Windshield washers pluging with Snow
Discussion in '2.5 Gen Tundras (2014-2021)' started by DCLarston13, Jan 18, 2023.
  1. Jan 18, 2023 at 2:36 PM
    DCLarston13
    DCLarston13 [OP] New Member
    2020 Tundra Magnetic Gray TSS
    The windshield washer nozzles on my 2020 SR5 kept plugging during a snow storm. It looks an issue that is likely to reoccur due to the placement of the nozzles. Are there any solutions to this?
  2. Jan 18, 2023 at 2:47 PM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Are you sure the tips are not getting frozen?
    Rocko9999 likes this.
  3. Jan 18, 2023 at 5:17 PM
    Rocko9999
    Rocko9999 New Member
    Need to use anti-freeze washer fluid.
  4. Jan 18, 2023 at 6:06 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Use the purple -30° windshield washer fluid at Walmart...it duals as another way to wipe ice off in the morning too!! There's also a one-way check valve that leaves fluid in the tubes for instant window juice...I always had mine freezing up while moving too despite the purple juice...I swapped it for a regular tee-fitting and the fluid drains back into the tank in the engine compartment, stays more warm and now works when I need it. There is only a couple second delay to when the juice squirts on the windshield which is a better tradeoff...for me at least...
    Rocko9999 and NewImprovedRon like this.
  5. Jan 18, 2023 at 7:47 PM
    adamha
    adamha New Member
    You just solved a mystery for me and freezing washer fluid despite purple fluid. T-fitting coming shortly.
    HulkSmurf14[QUOTED] likes this.
  6. Jan 19, 2023 at 5:49 AM
    DCLarston13
    The blue stuff was in there, good to -20?? The purple stuff and removing the check valve is probably the way to go. For the record the nozzles were clogged/frozen before I left but I let the truck run and warm up then they thawed out. They worked ok for a bit, but as it got colder and snowed, more they would clog up. Basically the snow was piling up in front of the windshield blocking the fluids path to the windshield.
  7. Jan 19, 2023 at 6:34 AM
    adamha
    adamha New Member
    Thanks for the info as it confirms I'm not losing my mind. I have had frozen over nozzles in the past but never line frozen. I had this issue going over Teton pass into Jackson a couple weeks ago and it really sucked.
    HulkSmurf14 likes this.
  8. Jan 19, 2023 at 6:37 AM
    Ericsopa
    Ericsopa Old man and the sea
    Or just use your regular washer fluid and add a quart of 90% isopropyl alcohol.
  9. Jan 19, 2023 at 6:40 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Never happened to me. Even at 25 below
  10. Jan 19, 2023 at 10:54 AM
    RCwyoming
    RC
    Add some rubbing alcohol
