Wireless Carplay with the Kenwood DMX906S in a SR Loooooooooooooong bed
Discussion in 'Audio & Video' started by GeoJoe, Jul 17, 2019.
  1. Jun 24, 2020 at 11:33 AM
    #91
    zippy15
    zippy15 New Member
    Les
    2019 Tundra Limited
    I have this same HU with a Maestro RR2 in a 2019 Tundra Limited and am not getting any Fuel gauge. The Tire Pressure and other gauges work OK, but when I go into Settings to pick which gauge to use on the P1/P2 screens, it is x out. Any ideas?
  2. Jun 24, 2020 at 11:40 AM
    #92
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    My fuel gauge doesn’t show either. I did find that sometimes revalidating PIDs on the HU can help get some parameters working (I wanted to display Transmission temperature but it was greyed out and when I revalidated the PIDs it was available)
    You can do that through the OEM settings menu on the HU. I can check later on how you actually get to that function.
  3. Jun 24, 2020 at 2:56 PM
    #93
    zippy15
    zippy15 New Member
    Les
    2019 Tundra Limited
    I went ahead and gave that a try (actually a couple of times) and still no Fuel option available to select. Odd that some Tundras have the option and others not.
  4. Jun 24, 2020 at 3:33 PM
    #94
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    2016 w/ Dmx 906s and TPMS works for me except that I have 2 bad sensors. Mine's a limited and did not display pressure on the dash.
  5. Jun 30, 2020 at 8:18 AM
    #95
    3rdGenTundraDC
    3rdGenTundraDC New Member
    MGM
    Central Florida
    14 Tundra DC
    305/50/20 Nitto Terra Grappler G2 Stock, stock, stock.
    I may bite the bullet and give it a go since I'm having issues with my Crux steering wheel module. Thanks for the confirmation.
    831Tun[QUOTED] likes this.
  6. Jul 14, 2020 at 5:14 PM
    #96
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
    Are any of you guys having reboot issues? I have a 9706S and when it is hot out and I get in the truck after everything boots up, if I use the steering wheel controls to call home, Siri says I'm checking and then the unit shuts down and reboots
  7. Jul 17, 2020 at 8:43 AM
    #97
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    My 906s reboots every now and then. I've not been able to identify a discernible pattern. It's done it while in Android Auto, Spotify, and just listening to the radio. Different times of year in varying temps. It does not do it often, but is annoying when it does.
  8. Oct 31, 2020 at 9:46 AM
    #98
    Eyeonyou
    Eyeonyou New Member
    I’ve had this HU for about a year in my 2007 tundra and love it. Recently after iOS14 the music apps go to black screen when you click on them on the screen. They only open up after I open them on my phone first. This happens every time now. Mostly on iheartradio, but it will happen on the others as well.
  9. Nov 19, 2020 at 11:41 AM
    #99
    lsumatt1514
    lsumatt1514 New Member
    2020 Tundra Crewmax Platinum
    What's the verdict on this head unit? I've got a lead on a good used one, and I'm thinking about going with it and saving $400-$500 from buying a new unit. Thanks!
  10. Nov 19, 2020 at 11:42 AM
    #100
    lsumatt1514
    I'm thinking of putting this unit in my 2008...are you pleased with it and can you post pictures of your install so that I can see what it will look like? Thanks!
  11. Nov 20, 2020 at 7:52 AM
    #101
    lsumatt1514
    One additional question...has anyone tried to install this system themselves? I just got a really, really high quote from a local stereo shop. Biggest concern is configuring the Maestro unit. Thanks!
  12. Nov 20, 2020 at 9:10 AM
    #102
    AZBoatHauler
    So.Arizona
    Lots of us have. On a scale of 1-10 difficulty to install I’d rate it 3. Read the instructions twice, take your time, and you should have it done in a couple hours.
  13. Nov 20, 2020 at 9:24 AM
    #103
    lsumatt1514
    Is that a 3/10 to install the Kenwood and/or the Maestro unit? Thanks!
  14. Nov 20, 2020 at 9:31 AM
    #104
    AZBoatHauler
    So.Arizona
    They are both easy. Flashing and hooking up the Maestro takes about 30 minutes. The HU/wiring harness is a little more time consuming but not difficult if you’ve ever spliced wires.
    My advice is to get the RR2 unit as several of us get random HU reset with the RR.
  15. Nov 20, 2020 at 4:29 PM
    #105
    lsumatt1514
    Few questions guys...
    1. Is there an antenna adapter required to connect the Kenwood to the Toyota antenna wire?
    2. Did anyone install a harness to allow for video playback on the Kenwood while in motion, and if so do you have a part name/number and instructions? I found this on Amazon: https://www.amazon.com/gp/product/B...title_srh_1?ie=UTF8&psc=1&smid=A3PEORXDHEWCJ1
    3. Will Crutchfield build a wiring harness for me (ReadyHarness), even if I did not buy the receiver from them (willing to pay for service and harness of course)?
    Thanks!
  16. Nov 26, 2020 at 5:25 AM
    #106
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    So does this thing let you adjust the factory convenience settings through the head unit? Like door lock settings, feedback settings, etc.? Can you also access the in-car WiFi settings through it like you can on the factory HU?
  17. Nov 26, 2020 at 6:53 AM
    #107
    AZBoatHauler
    So.Arizona
    Yes.
    This I can’t confirm since my truck doesn’t have wifi.
  18. Dec 1, 2020 at 4:03 PM
    #108
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
  19. Dec 1, 2020 at 4:11 PM
    #109
    glowblue
    VA
    Awesome! Thanks for the info. I updated to the iPhone 12 and my receiver rebooted recently so it’s not the iPhones issue, reboots when using Wireless CarPlay. It seems “stability improvements” are a common theme in the firmware upgrades!
  20. Dec 2, 2020 at 6:16 AM
    #110
    lsumatt1514
    How do you install the firmware updates...use a thumb drive in the USB port? Thanks!
  21. Dec 2, 2020 at 6:19 AM
    #111
    radon222
    Ed
    NW Arkansas
    Stock for now
    Yup. There is a downloadable PDF with instructions on the Kenwood site. But basically download the firmware zip file, Extract the compressed files to an EMPTY USB thumb drive and plug it into the receiver USB port.
  22. Dec 2, 2020 at 6:32 AM
    #112
    Kurdt
    Kurdt New Member
    Austin TX
    I updated mine recently hoping it would resolve the random reboot issue. It rebooted again the next day, so didn't fix it for me.
  23. Dec 2, 2020 at 12:16 PM
    #113
    glowblue
    VA
    Damn! That’s the only reason I updated. Just did it today. It kept failing on me initially - so I disconnected battery and tried a different USB stick and reformatted it on Windows (initially used my Mac to format MS-DOS FAT). It seems the Kenwood HU is ultra sensitive to the USB drive.
  24. Dec 2, 2020 at 7:37 PM
    #114
    lsumatt1514
    Can someone double check me here...I just downloaded the latest firmware. When I open my thumb drive, there is a root folder named S_V1_8_0009_5900. When I open it, there are two folders named BOOT_V1_8_0009_5900_release and SOC_V1_8_0009_5900, and also an icon named UpdateVersionControl. Can someone confirm this is correct? I don't want to brick this unit the moment I install it. Thanks!
  25. Dec 3, 2020 at 5:52 AM
    #115
    glowblue
    VA
    That looks right. Good luck! You should be fine. My first attempt failed and the HU went into a constant reboot cycle. I had to reformat my USB and reload the files and it worked fine on the first attempt on the reformatted USB.
  26. Dec 3, 2020 at 6:07 AM
    #116
    lsumatt1514
    Do you mind elaborating on how you formatted your USB stick? I bought a new one and didn't do any formatting...just dropped the firmware updates onto it. Thanks!
  27. Dec 3, 2020 at 6:13 AM
    #117
    glowblue
    VA
    I had an old USB lying around and tried first to format on my Mac...then loaded the firmware update. It started off ok but the update wouldn’t finish - I kept getting errors and it would endlessly cycle.
    I then reformatted it on my Windows machine, reloaded the firmware and presto... worked on first time.
    I think a new USB out of the box may not need formatting.
    lsumatt1514 likes this.
  28. Dec 18, 2020 at 11:10 AM
    #118
    lsumatt1514
    I got my firmware updated, but I am still having random reboot issues. Has anyone successfully isolated this to the Kenwood, or the Maestro? Thanks.
  29. Dec 24, 2020 at 8:10 AM
    #119
    lsumatt1514
    Had another random reboot yesterday...anyone been able to isolate this problem? Thanks guys.
  30. Dec 24, 2020 at 8:18 AM
    #120
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Happens to me pretty frequently. At least once a week and I’m only driving 10 miles per day. I’m leaning towards the maestro and a voltage issue. Probably going to pull the HU at the start of the year and run it on bench top for a few days to confirm my theory. If all goes well I’ll ditch the maestro and hardwire it. Only issue will be the backup camera
    AZBoatHauler likes this.
