Winter is here, Auto LSD is too!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by FrostyTundra22, Nov 17, 2022.
  1. Nov 19, 2022 at 7:37 PM
    #61
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I take it back, i just pulled out my manual and according to it the gentleman in that video is incorrect
    Tripleconpanna likes this.
  2. Nov 19, 2022 at 7:46 PM
    #62
    NDTundra18
    NDTundra18 New Member
    Andrew
    Fargo, ND
    2021 SR5 MGM CM
    As always, lots of opinions. Seemed to work very well for me engaging it when on icy inclines this week. I didn’t run it full time but I will say for the few spots I engaged it I found it to be more effective than just 2WD.
    Good enough for getting onto the interstate without 4hi and helping around town satisfies me.
    FrostyTundra22[OP] likes this.
  3. Nov 21, 2022 at 6:36 AM
    #63
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    Can Auto LSD be used in 4hi? Reading through the manual above it seems to be for 2wd only
  4. Nov 21, 2022 at 6:51 AM
    #64
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Which oil should I use in my AutoLSD? Do I need to add friction modifier?
  5. Nov 21, 2022 at 6:53 AM
    #65
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Whatever you use it has to be signed.
    JLS in WA and hagrid[QUOTED] like this.
  6. Nov 21, 2022 at 7:28 AM
    #66
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I ended up installing a real mechanical LSD in both my 2010 and just got my 2017 back with a Powertrax LSD. The Open diff with the auto LSD is piss poor. It’s also only intended to be used as a low speed traction aid. For it to even properly engage you have to keep the RPMs hovering in the 1600-1800 rpm range and as it senses the slip it will then start braking the slipping wheel. It is not a high speed traction aid, it won’t do anything but allow the slipping wheel to spin for a longer period before cutting in with the intrusive traction control.
    A true mechanical LSD is what these trucks need and should have gotten from the factory. It makes it so much more enjoyable on slippery road surfaces, from taking off in the rain to snow covered roads. It’s an upgrade I’d suggest to anybody.
  7. Nov 21, 2022 at 8:04 AM
    #67
    clarkritchie
    clarkritchie New Member
    My $0.02, but the Auto LSD generally works well for me when the normal traction control does not. Over the last 2-3 weeks, I've had to drive up and over a little north-facing hill that's been icy most mornings. Lots of slipping with the normal traction controls on, and Auto LSD has had no issues. Duratrac tires and not in 4WD.
  8. Nov 21, 2022 at 8:19 AM
    #68
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    I have Auto LSD on my '05, as well as good tires. Works great in the snow.
  9. Nov 21, 2022 at 8:49 AM
    #69
    FrostyTundra22
    FrostyTundra22 [OP] No longer new member
    2020 Toyota Tundra 1794 Crewmax
    This has been my experience as well
  10. Nov 21, 2022 at 8:51 AM
    #70
    FrostyTundra22
    can you use the same traction button to enable the true lsd once installed?
  11. Nov 21, 2022 at 8:59 AM
    #71
    Silver17
    Eastern PA
    The true LSD is purely mechanical and will transfer power automatically when one wheel slips. You can use it in conjunction with Auto LSD if you wanted which should greater aid traction in low speed situations than just either one working by itself.
  12. Nov 21, 2022 at 3:38 PM
    #72
    Joe333x
    Joe333x Member
    Boston
    No, 2wd only.
    TundraTed[QUOTED] likes this.
  13. Nov 22, 2022 at 10:47 PM
    #73
    FrostyTundra22
    Good to know we have options. Wondering if there is 4auto option that we can add? Like in the Chevy’s?
  14. Nov 22, 2022 at 11:07 PM
    #74
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'd bet you could find a Chevy guy willing to trade w/you :notsure:
  15. Nov 23, 2022 at 6:33 AM
    #75
    FrostyTundra22
  16. May 8, 2023 at 12:06 PM
    #76
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    "push this button if you want to drift"
    no, wait, for that I have to hold the button for 5 seconds....
    don't listen to my advice, I don't know what I am talking about, but I do like to do doughnuts in the snow, and I know what buttons to push for that!!
    this is an interesting thread!
