Winter driving!.... or... Winter driving?
Discussion in '2.5 Gen Tundras (2014-2021)' started by panicman, Nov 16, 2018.
  1. Nov 16, 2018 at 7:52 AM
    panicman
    panicman [OP] Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    newb question-
    This will be my first winter with my 18 tundra. Mostly I drive around the outskirts of Portland, so occasional snow and ice, some hills, etc...
    but I will probably go up Mt Hood, and I will drive around the state a bit for the holidays.
    Am I likely to need chains? I assume that with the Tundra’s 4WD I’ll be ok on decent tires. But, I don’t want to risk getting stranded or in an unnecessary fender benders.
    I am a reformed sedan driver, so I am very used to carrying chains and having snow tires if I needed them.
  2. Nov 16, 2018 at 8:00 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  3. Nov 16, 2018 at 8:05 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    As you know, ice is the big problem here in the Portland area, and the stock Michelins don't do too great in the ice. If you have to drive in the ice I would either get some chains or some winter tires. When we got that mini storm last Christmas Eve I had to do some driving and it definitely got a little slippery, even in 4x4.
    jewsNbrews likes this.
  4. Nov 16, 2018 at 8:07 AM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    You shouldn't need chains. 4WD with good AT tires is plenty.
  5. Nov 16, 2018 at 8:18 AM
    RustyPNW
    RustyPNW New Member
    Oregon
    2018 Cement Tundra SR5 CM TRD
    5100 middle setting, stock rears
    I've been up Mt. Hood in my Tundra, specifically hard pack snow up to Timberline Road. No issues whatsoever, driving slow and cautious is key. Road crews do a fairly good job keeping that area sanded and plowed.
  6. Nov 16, 2018 at 9:59 AM
    15whtrd
    15whtrd Mr. Blonde
    I have not needed chains yet. But I have them just in case. You know the saying. Better to have.....
  7. Nov 16, 2018 at 10:03 AM
    Outbound
    Aaron
    Northern Alberta
    Between 4x4 and studded Nokian Hakkapellita tires I figure I could drive up a frozen waterfall. :D
  8. Nov 16, 2018 at 11:12 AM
    Rex Kramer
    Georgia
    Black ice is the absolute worst for getting around during the winter.
    ColoradoTJ likes this.
  9. Nov 16, 2018 at 11:15 AM
    18Cement
    18Cement New Member
    Olympic Valley, CA
    2018 Cement Tundra Limited
    5100's on all fours Icon rear leaf Fuel Vector 20" Nitto Ridge Grapplers 305/55/R20 Leer Shell
    I'm in Tahoe. Live on a steep street. I just got my studded snow tires put on today. Now let it snow.
    TheBeast likes this.
  10. Nov 16, 2018 at 11:20 AM
    panicman
    Eric
    Sounds like cables will get the job done, and I think snow tires would be overkill for my locale.
    Thank you all for the input!!
    And always good to get extra advice from Mike!
    15whtrd likes this.
  11. Nov 16, 2018 at 11:33 AM
    goffredo
    goffredo Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    I live in an area that gets an average of about 450" of snow a year, usually as multiday dumps of 2-6 feet, 5-6 times a winter. My BFG AT tires do great in deep fresh powder, I have no need for chains nor studs.
    After a storm, the roads turn to hard packed ice from the endless hoards of people driving on them with chains up to the ski hills, and the ATs do fine on these as well, though I do keep two 60-pound sand bags over each rear wheel (240# total) otherwise I find the back end can slide out. Due to the nature of our climate here, this ice tends to melt away after a few days and the roads clear up.
    The only reason I would get studs is if I was regularly exposed to a sketchy icy hill. For example, living up a sketch driveway, or working at an area that a sketchy hill. By sketchy, I mean, steep enough to lose traction driving down. I can usually negotiate these just fine by crawling and my ATs have enough grip, but if I had to do it twice a day, the odds are very high that I'd lose out against the friction war, and end up in the ditch.
    When I lived in Fargo, the streets were wind-polished ice. Even though there were no hills, studded tires (and block heaters) were a must -- again, because of regular exposure to super icy conditions. When I lived in the Burlington / Montréal area, freezing rain and ice storms were somewhat common due to the proximity of cold arctic fronts meeting with humid storms rolling up the east coast -- the classic nor'easter -- and I simply didn't drive anywhere after an ice storm. I mean, I couldn't even walk out my front door to my truck.
    In summary, as someone who has lived in extremely snowy climates most of his life, I would say, ATs are probably fine, unless you live or work on a super icy hill, in which case you might look into studs. Regardless, I highly recommend putting sand bags in the bed over your rear wheels in the winter. I don't carry chains -- I carry a shovel and an overnight kit. If conditions are bad enough to warrant full R3 chains (mandatory chains on all wheels), I pull over and park. It's simply too dangerous to be driving in those conditions, sometimes you have to be humbled and let nature do its thing.
    Here's my Taco with 33" BFG ATs doing just fine after a little dump.
  12. Nov 16, 2018 at 7:25 PM
    panicman
    Eric
    Thanks Goffredo- cool picture!
    I don’t think I’ll see any snow like that!!
    Mountun Goat likes this.
  13. Nov 16, 2018 at 7:27 PM
    Mother Nature house insulation...
    Boosted4runner and Mountun Goat like this.
  14. Nov 16, 2018 at 7:38 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    :eek2:Wtf!! Cool!!
    Boosted4runner likes this.
  15. Nov 16, 2018 at 9:36 PM
    goffredo
    Yeah, except zero daylight through the windows is kind of a bummer! It's literally a cave.
  16. Nov 17, 2018 at 1:10 AM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Sweet post and killer picture!!
    OP - I’m local PDX (somewhat) as well - and it all depends on how comfortable you are in your vehicle - and your area.
    Every location is different and knowing your limits is the ticket.
    I knew the last 20 years in my 4runner, I’d tackle almost anything, as long as it wasn’t a 1/2 mile long ice-hill going downward. When Portland was shut-down for 9 days about 4 years back (known as the “snowpocalypse”), I was commuting no problem daily from Ridgefield to Portland. And I was moving waaaaay quicker than when traffic was normally bumper-to-bumper without snow.
    Heading up to Mt. Hood - if you’re not running Durratracs or “snowflake” rated tires, State Patrol will require you carry chains. And I’d recommend it. (Even though I ran a FWD Subaru up there for 8 years without great tires or chains).
    They’ll stop and check you nowadays.
    Juanjoolio007 likes this.
  17. Nov 17, 2018 at 1:15 AM
    Boosted4runner
    WA
    Oh, P.S. - you’re now in a 5,000 lb tank, not a 3,000 lb car. The level of stopping distance in almost every situation, is waaaaay different.
    Keep that in mind.
  18. Nov 17, 2018 at 3:48 AM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Yes you will be “required” to carry chains if you go over the pass or up to Mt Hood.
    If you didn’t know Les Schwab will sell you a set now and in like March or April refund you the money if you don’t use them.
    Going out on a limb here... you are not from Portland.
    This x 1000! I have 35’s. They only had chains when I went. I can’t remember the cost maybe $100-150. I was going to return them but got stuck on ice on Timberline road after stopping to offer to yank out a couple of those AWD Subaru WRX’s that we’re stuck in the ditch(on the wrong side of the road).
    I ended up using them because it was way cheaper and smarter to just own those chains for ever then to try and wait for someone with enough traction to pull me like 5 feet enough to get off that patch of ice.
    I didn’t quote that long post with the super cool picture.... but do this. Every time he mentions “super sketchy or super icy” insert Portland. If that doesn’t convince you I don’t know what will.
    Congrats on the Tundra and Welcome from Sherwood.
    15whtrd[QUOTED] likes this.
  19. Nov 17, 2018 at 3:56 AM
    Juanjoolio007
    Oregon
    Oh one last saved round...your 4wd won’t engage if your front tires don’t have traction. So if your say heading to Timberline and you turn off 26 and it’s clear but 2 miles up the road it’s icy switch it before you think you need it. Your 4wd light will just flash at you other wise.
    NewImprovedRon and 15whtrd like this.
  20. Nov 17, 2018 at 8:46 AM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    No I live in the midwest where we get more snow and ice than Portland. I use to live in Vancouver, WA and know about the weather in your area.
  21. Nov 17, 2018 at 10:27 AM
    Juanjoolio007
    Oregon
    It’s not just the weather. Though since you are familiar with the area and it’s “micro climates” or whatever the heck it’s called then you know that the conditions change or can change every couple of miles even on the same road in town.
    It’s a two part problem and it’s the people you have to watch out for too. I doubt as a whole Portland is improving and a few years ago we were rated 47 out of 50 of the worst cities to drive in or drivers which ever it was. 50 being the worst.
    So I carry them(only used once) just in case cause you never know what’s going to happen.
    KMG[QUOTED] likes this.
