Wireless Carplay with the Kenwood DMX906S in a SR Loooooooooooooong bed
Discussion in 'Audio & Video' started by GeoJoe, Jul 17, 2019.
  1. Aug 19, 2019 at 6:37 PM
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    I installed a Kenwood HU in my daughters 4Runner and had to put the new mic on the pillar at the top. Seems to be a good place for it. It wasn't long enough to reach the rear view mirror, unless spliced. I was going to stick out to the mirror channel.
  2. Aug 20, 2019 at 5:46 PM
    GeoJoe
    GeoJoe [OP] 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    Here's a pic of the mic install spot in mine.
    Also I had to reconfig the Maestro to get some settings the way I wanted.... turns out it has to have zero power running to it to reflash it. So either disconnect the power harness from the Maestro unit... or supposedly you can pull the radio fuse... or even the battery. Either way is probably easier than dealing with this mess.
    Here's my Maestro settings. I could only get the left side of the steering wheel buttons to configure. All mine on the right side remain with stock functionality.
    TuFerLife likes this.
  3. Aug 20, 2019 at 6:07 PM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    I had the same problem. I guess it’s not that big of a deal that might right side doesn’t work. But only my left side works.
    I’ll take a pic of my mic in a minute, but I think I might have to move it...
    Also, I plugged the USB into the grey port (for android) instead of the black port (for Apple), so now I gotta pull it back out of the dash. :anonymous:
  4. Aug 20, 2019 at 6:19 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    You can't use the mic that's built in the truck?
  5. Aug 20, 2019 at 6:55 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    Not that I’m aware of... there’s no adapter to make the OEM one work. Kind of dumb...
  6. Aug 20, 2019 at 7:06 PM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Sounds like a job for a soldering iron and electrical tape.
  7. Aug 22, 2019 at 5:27 AM
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    What do you mean right side of steering wheel?
  8. Aug 23, 2019 at 5:18 AM
    GeoJoe
    Buttons on right side remain with stock functionality and controls the screen on the dash. Buttons of left side of wheel are highly configurable with Maestro options.
    NCTundra1980[QUOTED] likes this.
  9. Aug 23, 2019 at 5:20 AM
    NCTundra1980
    Stephen
    2019 SR5
    Oh awesome ok sounds great, I have a 19 and want car play. I think Im gonna wait to see the new aftermarket decks coming next year but I’m trying to get a game plan now thank you for your help
  10. Sep 2, 2019 at 3:47 PM
    amkesler26
    amkesler26 New Member
    What rear view mirror is that?
  11. Sep 2, 2019 at 4:17 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    I have the DMX 905s and I had the same issue with the fuel gauge on my SR5 double cab so I just chose a different gauge for that spot.....actually when I first installed mine I was having issues with the distance to empty showing on the truck gauge as well but that corrected itself.
  12. Sep 2, 2019 at 4:20 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    I originally mounted mine to the black part of the windshield behind and above the RVM but I was constantly having to take it off BT because people couldn’t hear me. So I moved it to this location and was a massive improvement, no issues since.
  13. Sep 2, 2019 at 4:43 PM
    GeoJoe
    Some dealer installed aftermarket junk that I can't get to program yet.
  14. Sep 6, 2019 at 11:04 PM
    amkesler26
    Got it! DO you have a front mounted camera? If so how well does it work?
  15. Sep 7, 2019 at 6:55 PM
    GeoJoe
    Yep... had one mounted above the Toyota badge on the grill. Cam and head unit work great together. But I had to tweak the settings as mine thought it was a rear cam at first.
    I had to clip a white jumper wire on the camera harness to make it forward facing. The Audiovox one I have comes set up as a rear cam. Cut the jumper and reset the power.... then the mirror image and parking lines go away and it's a front cam.
    In this...
  16. Sep 7, 2019 at 10:21 PM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    I have the DMX7706S amd my fuel % won't read or the tpms in each tire won't show...
    Called crutchfield and trouble shot everything, didn't work. They recommended calling maestro...but all of my other gauges work and are reading data from the truck
  17. Sep 9, 2019 at 7:09 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    My tire pressure seems to work fine on the radio....just not the fuel gauge
  18. Nov 16, 2019 at 12:43 PM
    3rdGenTundraDC
    3rdGenTundraDC New Member
    MGM
    Central Florida
    14 Tundra DC
    305/50/20 Nitto Terra Grappler G2 Stock, stock, stock.
    Looks like actual tire pressure value only works on 2018+ models. Can anyone with earlier year confirm otherwise? This is the only feature along with steering wheel control that's making me wanting to spend the $100 to add the Maestro RR.
    If you swapped in a non SR steering wheel with audio controls, are the earlier model SR prewired for it?
    831Tun likes this.
  19. Nov 16, 2019 at 1:22 PM
    #49
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I have individual tire pressure when I put in my KENWOOD and maestro on my 2016 Platinum. Lots of other members also.
    Sleeper16plat likes this.
  20. Nov 16, 2019 at 4:24 PM
    #50
    3rdGenTundraDC
    MGM
    Central Florida
    14 Tundra DC
    Did your Platinum display this in the center dash from factory? This will definitely determine if it's a programming/wiring issue or
    it's per trim level.
  21. Nov 16, 2019 at 8:51 PM
    #51
    GeoJoe
    Mine psi displays both via OEM and on the Kenwood, and they don’t match.
  22. Nov 16, 2019 at 11:03 PM
    #52
    3rdGenTundraDC
    MGM
    Central Florida
    14 Tundra DC
    The tundra tire pressure became a monitoring system but I'm not sure what year or trim level did they start switching over from the originally warning system. My 14 is only a warning system and does not display anything about the tire pressure in the dash display so I'm not sure if the maestro will be able to pull the data.
    Im pretty sure 18+ with the updated gauges will definitely work since you guys already have it on the dash. I guess it'll be a mystery for us owners with the warning system. I think the maestro is much like an obd2 scanner with the Torque pro app. If you cant get a specific data on the app, more than likely it will not be available with the Maestro.
  23. Nov 17, 2019 at 3:45 PM
    #53
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Nope
  24. Nov 21, 2019 at 3:38 PM
    #54
    cquilichini
    cquilichini New Member
    AGia15, zach_attack4 and BlueBottle like this.
  25. Nov 22, 2019 at 1:12 PM
    #55
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    I installed this unit last weekend and it's been awesome so far, other than it rebooting twice while running Waze over wireless AA. It's rebooted twice and only in that scenario. I haven't tried Waze with it wired yet. Just curious if others have experienced any reboots like this. I'll have plenty of drive time to test this out over Thanksgiving to see if it's a Waze thing, a wireless AA thing, or what.
  26. Nov 22, 2019 at 1:40 PM
    #56
    GeoJoe
    Mine has not rebooted but my GPS seems off. Was working fine. Now thinks it’s about 200’ to the left. Not sure if that’s from my phone or the unit GPS.
  27. Dec 7, 2019 at 9:08 AM
    #57
    jastran00
    jastran00 New Member
    Anyone have any issues adding a security code on their DMX906S? Based on the instructions, all you have to do is take it off Demo mode and it should appear in the menu settings. I have even tried standby mode, but no luck.
  28. Dec 12, 2019 at 4:45 AM
    #58
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Question for those with the Kenwood HU...I just installed the DMX906S with the Maestro RR unit. So far works really good - wireless CarPlay seems to be pretty solid. However, at night the screen is very bright and I have found no way to dim it. I read the manual and have played with the Display settings and only see the option to manually turn on/off the Screen Dimming, or Sync it with the headlight switch controller (the wiring diagram shows a conenction from the headlight switch position - but that doesn't seem to work for me).
    I am going to play with the viewing angle settings but wanted to ask if anyone has issues with the display screen being too bright at night.
    Thanks!
  29. Dec 20, 2019 at 2:50 PM
    #59
    zach_attack4
    zach_attack4 New Member
    Zach
    York, PA
    21 Army Green CM
    There's a way to do it. I had trouble finding it myself but finally got it. I don't recall the exact place off hand, but I'll check the truck and update when possible.
  30. Dec 20, 2019 at 4:03 PM
    #60
    glowblue
    VA
    I figured it out - there is a backlight setting when you press rhe menu button, then the screen adjust option. Not perfect but it helps.
    it isn’t cover in the manual however!
    zach_attack4 likes this.
