PNW
    Casey
    Clark County, WA
    OK - updated links and attachments are up, including the "missing" model years. I had to split the 2006 because it is JUST too big for the file size limits...
    Hightide, Bakershack and Yzed608 like this.
  20. Feb 10, 2021 at 6:55 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Thanks for the update!
  21. Mar 23, 2021 at 9:26 AM
    G10dra
    G10dra Not a New Member
    This thread is so important that it should have under section under DYI /mod's.
  22. Mar 23, 2021 at 1:58 PM
    Bossmike253
    Bossmike253 New Member
    Does anybody have the colouring diagram from the alternator harness have a new plug with different colour wires and I need to know which original wire goes into what port
  23. Mar 23, 2021 at 2:20 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Will need to know what year and model (and engine). From there, the specific diagram to get you started is the "Charging" circuit, which will show connectors, colors, and terminal positions for the "Generator" (what Toyota calls the alternator in their diagrams).
  24. Mar 23, 2021 at 2:33 PM
    Bossmike253
    Sorry 2014 sr5 crew 4.6 v8
    This?
  25. Mar 23, 2021 at 2:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    In the 2014 EWD PDF file that is linked in the original post, page 128-130 is the charging system.
    The 4.6L V8 is the 1UR-FE engine, so any wiring that has a *2 or *3 would be applicable (in addition to anything with no designation at all).
    Based on that, the connectors are E1 and E9. Looking on Page 3, connector E1 is simply a terminal ring, so that's easy to figure out. Connector E9 is waterproof connector, and the pin numbers are based on you looking at the OPEN END of the connector (not the "back" where the wires enter it).
    Referring back to the diagrams
    • Pin 1 is "S" (from the 5A ALT-S fuse) and should be Black w/ Yellow stripe
    • Pin 2 is "IG" (from the 7.5A LH-IG fuse) and should be Green w/ Yellow stripe
    • Pin 3 is "M" (from the ECM) and should be Red
    • Pin 4 is "L" )from the speedometer/instrument cluster) and should be Black
    bro66677 likes this.
  26. Mar 24, 2021 at 11:23 AM
    trantundra
    trantundra New Member
    Hi Guys,
    Thieves took both of my 2016 Tundra catalytic converters and cut the oxygen wiring sensor.
    I need help to identify oxygen sensor wiring color of bank1 sensor2. OEM wiring has 4 wires Green, green/black, blue and blue/white. I brought a male plug all wires has same color as black, does anyones has knowledge of this wiring colors. see pictures below
    Thanks for your help
  27. Mar 24, 2021 at 11:35 AM
    RainMan_PNW
    Casey
    Clark County, WA
    You'll want to start by downloading and saving this PDF.
    https://www.tundras.com/attachments/2021-tundra-ewd-em27m0u-2-0-system-circuit_2016-17-pdf.531489/
    Then, depending on your engine (4.6L or 5.7L), you need to review one of two pages.
    Page 174 is the Engine Control for the 4.6L
    Page 207 is the Engine Control for the 5.7L
    Looks like both have same wiring for that sensor:
    Green/Black to Pin 1
    Blue/White to Pin 2
    Green to Pin 3
    Blue to Pin 4
    Pin numbers are based on looking at the "socket" end (not the wiring end) of the connector.
    trantundra[QUOTED] likes this.
  28. Mar 24, 2021 at 11:39 AM
    trantundra
    Thank you so much RainMain...
    Tom's Tundra and RainMan_PNW[OP] like this.
  29. Mar 24, 2021 at 11:39 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Hey Casey, you seem to have gotten REALLY good at finding stuff in those wiring diagrams! It takes me awhile to find what I am looking for, much less what someone else asks about!
    Tom's Tundra and trantundra like this.
  30. Mar 24, 2021 at 12:19 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I have spent WAY too much time sifting through them to do mods, going back to my 2008 truck. So, I've really gotten to know the structure of them. Doesn't hurt I've got a really nice (and expensive) PDF software on my computer that lets me bookmark, search, and OCR them to help find stuff.
    Tom's Tundra and Hightide like this.
