Wind Noise
Discussion in '1st Gen Tundras (2000-2006)' started by arlail76, Dec 19, 2020.
  1. Dec 19, 2020 at 12:57 PM
    arlail76
    arlail76 [OP] New Member
    Andrew
    Stock 2004 Toyota Tundra Double Cab 2WD
    So, I am revisiting this old post:
    https://youtu.be/vSGDhhIJ4rc
    I have a question...to stop the squealing noise, can I just get a bunch of caulk/sealant, and go around the windshield, or do I have to pull the windshield and get it “re-set”? Is it that or the trim mold on the sides of the window making the noise?
  2. Dec 19, 2020 at 1:37 PM
    Professional Hand Model
    Hand Protectors
    Whoa! The noise sounds annoying.
    Check my build page for pics of the side pillars. Might have something going on there. Never had any problems like yours, but noticed debris build up and some bad gaskets at each pillar when I had the Windshield replaced. When you see what I did it will make sense. Made my truck quiet down inside.
    There are also two rubber sponge type gaskets at the base of the pillars where they meet the hood hinges. I squared those up into shape, as well.
  3. Dec 19, 2020 at 1:48 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    First thing I would do is locate the source. There's air passing over something that's making it vibrate like a reed. My wife's Jeep GC did this and we were able to determine it was the cowl to windshield seal that was vibrating. I taped the cowl to windshield rubber seal and the vibration went away. You could try to tape the windshield seal and see if that eliminates the noise. Could even start with one side, and test drive it until you find exactly where the problem is.
  4. Dec 19, 2020 at 2:04 PM
    arlail76
    Andrew
    The video is not my vehicle, but mine makes the same sound around 70-75...especially when it is windy.
    I have taken the pillar molding off and I had to glue the rubber back to the metal. That didn’t help. I did discover one single spot where the windshield seal was bad on the passenger side pillar, about where if you looked in the window, you’d see the Climb in handle. I caulked there and I still have the noise. The noise sounds like it comes from right in front of me. My next plan was to take that cowl off where the wipers are, and check the seal there.
  5. Dec 19, 2020 at 2:08 PM
    arlail76
    Andrew
    Where is your build post?
  6. Dec 19, 2020 at 6:24 PM
    Hand Protectors
  7. Feb 10, 2021 at 5:54 AM
    arlail76
    Andrew
    So, I took some electrical tape and sealed the top piece of molding/rubber to the windshield and cab.
    I got all the way up to 90, and not a hint of noise.
    I was going to apply some sealant/caulk to the top of the window, then put the molding back, but good grief, that molding does not want to attach to anything, and I really would hate to take it off and then not be able to get it back on.
