Wireless Charger In center Console DIY. 2014+ Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by trdlife, Nov 12, 2017.
  1. Sep 17, 2019 at 9:40 PM
    #211
    kw819
    kw819 New Member
    Good to hear about the success rate so far of the cheotech. Been wanting to do this mod for a while but I use car play and have to plug in, so until I can get wireless CarPlay I may hold off since I doubt I’ll use it
  2. Sep 18, 2019 at 9:02 AM
    #212
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    Installed a Mophie yesterday. I have had the charging pad in the center console (orginizing tray) for while. Just finally got around to installing it to work with the center phone holder. Fingers crossed.
  3. Sep 18, 2019 at 10:34 AM
    #213
    TundrAZ
    TundrAZ New Member
    Joe
    AZ
    2018 Black Tundra Limited 4x4
    Icon Rebound 17” wheels Titanium finish, 285 75 17 BFG KO2’s, Billstein 5100 front/back, leveled, Westin Protraxx 4” oval step bar, Dirty Deeds standard 8” system, Viper remote start, color match door handles and mirror caps, JDM ASTAR led interior lights, center console organizer tray, VViViD vinyl wrap carbon fiber interior trim, AJT Designs vent covers, stubby antennae
    Had the Cheotech for about a year now. No issues.
  4. Sep 20, 2019 at 6:18 PM
    #214
    Crizzlej5
    Crizzlej5 New Member
  5. Oct 4, 2019 at 7:26 AM
    #215
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I just picked up a pixel 3xl.....first phone with wireless charging. It looks like the there is a 5 coil cheotech out there, but it looks like it will only charge with 7.5w of power per the reviews.
    Anyone find a 10-15w qi charger that will work well for the mod?
  6. Oct 4, 2019 at 10:39 AM
    #216
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    I bought the Cheotech charger with the intent of install in/under the console trey, but was screwing around today in the truck and temporarily did this. Maybe another option.
    Which got me thinking of installing over/under this location or under the front part of the console and either plugging into the front port or the one inside the console. I ran the wire underneath to the front and plugged it in there since I was running out to lunch. Putting the phone on it, like it is, with an Apple leather case, it didn't slide or budge at all.
  7. Oct 4, 2019 at 10:47 AM
    #217
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    I have a round one in that I already used for in the house, it works but it doesn't have enough coverage. I looked hard at the QI but went with this Choetch since it has more than one coil.
    https://www.amazon.com/gp/product/B07PYQQ1R7/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    I'll install this weekend.
  8. Oct 6, 2019 at 8:47 PM
    #218
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    Installed line this week and live it. Only took me about 30 minutes and most of that was sanding .
  9. Oct 6, 2019 at 8:51 PM
    #219
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I did this mod a couple years ago with a choetech 2 coil. I have always had issues with it connecting and maintaining connected. I have an samsung Galaxy s7 witb a spigen slim case. It charges better without the case. Does anyone know of a reasonably priced multi coil charger that may provide me with better charging thru my case? I'm not willing to part with having a case on, so sometimes I end up plugging it on to charge. I would be willing to swap out the old charger for a new one, and maybe relocate the current one to a different spot.
  10. Oct 6, 2019 at 9:29 PM
    #220
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    I just installed the Choetch 5 coil I’ll let you know if the phone moving is a problem. I had the same problem with my last one.
  11. Oct 10, 2019 at 2:58 PM
    #221
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Just did this mod. Less than an hour to do. Very cool. Thanks!
  12. Oct 10, 2019 at 3:35 PM
    #222
    Jsnake89
    Jsnake89 New Member
    Dane
    I did the 3 coil In mine and works great.
  13. Oct 13, 2019 at 8:43 AM
    #223
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    Pudge likes this.
  14. Oct 13, 2019 at 8:46 AM
    #224
    Stocky Balboa
    OC , CA
    I have the rubber insert on the center console tray with a thinner case and mine works well.
    Pudge likes this.
  15. Nov 11, 2019 at 5:05 PM
    #225
    Will McLane
    Will McLane New Member
    Will
    2016 Tundra Platinum
    Cheotech 5 coil Saran wrapped and coated with 2 part epoxy. 2017 Tundra Platinum.
    Slid out charger and cut vents with dremmel.
    Charges through case
    Reinstalled
  16. Nov 15, 2019 at 7:04 AM
    #226
    jrd347
    jrd347 New Member
    2018 Tundra Limited 4x4
    New item what you think?
  17. Nov 15, 2019 at 7:15 AM
    #227
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    Ummm. Yes. Where can you buy it?
  18. Nov 15, 2019 at 7:28 AM
    #228
    kw819
    kw819 New Member
    thats real nice but how much? and can it be hard wired into the cig lighter or does it have to be plugged in
  19. Nov 15, 2019 at 7:43 AM
    #229
    prerunnerseth
    Apex, NC
    He says hes at a dealership and they just came in. So im assuming theyre an official accessory and have a way to power them from factory wiring.
  20. Nov 15, 2019 at 7:43 AM
    #230
    jrd347
    jrd347 New Member
    kw819 likes this.
  21. Nov 15, 2019 at 7:44 AM
    #231
    jrd347
    jrd347 New Member
    It is distributed by Southeast Toyota I work for a dealership in South Florida. Message me if interested
    619Tundra likes this.
  22. Nov 15, 2019 at 7:46 AM
    #232
    prerunnerseth
    Apex, NC
    You have a part number?
  23. Nov 15, 2019 at 7:53 AM
    #233
    kw819
    kw819 New Member
    do you know how much they run? one of my local dealerships said they don't have an approved vendor to get them yet.
  24. Nov 15, 2019 at 8:09 AM
    #234
    jrd347
    jrd347 New Member
  25. Nov 15, 2019 at 8:11 AM
    #235
    Danimal86
    Daniel
    Sacramento, CA
    this is what i've been waiting for!
    Voyagermike likes this.
  26. Nov 15, 2019 at 8:26 AM
    #236
    prerunnerseth
    Apex, NC
    It should be better for charging with cases as it minimizes the space between the coil and phone. The diy method still leaves a pretty big space because of the ridges in the tray.
  27. Nov 15, 2019 at 8:49 AM
    #237
    lewishenry19
    lewishenry19 New Member
    Shoot, I might have to do this now.
    Voyagermike and 619Tundra like this.
  28. Nov 15, 2019 at 9:02 AM
    #238
    prerunnerseth
    Apex, NC
    Ordered. First one
  29. Nov 15, 2019 at 9:16 AM
    #239
    jrd347
    jrd347 New Member
    Thanks
  30. Nov 15, 2019 at 12:49 PM
    #240
    Will McLane
    Will
    Well dang, after all that work...
