Winjet Tail Lights
Discussion in 'Lighting' started by scurdyness, Jan 12, 2017.
  1. Jan 12, 2017 at 5:21 PM
    scurdyness
    scurdyness [OP] One thing is sure, uncertainty is certain
    William
    Fort Smith, AR
    2017 MBM Platinum_BlackOps
    TRD CAI, TRD Dual Exhaust, TRD rear sway bar, TRD shift knob, T-Rex Sport grilles upper and lower, full window tint and brow, de-chromed, powder coat OEM wheels, blue LED interior, Winjet Tails, Retrofit headlights
    So, digging through Craigslist a few days ago, I came upon a set of Winjet Tails in Black/Smoke for a 2014-2017 Tundra.
    Seemed like a good deal, so I jumped on them.
    However, despite being "brand new", etc the driver side blinker is defective...
    Is this fixable (i can apply 12V in my shop across the contacts and get illumination, but when wired to the truck...NADA) or do I sentence them to the dumpster and move on?
    Thanks folks
  2. Jan 12, 2017 at 5:28 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I don't know if it's fixable or not, but I have the exact same tail lights and have had zero problems with them. I actually like the way they look alot more than Spyders, although Spyders are also nice. I haven't experienced any moisture intrusion whatsoever, and I wash my truck often on top of it being a really, really wet winter here.
    I would do a bit of troubleshooting - If you have a multimeter check the post that provides an interrupted signal to the turn signal. If you don't just plug in the opposite tail light and see if it functions properly. I'd go as far as separating the assembly before I tossed them.. Good luck man, I know this wasn't much help. =\
  3. Jan 12, 2017 at 5:32 PM
    scurdyness
    William
    Fort Smith, AR
    Mike,
    I tried this already, and same result. I thought that maybe the LED bank was faulty but 12v across the pins illuminated them. I do not get the fast blink warning either, which would indicate that the resistor is faulty? back to stock lights and NO problems, oh my.....
  4. Jan 12, 2017 at 5:36 PM
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    Is it possible the input is reversed? IE providing power to the ground on the LED Panel, and Ground to the Power side?
  5. Jan 12, 2017 at 5:42 PM
    scurdyness
    William
    Fort Smith, AR
    Good point, I also tried that (removing the plug and reversing the LED plug-in inside the housing ), polarity was the first thing I checked...to no avail.....gggrrrrrrr
    Contacts appear to be good too, 12V across the pins = lights on???...BUT not on the truck
  6. Jan 12, 2017 at 5:57 PM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    2016 CrewMax TRD PRO
    I wouldn't waste any more of your very valuable time one them. Send them to me. : )
  7. Jan 12, 2017 at 7:31 PM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    Check all fuses? Use test light to confirm signal throughout the wire past plug on both truck and light side of connector?
  8. Jan 12, 2017 at 7:35 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Hmmm. . Don't toss them, there has to be a way to figure it out. If they light up with power they still work, is the truck sending power or did a fuse blow during installation or something?
    NewImprovedRon likes this.
  9. Jan 12, 2017 at 7:37 PM
    scurdyness
    William
    Fort Smith, AR
    Yes sir, been there too.....:rolleyes:, same results......
    Just to clarify....signal from truck is OK (connected passenger side assembly to drivers side and no problems, did the same with the 'working Winjet'.
    Stock lights refitted back onto truck and no problems.
    LED's appear OK and all lit with a 12V shop supply.
    I am bamboozled....
  10. Jan 12, 2017 at 7:43 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That's weird. I wonder if WinJet has good customer service.
    Did you try the driver's side (faulty tail) on the passenger side of the truck to see if it would work?
  11. Jan 12, 2017 at 7:45 PM
    scurdyness
    William
    Fort Smith, AR
    Yes, and it's all good...EXCEPT the blinker....
  12. Jan 12, 2017 at 7:51 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    Could be a ground issue for what ever reason within the light. When you put 12V across, I'm assuming the ground and power are direct from the power source? Take 2 jumper wires and jumper power to power from the harness and the second manual ground from chassis to ground on light plug.
    I know it sounds weird... but I've seen some of the factory LED lights on our work trucks have ground issues on the utility beds.
    If no luck, it's got to be a wiring mistake within the light...
    NewImprovedRon and MotoTundra like this.
  13. Jan 12, 2017 at 7:52 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Sorry I had a long day. So weird, it doesn't seem to make any sense.
    Good point @Midnighttaco08 .
    Good luck. I wonder if you could separate the tails, remove the LED diffuser, and install a new LED strip where the original is?
    Midnighttaco08 likes this.
  14. Jan 12, 2017 at 7:55 PM
    scurdyness
    William
    Fort Smith, AR
    Thanks Sam, looks like I have a project for tomorrow?......getting outta my comfort zone with this though.....me + electrics = usually a big fat mess!!!
  15. Jan 12, 2017 at 8:01 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    :thumbsup:
  16. Jan 12, 2017 at 8:11 PM
    scurdyness
    William
    Fort Smith, AR
    Folks,
    I much appreciate your comments and suggestions so far, BUT...
    erm......OK, what is confusing me is......
    12V DC supply in my shop....red and black, as long as the polarity is correct, the LED's fully illuminate!!!!!!!
    I may be wrong here, but in the truck, turn signal on = alternating on/off power supply to the light bulb?
    I understand the resistor feature for turn signals when using LED (to fool the light controller; bulb out, etc), however, if the resistor/LED was faulty, then surely I would get an indication on the console...fast blink, to tell me a bulb was out???black
    It's a two pin plug with no ground?. red = + and black = -
    Oh my.......
  17. Jan 12, 2017 at 8:27 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    Yes you would. But my guess is, there could be a wire not connected within the circuit board on the light. (Possibly got disconnected during shipping or manufacturing and whatnot) LEDs require a circuit board and unlike the factory lighting, is a bit more complex.
    But... there's always that thought of "that's why they were on Craigslist" type of thing :anonymous:
  18. Jan 12, 2017 at 8:39 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    Well if you want to make some money back, I just need one of the housing
  19. Jan 14, 2017 at 11:43 AM
    scurdyness
    William
    Fort Smith, AR
    FIXED!!!!!
    After much head scratching and gnashing of teeth......there was a loose connection (LED harness) on the blinker plug inside the light body. When I locked in the connector it was working loose. A little manipulation with a flat blade driver squeezed the connector closed.....wohoooo......
    Perseverance DOES pay dividends!
  20. Jan 14, 2017 at 12:04 PM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    Looks good!
    scurdyness[OP] likes this.
  21. Jan 14, 2017 at 12:12 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    :thumbsup:
  22. Jan 14, 2017 at 12:44 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice! They look great!
  23. Jan 14, 2017 at 8:31 PM
    joeguam
    joeguam New Member
    JOE
    Glad you have it working
  24. Jan 14, 2017 at 8:40 PM
    TheBeast The Beach
    looks clean !
  25. Jan 14, 2017 at 8:54 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Glad to see you were able to figure it out. I've go the same ones. The stock red lenses just stood out against the black a little too much for me. These look like they belong.
  26. Jan 14, 2017 at 8:58 PM
    scurdyness
    William
    Fort Smith, AR
    Thanks guys, yip. IMHO, they "illuminate" the truck's ass....;)
    thumper7799 and 831Tun like this.
  27. Jan 14, 2017 at 10:26 PM
    scurdyness
    William
    Fort Smith, AR
    Blend?
  28. Jan 14, 2017 at 10:51 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I like the black 4x4.
  29. Jan 14, 2017 at 10:56 PM
    scurdyness
    William
    Fort Smith, AR
    I wanted to keep the badges, how weird am I?...colour matched MBM, would have saved me mucho dinero to rip em off...BUT, it's all about what I want, right? :jellydance:
    Maybe I need to address the cracks in my driveway though, nice and shiny is like a mirror, oops!
  30. Jan 15, 2017 at 8:47 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    The tail lights look good William! Those are the same ones I've been contemplating on getting for mine. Do they seem bright enough at night?
