Wireless charger in center console
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pudge, Mar 8, 2017.
  1. Mar 8, 2017 at 3:47 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I bought a $12 charger off Amazon and figured I'd give this a go. I used a dremel and a chisel to get the surface under the little tray on the arm rest perfectly flat, and it had to be very smooth in order to charge through my spigen s7 case. Once I had that done realized I also would have to remove the cover of the charger to get a reliable connection. Then I got it in place and used a piece of Styrofoam on top of the charger to use as a pressure fit between case and the inside console cover. Worked out great and I highly recommend this mod. Took about 1 hour in all. Didn't take many pics but you get the idea. I plugged it in to the port in the console.
    Dgjman, JoshuaA, No Limit and 2 others like this.
  2. Mar 8, 2017 at 7:23 PM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    Awesome work!
    Pudge[QUOTED][OP] likes this.
  3. Mar 8, 2017 at 7:43 PM
    Pudge
    CT
    I made sure to get a 3 coil charger so I wouldn't have to worrying about exact placement. There's a decent amount of leeway with the 3 coil
  4. Mar 15, 2017 at 1:17 PM
    TigerTanker
    TigerTanker Tyranny doesn't leap, it creeps
    Tacoma WA
    2016 White Platinum Edition Tundra
    none so far
    You just reminded me to ask...
    In my GMC, I could charge off the Cig lighter even if the car wasn't running.
    It appears I can't do that in my rig? Is any outlet hot when the truck is off, can I change it if I want?
    Muchos thankos!
  5. Sep 7, 2017 at 7:58 PM
    mscroggi
    mscroggi New Member
    I believe the answer is - Not in the stock configuration.. I think its relatively easy to run an extra hot wire to a 12 power receptacle, or even easier, plug in one of these - https://goo.gl/c9WJHV in one of the blanks, and run the cables straight to the fusebox.
  6. Sep 7, 2017 at 8:03 PM
    Great job! Great write up n mod!
  7. Aug 18, 2019 at 9:33 AM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
    Awesome idea and write up Pudge. I just ordered a wireless charger on Amazon to do this mod as soon as I get my Truck. I have wireless charging in my 19 Chev and really like it. I was going to miss that feature...thanks to you I won't !
  8. Aug 27, 2019 at 6:47 AM
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    I need to do this!
  9. Aug 27, 2019 at 6:48 AM
    soobahru
    soobahru New Member
    Can it do fast charging? That would be mint.
  10. Aug 27, 2019 at 7:15 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    I did the mod. Tried a fast charger using a Samsung "Puck" and it's signal was poor. Tried an older traditional Samsung and it worked fine with thin cases. Someone bought a charger that was designed to be mounted under tables and apparently that worked perfectly. Your mileage may vary.
  11. Aug 27, 2019 at 7:20 AM
    soobahru
    soobahru New Member
    Yup was thinking the same about the puck. I think IKEA has some.
  12. Aug 27, 2019 at 10:09 AM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Has anybody done this that has the Tufskinz center console pad thingy? I like the looks of mine but wouldn’t mind doing a wireless charger as well. Wondering if there would be too much/thick material in the way.
  13. Sep 7, 2019 at 7:01 AM
    No Limit
    No Limit New Member
    Alberta
    +1 I am wondering the same
    bigzrs01[QUOTED] likes this.
  14. Sep 7, 2019 at 9:15 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    It may if you output a high watt cigar > USB-C to USB-C cable > newer Qi wireless charger, and you own a capable android.
    I did this mod with a regular cigar but don’t use it much because my drives are short. I’m on iPhone and it’s a lot faster wired using my other HW cigar charger (18W is sufficient, it’s negligibly faster more than that) and a USB-C to lightning cable.
  15. Sep 7, 2019 at 5:14 PM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Might have to be the guinea pig for this and try it
  16. Sep 7, 2019 at 5:23 PM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
