Windshield washer not spraying
Discussion in 'General Tundra Discussion' started by Capt._Ian, Jun 17, 2019.
  1. Jun 17, 2019 at 11:17 PM
    Capt._Ian
    Capt._Ian [OP] New Member
    Ian
    2017 Tundra SR5
    K&N cold air intake, true dual flowmaster super 10 exhaust turn downs
    Looking for some help. My washer pump will not work. I used to have my bulldog connected to the washer fuse and now it won't spray at all. A few times the wipers would just randomly go off. I've since moved the bully dog wire. I've checked the fuse under the dash. And changed the pump in the reservoir and still nothing. Anyone else have any ideas would be helpful. Thanks
  2. Jun 18, 2019 at 3:36 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Is a hose off or broken?
    OR18TRD likes this.
  3. Jun 18, 2019 at 3:44 AM
    Capt._Ian
    Ian
    2017 Tundra SR5
    No I hit the lever in the cab and the wipers go off but no fluid anywhere
  4. Jun 18, 2019 at 4:11 AM
    Sure a line isn’t pinched?
  5. Jun 18, 2019 at 6:03 AM
    Capt._Ian
    Ian
    2017 Tundra SR5
    Update: I feel like a fool swapped fuses still nothing. Disconnected the hose had my wife pull it still nothing. After much frustration and heeding the advice of OR18TRD I went and got fresh new fuses and bam. Back in business. But this was the fuse I pulled out. Looked perfectly fine. Thanks guys for your help
  6. Jun 18, 2019 at 6:18 AM
    A handheld digital multimeter can be your friend when checking fuses among other things:thumbsup:
    NewImprovedRon and Capt._Ian[OP] like this.
  7. Jun 18, 2019 at 9:43 AM
    Capt._Ian
    Ian
    2017 Tundra SR5
    I put a light test on the pump wire and it didn't light up but the wipers still went off
  8. Jun 18, 2019 at 5:17 PM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Looks like the contacts are badly rusted/corroded from the picture. How did they get that corroded in a 2017?
    Tundyfundy likes this.
  9. Jun 19, 2019 at 12:35 AM
    Capt._Ian
    Ian
    2017 Tundra SR5
    Maybe it had something to do with the bullydog I had hooked up to it
  10. Jun 19, 2019 at 12:45 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Looks like you are using a 20amp fuse circuit. Does your bully dog have a separate fuse? Manufacturer says hook it up to a 10-15 amp circuit. Seems the higher fuse may not be allowing the fuse to work properly since it is no longer the weak link since it needs to be 10-15 amps max apparently.
    Which means it will overheat instead of blow the fuse. Hence black contacts on the fuse.
  11. Jun 19, 2019 at 1:06 AM
    Capt._Ian
    Ian
    2017 Tundra SR5
    No fuse when I hooked it up at first, I kind of Jerry rigged it. But I wanted it to come on automatically when the key turned so I went with the wiper fuse. I've since done it properly used and add a fuse and went to the cigarette plug fuse
    Tundyfundy and OR18TRD like this.
  12. Jun 19, 2019 at 1:14 AM
    Capt._Ian
    Ian
    2017 Tundra SR5
    Thanks. Yeah this is my first Toyota Tundra and that's specifically why I got on here was help with something new but little did I know all the money I would spend lol
    Tundyfundy and OR18TRD[QUOTED] like this.
