Wireless Android Auto - Available now!
Discussion in 'Audio & Video' started by Tundra234, Jan 27, 2022.
  1. Feb 28, 2022 at 5:41 PM
    #61
    Tundra234 [OP] New Member
    Other than unplugging it, is there a way to keep it from connecting if you don't want to use it that day?
  2. Feb 28, 2022 at 5:45 PM
    #62
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    I believe once it's connected you can just turn off your wifi and it will stay disconnected. I'll try it out tomorrow and let you know!
  3. Feb 28, 2022 at 5:55 PM
    #63
    Thanks. I think I tried that but it kept turning the wifi back on. I'll have to mess with it again as well.
    Moe2o4[QUOTED] likes this.
  4. Feb 28, 2022 at 6:21 PM
    #64
    Moe2o4
    Moe2o4 New Member
    Corey
    No problem! I'm thinking you could go onto the wifi and turn off auto connect as well!
  5. Mar 1, 2022 at 4:42 AM
    #65
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    In iphone under Setting>>General >>Carplay >>Unpair. If you want it to not reconnect. But this will unpair and you will have to re-pair the next time you want to use it.
  6. Mar 1, 2022 at 4:52 AM
    #66
    skip1980
    skip1980 New Member
    Columbia, Missouri
    Just for clarification, I have a 2018 with factory headunit. No Android auto or caraway. Will this add/allow you to use Android auto? Or did it have to come with it from factory?
  7. Mar 1, 2022 at 5:01 AM
    #67
    Moe2o4
    Moe2o4 New Member
    Corey
    It has to come from the factory with built in carplay. Which I believe is 2019 +.
  8. Mar 1, 2022 at 5:05 AM
    #68
    Moe2o4
    Moe2o4 New Member
    Corey
    So it looks like if you just turn the Wi-Fi off it will disconnect. And as long as you don't hit the map botton it won't automatically come back up. But if you hit the map button it will automatically come back up. If you go into your Wi-Fi and click the little gear next Android auto and I'm deselect automatically connect it won't automatically connect if you don't want it to.
  9. Mar 1, 2022 at 8:34 AM
    #69
    Thanks. I have a Pioneer head unit but I will take a look at the settings.
  10. Mar 1, 2022 at 8:49 AM
    #70
    Moe2o4
    Moe2o4 New Member
    Corey
    No problem, shouldn't matter what head unit you got as long as you disable the auto connect to the Android Auto wifi you should be all good!
    Tundra234[QUOTED][OP] likes this.
  11. Mar 13, 2022 at 10:52 AM
    #71
    odin1701
    odin1701 New Member
    2021 Tundra LTD TRD OR MGM
    These are showing available now on Amazon.
    PomDad likes this.
  12. Mar 13, 2022 at 11:10 AM
    #72
    May delivery
  13. Mar 13, 2022 at 11:11 AM
    #73
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Thank you! Been checking and they've all been scalped ones lately. Just placed the order - with prime it arrives May 5-8, so quite an advance order.
    odin1701[QUOTED] likes this.
  14. Mar 13, 2022 at 5:48 PM
    #74
    Bentarm13
    Bentarm13 New Member
    ordered my second for the wife’s charger
  15. Apr 15, 2022 at 10:30 AM
    #75
    Bentarm13
    Tundra, can you walk me through your settings please? Mine works, but I have some bugs with it, IE: on start up, everything shows on the screen after about 15s but I have to power off\on the radio, then it’s fine. Any alerts will cause the same thing, driving directions, etc will cut the audio and I have to power on\off. I’ve had to mute google maps and not allow notifications in Android auto. I have mine plugged into the USB normally used physically connect the phone (closest to the driver) the other 2 my phone says connected but nothing happens on the HU.
  16. Apr 15, 2022 at 10:39 AM
    #76
    odin1701
    odin1701 New Member
    Are you going into AA on the HU? It doesn't go into it automatically for me, it just shows the normal home screen with the Toyota Nav and Audio/Phone Number split screen thing. Is this what you mean?
    I haven't had any issues with my unit connecting and doing what it should. It will automatically start up the audio from my phone and it will say the source as AA there. But if I want actual apps like Google Maps, I have to go into AA on the HU specifically.
  17. Apr 15, 2022 at 10:42 AM
    #77
    Bentarm13
    When I start my vehicle, within 15 second AA starts on my screen perfectly, I just can't get audio until I manually power off/on the HU. Make sure in your AA settings to check automatically start when connected.
  18. Apr 15, 2022 at 11:06 AM
    #78
    odin1701
    odin1701 New Member
    Yeah it's starts up automatically and connects and all, it just doesn't change the screen from the default. I don't have any issues with audio coming through at all.
  19. Apr 15, 2022 at 11:18 AM
    #79
    Bentarm13
    Try a different USB. If you have 3, the closest to the driver
  20. Apr 15, 2022 at 11:28 AM
    #80
    odin1701
    odin1701 New Member
    I'm not using USB exactly, I'm using the Motorola Wireless AA adapter. It is plugged into the only port that does AA.
  21. Apr 18, 2022 at 7:55 AM
    #81
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Will this gadget cure my Wireless Android Auto woes?
    On the Kenwood DMX1057 there is Android Auto but it must be manually started from the head unit after each startup. After a shutdown the system goes back to Idle mode and 'forgets' you had left it running. Apparently this is by design from Kenwood.
    Not sure if have this 'wired' (yet wireless) device would fix that issue.
  22. Apr 18, 2022 at 7:58 AM
    #82
    odin1701
    odin1701 New Member
    Doesn't sound like this would fix the Kenwood issue. It would just make it so you don't have to plug your phone in.
  23. Apr 18, 2022 at 10:51 AM
    #83
    BrakeDust
    Hill Country, TX
    I already don't need to plug in my phone - the DMX is wireless. I _may_ also plug in my phone and if I do that, AA resume playing my music after I restart the car - just what I want.
    So what I'm wondering is whether this wireless AA dongles makes the phone appear to be 'wired'.
  24. Apr 18, 2022 at 10:53 AM
    #84
    odin1701
    odin1701 New Member
    It is meant to convert the standard "wired" AA to wireless. I'm not sure how it would interact with a HU that is already capable of wireless AA. So if your HU seems to do what you want when you plug your phone in, but not when connected wirelessly, it might work.
  25. Apr 18, 2022 at 11:51 AM
    #85
    Mine is used with an aftermarket Pioneer so the settings might be different?
  26. Jun 10, 2022 at 3:36 PM
    #86
    Currently available to order on Amazon for $89. Estimated delivery June 30th.....move fast!
    bulldog93 likes this.
  27. Jun 10, 2022 at 4:45 PM
    #87
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Thanks. I was finally able to order one.
  28. Jun 13, 2022 at 9:48 AM
    #88
    Currently available on Amazon again after being unavailable over the weekend.
  29. Jun 14, 2022 at 9:55 AM
    #89
    Mine just arrived a week early. :thumbsup:
  30. Jun 16, 2022 at 4:53 PM
    #90
    Bentarm13
    Alright folks, help me with your settings. I have pixel 6 pro. Within 30 seconds in connects to the head unit but does not automatically play . I have to shuffle to get to Auto. If I have voice activated on Google maps, it pauses the entire Auto system and I have to cycle back to it. I've shut off all voice prompts it's become so annoying.
