Wireless Charger In center Console DIY. 2014+ Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by trdlife, Nov 12, 2017.
  1. Jun 13, 2018 at 5:36 PM
    #151
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Got a link to where you got this?
    Nevermind I found it. $200 ???:eek:
  2. Jun 15, 2018 at 7:01 AM
    #152
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    Ok so does anyone know how to hardware a usb accessory or would it be better to run the plug up into my center console and plug into my new dualC3A9BA56-0C7B-4157-8D9F-13E35E49A764.jpg plug?
  3. Jun 15, 2018 at 9:04 AM
    #153
    trdlife
    trdlife [OP] Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Pudge[QUOTED] likes this.
  4. Jun 15, 2018 at 9:06 AM
    #154
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    On the first page of the thread, I linke another thread on hardwiring and installing a usb outlet. but note, charge time will be slowing unless you use the fast charge capable usb power port.
  5. Jun 15, 2018 at 9:28 AM
    #155
    Pudge
    CT
    trdlife[QUOTED][OP] likes this.
  6. Jun 15, 2018 at 12:57 PM
    #156
    sgrounds22
    sgrounds22 New Member
    2018 Tundra Limited
    I ordered one and it said it wouldn't ship until 6/22. It arrived today
  7. Jun 15, 2018 at 1:15 PM
    #157
    Pudge
    CT
    Damn maybe I'll just order one. I have one under the consol but it charges sporadically so I'd like something more reliable.
    Thanks!!
  8. Jul 30, 2018 at 6:54 PM
    #158
    brad71
    brad71 New Member
    Brad
    Pennsylvania
    2017 Quicksand Toyota Tundra
  9. Jul 30, 2018 at 8:37 PM
    #159
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Hmm, kinda sounds like a charger issue, what are you using for power source? And did you split the case to expose the coils or just mount it up?
  10. Aug 6, 2018 at 9:14 PM
    #160
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I just tried using this charger and it doesn't work. I will take it apart to expose the coils to see if that helps. I'm also mounting it by the gear selector.
  11. Aug 6, 2018 at 9:20 PM
    #161
    r1-superstar
    DB
    UTAH
    That's where I'm installing mine tomorrow.
  12. Aug 7, 2018 at 7:15 PM
    #162
    r1-superstar
    DB
    UTAH
    First attempt. Clean install, charger didn't work even with exposing the one coil. This was the armrest version. However I didn't want my phone flying when the wife or kids open it up. SO I installed it down by the gear selector.
    Second attempt. Cheotech charger mounted by the gear selector. Exposed the three coils and it works.
    trdlife[OP] likes this.
  13. Aug 7, 2018 at 8:12 PM
    #163
    SNO BUS
    SNO BUS Professional Moneywaster
    Nick
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
    :spending:
    It's all supposed to be here tomorrow... let's see how it goes. I wish Samsung made a fast charger with 3 coils so I could use that instead of an off brand cheapie from Amazon but you can't have everything
  14. Oct 26, 2018 at 7:00 PM
    #164
    The Pope
    The Pope New Member
    How did you guys make the charger work thru the plastic of the middle console? I did everything, as it shows in the post and purchased the same wireless charger, but it will not charge thru the plastic console.
  15. Oct 27, 2018 at 6:13 AM
    #165
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    What phone do you have? and the charge cable and everything is good? my charges as soon as i set it in there. do you have a thick case on the phone?
  16. Oct 27, 2018 at 6:47 AM
    #166
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    Did you take the charger out of its case and only mount the circuit board? If yes and you know its working the only other thing i think would be the size of your case. I have a pretty thin case on mine and it works fine
  17. Oct 27, 2018 at 7:19 AM
    #167
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I cut the grid structure from underneath the console pocket and sanded it flat with a da sander. I then removed the the top half of the charger exposing the coils and used gorilla take to mount it. I have a thin spigen cover on my s9+ and it charges great.
    I think the key is to minimize what you have between the phone and charger.
  18. Oct 27, 2018 at 12:59 PM
    #168
    The Pope
    The Pope New Member
    Yes, I did cut the ribs off the back of the console, took the top off of the charger, the cable is good the charger is good, I took the case off of my IPhone X and it will not charge. If I place the phone with the case directly on the charger, it charges fine. But it will not charge thru the console.
  19. Oct 27, 2018 at 1:25 PM
    #169
    ZPMAN
    Minnesota
    Maybe this guy made your counsel?
  20. Oct 27, 2018 at 1:37 PM
    #170
    smooosh
    Ongoing project
    Console or armrest?
  21. Oct 27, 2018 at 1:44 PM
    #171
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    A coworker's iphone x charges fine on mine. He has an otterbox case.
  22. Oct 27, 2018 at 3:05 PM
    #172
    The Pope
    The Pope New Member
    Middle console, right under the lid. I even took the case off of the iphone and it is still not charging. The charger only has one round coil, when I opened it up, so maybe that is the issue, it doesn’t have the three coils like the pictures posted at the beginning of this post. Perhaps it is not strong enough to work thru the thick plastic of the middle console lid. Any suggestions? I ended up place it in on top of the lid in the little opening there and ran the cable from inside the middle console thru a small hole I drilled and it works fine this way, even with the iphone case on the phone.
  23. Oct 27, 2018 at 3:10 PM
    #173
    smooosh
    Ongoing project
    Use this one. It will work. Choetech T513 3 Coils Qi Wireless... https://www.amazon.com/dp/B00JA7HNZO?ref=yo_pop_ma_swf
    dud13 and Hondoman like this.
  24. Oct 27, 2018 at 3:18 PM
    #174
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
  25. Oct 27, 2018 at 4:39 PM
    #175
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    Same. Works like a champ!
    Hondoman[QUOTED] likes this.
  26. Oct 27, 2018 at 4:50 PM
    #176
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    I have the same one too! Zero issues charging my iPhone 8 Plus through an otter box case.
    Hondoman likes this.
  27. Oct 29, 2018 at 11:46 AM
    #177
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Yea that sounds like your issue, I tried he 1 coil first, and had issues, switched to the 3 coil chargers and have no issues.
  28. Oct 29, 2018 at 3:47 PM
    #178
    ZPMAN
    Minnesota
    Is it fast charging?
  29. Oct 31, 2018 at 8:05 AM
    #179
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    yes, as long as you use a fast charge usb like i have listed, i use it with mine. Wireless fast charge is of course still slower than regular but this will still be fast than a regular usb plug.
  30. Nov 19, 2018 at 2:06 AM
    #180
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I'm thinking of getting the iPhone XS max and then doing this. Does anyone know if that phone will fit in the center armrest part? Don't want to get it and find out it doesn't
