Wireless Charging
Discussion in '3rd Gen Tundras (2022+)' started by PA_Richie, Feb 5, 2022.
  1. Sep 27, 2023 at 1:59 PM
    #61
    slu94
    slu94 New Member
    Guy
    23 Tundra sr5
    Leveled
    What brand charger? Your Amazon link doesn’t work.
    thanks.
  2. Apr 21, 2024 at 4:03 PM
    #62
    79mjenks
    79mjenks New Member
  3. Apr 22, 2024 at 8:07 AM
    #63
    awpk03s
    awpk03s New Member
  4. Apr 22, 2024 at 8:43 AM
    #64
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Breathing Borla likes this.
  5. Apr 22, 2024 at 9:43 AM
    #65
    grizzy86
    grizzy86 New Member
    Depends on where you live, this looks pretty slick
  6. Apr 22, 2024 at 10:03 AM
    #66
    Breathing Borla
    AZ
    if you get in a wreck that phone flying at you may suck as well
  7. Apr 22, 2024 at 10:12 AM
    #67
    grizzy86
    grizzy86 New Member
    But the golf clubs on the back seat will already have taken me out? So....
  8. Apr 28, 2024 at 5:55 PM
    #68
    awpk03s
    awpk03s New Member
    I ordered that one from Amazon linked above that fills the dash void. Looks nice and seems well made. Install was easy. It doesn’t sit completely flush, but it’s uniform all the way around, and I suspect it’ll settle in some. It looks good. In a few short drives, it is not picky about phone location, toss her up there and it charges up, doesn’t move around. Will see how it does with heat or etc over time.
  9. Apr 29, 2024 at 6:19 PM
    #69
    Poolguy89
    Poolguy89 New Member
    2024 Black Limited iForce Max
  10. Apr 30, 2024 at 3:30 AM
    #70
    jh7000
    jh7000 New Member
    I am using that, I replaced the factory wireless charger with that one. The factory charger only had 1 coil on it, the one you linked has 3.
    With the factory charger, I would always have issues where charging would start, then 30 seconds later it would stop... with the new one, it just works all the time.
    PapaDave418 likes this.
  11. Apr 30, 2024 at 6:06 AM
    #71
    Poolguy89
    How was the install? Did they have instructions or a video?
  12. Apr 30, 2024 at 7:59 AM
    #72
    jh7000
    jh7000 New Member
    I found a YouTube on removing the center cons
    I followed this video on Youtube https://www.youtube.com/watch?v=0p0-j9Ea1OU to take apart my center console. I don't think the new charger from European Enterprises had any instructions with it - but I bought the "Qi Lite v2" version. After unscrewing the factory charger, which was 4 screws, I installed the new one which was just 3m adheasive. I removed the tape and mounted it to the back of the plastic where my phone would sit. I pressed the adhesive strips in pretty well and it seems like it will hold just fine, so far so good anyway.
  13. May 30, 2024 at 7:13 AM
    #73
    chavey2
    chavey2 Stormtrooper in Training.
    Christopher
    Austin, TX
    2024 Tundra SR5 Double Cab Std Bed 4x4.
    Just starting
    FYI - I bought this and returned it before I saw your post. Yes, it fit well on top of the dash and looks very stock. However, it had some MAJOR issues that I called it defective and returned:
    1. Majorly overheated the phone, so much so that either a) I couldn't even touch the phone or put it in my pocket, or b) actually shut the phone down because it was too hot.
      • Before anyone asks, the phone was not in the sun (we were heading north so the roof shaded it), it was only 84 degrees outside and 74 degrees inside. This happened all 3 times I tried to use it.
    2. Didn't charge well enough to help. I have a wireless charger at home that gets me about 1% per minute. I was driving home (45 mins) and only got ~5% charge without using the phone. Perhaps the above overheating issue affected this too.
    3. You can't see the phone from the driver's seat. Shouldn't be a problem while driving (no distraction), but you couldn't even see if you got the phone in the correct location to start the charge, or even if the charger was turned on and working.
    I can't recommend this one, but perhaps other users had better experiences.
  14. May 31, 2024 at 2:29 AM
    #74
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    I know this one from sleeoffroad.com is pretty expensive and keeps going out of stock, but has anyone installed it that can report back on your experience?
  15. Jun 1, 2024 at 8:10 AM
    #75
    awpk03s
    awpk03s New Member
    Yeah, I noticed it definitely does overheat the phone, even when starting from a cool garage; so it’s not the sun…. I took it out.
    chavey2[QUOTED] likes this.
  16. Jun 2, 2024 at 8:05 AM
    #76
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Was this plug and play if you already have the factory charger?
  17. Jun 2, 2024 at 5:03 PM
    #77
    tundrametz
    tundrametz New Member
    2024 Tundra Limited TRD Off-Road
    This was one of my first modifications, if not the first, I did to my truck after I bought it. My truck did not have a factory charger but my wife’s 2024 Venza did have one. Easy install and it has been working great for over 6000 miles (many extended highway trips using Google Maps and Spotify). It definitely works better than my wife’s factory charger. The only quirk is that you have to press the button to turn it on after every ignition key cycle. But, it has become second nature to turn it on as I place my phone on the charger.
    Was it worth the cost and would I do it again? Yes and absolutely I would.
    HTH
    Hoody[QUOTED] likes this.
  18. Aug 27, 2024 at 3:52 PM
    #78
    ansel123
    ansel123 New Member
    Sr5 2024
    Several
    Put the apple charger where the factory charger would be used double stick tape and ran the cord into the console
    works perfectly
  19. Aug 27, 2024 at 4:13 PM
    #79
    iforceAZ
    iforceAZ New Member
    The OEM one stinks. Turns on and off. Just bad overall.
    ansel123 likes this.
  20. Jan 19, 2025 at 3:42 PM
    #80
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    How is this charger working? Does it actually charge up when you are using CarPlay or AA? Is it faster than OEM?
  21. Jan 19, 2025 at 3:43 PM
    #81
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    How do you like this unit now that it’s been another 7 months? I’ve read that 10W per side is slow on the charging with CarPlay or AA running?
  22. Jan 30, 2025 at 9:15 PM
    #82
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
  23. Feb 1, 2025 at 12:11 PM
    #83
    matth66
    matth66 New Member
    matt
    Nor cal
  24. Feb 1, 2025 at 12:26 PM
    #84
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    It piggy tails from the 12v at the top of the dash. So it doesn’t display the Qi charger logo on the factory radio screen but I use CarPlay and it displays a charging battery there. The whole install was maybe 20 mins. Works great and charges well. Plus I could therotically swap back in the OEM and sell this if I really wanted to in the future.
  25. Feb 1, 2025 at 10:13 PM
    #85
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Does your iPhone heat up when charging on this? The Tacoma Qi made it way to hot as well another car we had. Not good for the battery or phone.
    PapaDave418[QUOTED] likes this.
  26. Feb 2, 2025 at 4:30 AM
    #86
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I have not noticed it being hot so far
  27. May 7, 2025 at 3:22 PM
    #87
    mwrood
    mwrood New Member
    Out of curiosity, which wire from the cigarette lighter is the positive and which is the negative? Also, did you add an inline fuse for the usb ports?
  28. May 8, 2025 at 5:34 AM
    #88
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Here's my latest take on this.... dual MagSafe chargers in a 3D printed block, plus some 3D printed clips to dress the cables. Fasten the clips to the console with thin 2-sided tape. The 3D printed block has indentations to accept the phones' camera bumps so they can sit flat and make perfect contact with the charging pucks. You could always use black cables and pucks to get a stealth install. Looks like I don't have the clips saved on Thingiverse yet, I'll try to post them there sometime. If anyone is interested let me know and I'll try to expedite that.
    https://www.thingiverse.com/thing:5846453/files
    Linuxrules likes this.
  29. May 10, 2025 at 6:37 AM
    #89
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    This is somehow buried in a female’s DNA…
  30. May 10, 2025 at 6:51 AM
    #90
    DontTazeMeBro
    DontTazeMeBro New Member
    2022 Platinum MGM
    I have this one as well. Pretty simple install, and works great. Only odd thing, as you mentioned, is that you have to push the power button to start it. Works excellent.
