Driver side wiper issue above 60 mph
Discussion in '2nd Gen Tundras (2007-2013)' started by primeiro, Feb 13, 2020.
  1. Feb 13, 2020 at 12:53 PM
    primeiro
    primeiro [OP] New Member
    Henk
    Netherlands
    just a question guys
    when i drive 60 - 70 mph the damn wiper of the driver side aint working correctly when raining
    its like wind is going under it, up goes oke just not down, i have tryed multiple
    wipers and none of them work like it should, i have try to find spoilers for it
    but also none of them work with the oem wiper, could it be that the wiper arm spring aint good anymore ?
    let me hear your thoughts about it
    thnx all
    Rex Kramer likes this.
  2. Feb 13, 2020 at 12:58 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So blades replaced yet the same underlying arm/spring? Perhaps replace the spring?
    15whtrd likes this.
  3. Feb 13, 2020 at 12:58 PM
    15whtrd
    15whtrd Mr. Blonde
    Trying to understand what you’re talking about. Does the driver side gets stuck in the up position? Or is it just lifting off the glass at speed on the down stroke? If it’s the latter, maybe this spring is all stretched out and time for a new arm.
    NewImprovedRon likes this.
  4. Feb 13, 2020 at 1:00 PM
    primeiro
    Henk
    Netherlands
    it does not get stuck , its just the uplifting off the glass, thnx for saying that in a corect way :)
    15whtrd likes this.
  5. Feb 13, 2020 at 1:07 PM
    15whtrd
    15whtrd Mr. Blonde
    I’d say your next step should be either trying to replace that spring or the entire arm. Unsure of where you live, but I know in some climates people like to lift their wipers up when they park at night so they don’t get stuck/frozen to the window and ruin the blade. Is it possible this happened with your truck and the spring is just blown out?
  6. Feb 13, 2020 at 2:08 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Those springs are really stout so I would guess that this would be the only way they would weaken.
    15whtrd[QUOTED] likes this.
  7. Feb 13, 2020 at 2:18 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    May have a bad or rusted wiper spring
  8. Feb 13, 2020 at 9:54 PM
    primeiro
    Henk
    Netherlands
    going to order the spring , i live in the netherlands btw, a shit load of rain here always
    does anyone have a link where i can order the spring or arm ?
  9. Feb 14, 2020 at 10:38 AM
    15whtrd
    15whtrd Mr. Blonde
    https://parts.toyotaofcoolsprings.com/
  10. Feb 14, 2020 at 10:50 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    Swap the left/right arms to see if that changes the behavior. You'll probably want to swap the blades too as they're different lengths.
  11. Feb 15, 2020 at 1:56 AM
    primeiro
    Henk
    Netherlands
    thnx never thought of that , going to try it today
  12. Feb 15, 2020 at 3:35 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My drivers side blade does the same thing, it lifts & skips when wiping down.
    This happens at speeds above 40 mph, and it sucks.
    It's not the blade, so it is one of 2 or 3 possibilities.
    1. I re-installed the arm incorrectly when I removed it to apply paint.
    2. The spring is worn out.
    3. The arm & spring are worn out.
  13. Feb 15, 2020 at 4:15 AM
    primeiro
    Henk
    Netherlands
    thats exactly whats going on
  14. Feb 15, 2020 at 5:17 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Before you get too far along, check the arms for a "D" or a "P" molded/cast into them, they may actually be side specific.
  15. Feb 15, 2020 at 8:08 AM
    primeiro
    Henk
    Netherlands
    hey are :(
  16. Feb 15, 2020 at 9:33 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I suppose that you'll have to experiment a bit to determine which component is not performing up to standard. Frustrating and time consuming, but sometimes that's what's required.
    15whtrd likes this.
  17. Feb 15, 2020 at 11:30 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    maybe try a wiper that has a wider footprint with a lip? Might create enough down force to keep the wiper down...Not sure how wide the rain-x latitude is just by looking at pictures but maybe something like that?
  18. Feb 15, 2020 at 11:36 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
  19. Feb 15, 2020 at 1:18 PM
    primeiro
    Henk
    Netherlands
  20. Feb 15, 2020 at 2:07 PM
    Rex Kramer
    Georgia
    It is a warm sunny afternoon here, so I did some investigating.
    The portion of the arm with the bolt hole in it appears to be made out of Aluminum, and mine has worn down in a few places, enough that there is play even with the wiper arm nut tight. I placed an order for a new arm 85221-0C020, and hopefully that will solve my problem.
    Mine are marked D and P
  21. Feb 15, 2020 at 2:23 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    ^there you go, thats likely the culprit.
  22. Feb 16, 2020 at 12:04 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Looks like no teeth left, just gums. :p
  23. Feb 22, 2020 at 3:03 PM
    Rex Kramer
    Georgia
    I installed the new wiper arm this afternoon... the grooves you see in the pictures above are not present on the new arm, the post it's installed on actually cuts the grooves as you tighten the securing nut.
    More rain is forecast to begin tomorrow night and stick around until Wednesday night, so I should know if this solved my problem pretty soon.
    I suppose one could press an aluminum ring of some kind into the worn out bolt hole and keep it going for another couple 100 thousand miles.
  24. Feb 23, 2020 at 5:57 AM
    primeiro
    Henk
    Netherlands
    i'm getting the new ones next week , i hope also this fixes my problem with it
    if not then i'm going to weld some spoilers on the arm
  25. Feb 23, 2020 at 8:27 AM
    Dr_Al
    Dr_Al New Member
    Al
    Do a search for wiper arm spoiler. They mount to the arm and use the force of the wind to push the wiper down onto the windshield. Over here I would just search ebay and probably find a ton of Chinese companies that sell them. It could be the same over there. Hopefully the replacements fix the problem but if not a spoiler could be the solution.
  26. Feb 23, 2020 at 8:31 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that you could probably find some plastic clip on ones that should work for a price less than the cost of the electricity that you'd use to try to do any welding.
  27. Feb 23, 2020 at 9:07 AM
    Rex Kramer
    Georgia
    The reviews I read on the spoilers were pathetic.
    Wynnded likes this.
  28. Feb 23, 2020 at 9:15 AM
    Rex Kramer
    Georgia
    Tip:
    If you don't ever remove your wiper arm from it's post, you probably won't have this issue. The problem did not start on my truck until after I removed the arm to paint it, and seeing how the new arm installs it makes perfect sense that this would happen.
  29. Feb 23, 2020 at 9:20 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Windshield replacement could bring this to a person's attention.
    P-Factor and Rex Kramer[QUOTED] like this.
  30. Feb 23, 2020 at 9:23 AM
    Rex Kramer
    Georgia
    True, and I no idea how many windshields this truck has gone through.
