Wind noise coming from passenger side dash area
Discussion in '2.5 Gen Tundras (2014-2021)' started by allybear21, Jun 24, 2017.
  1. Jun 24, 2017 at 6:23 AM
    allybear21
    allybear21 [OP] New Member
    Walker
    2017 Toyota Tundra 1794 Barcelona Red
    Just traded for a 2017 Tundra 1794. I have a wind noise coming from the passenger side dash area when traveling above 35 mph. I checked the cabin filter to make sure it was there and properly fitted. It sounds like there is an open hole somewhere in or near the glove box area. I've tried folding mirrors in, taking antenna off etc, but it is very annoying. Anyone else experience this issue and have any suggestions?
    Jsena likes this.
  2. Jun 24, 2017 at 7:55 AM
    Stig
    Stig New Member
    High pitched whistle?
  3. Jun 24, 2017 at 8:11 AM
    Put tape around the windshield and see if it stops.
    joonbug and Y0TA PR0 like this.
  4. Jun 24, 2017 at 8:13 AM
    allybear21
    Walker
    No, just wind sound like there is a hole not sealed somewhere. I adjusted the hood stops down. It looked like passenger side was much higher than drivers side. This seems to have helped quite a bit. Hard to tell because it's raining and roads are wet, but I think it's an improvement.
    I did notice the weatherstrip around the window on that side is a little loose. I will have dealer take a look at that too.
  5. Jun 24, 2017 at 9:12 AM
    claptrap
    claptrap New Member
    '16 TRD Pro
    one thing you may try is turning the climate system to circulate. That will eliminate air coming into the cab from outside through the vents. It may not solve your issue, but it's any easy thing to rule out
  6. Jun 24, 2017 at 10:08 AM
    allybear21
    Walker
    Well, thought I had it solved. Guess I'll have dealer take a look soon.
  7. Jun 24, 2017 at 10:57 AM
    lehminh
    lehminh New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    Did u check the firewall from the engine to under the glove box where the electrical wires are? Maybe there's a hole there
  8. Jun 24, 2017 at 11:05 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Most likely the weatherstrip on windshield needs to be replaced.
    GNTundra likes this.
  9. Jun 25, 2017 at 7:01 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Sounds like a dying whale..same here..is on the passenger windshield molding..rd have to curve to the left as you go into the turn and have to be a little windy outside..and there's a cross wind..is much louder at 75 mph..enough to put a skii Mark on your tidy whities if your not expecting it..
    Jsena likes this.
  10. Jun 25, 2017 at 1:45 PM
    mds808
    mds808 New Member
    2017 Platinum Tundra - Metalic Black
    I have the same thing going on.. sounds like I didnt roll up all the windows enough. Let us know what you find out from the dealer.
    Jsena likes this.
  11. Jun 25, 2017 at 1:50 PM
    allybear21
    Walker
    That's exactly what it sounds like. Like there is a hole somewhere right where top of dash meets window.
  12. Jun 27, 2017 at 2:08 PM
    allybear21
    Walker
    Took it in today and had mechanic ride with me a bit. He thinks the front windshield didn't get set properly so they are going to reinstall the windshield and put on new weather stripping all around. Hopefully, this will stop that wind noise.
    Jsena and ToyotaDreaming like this.
  13. Jun 29, 2017 at 7:06 AM
    Sooner77
    Sooner77 New Member
    Todd
    Tulsa, OK
    2017 Cement TRD PRO
    Predator Pro Step Bar, BackFlip MX4, XPEL Paint Protection Film, Husky X-ACT
    Mine has been at the dealer since Monday. Completed the bumper recall and 3rd time in for wind noise. Finally got them to agree that the passenger door didn't fit correctly around the roof line and down the front pillar. The dealer opened a case with Toyota for repair advise.
  14. Jun 29, 2017 at 8:34 AM
    allybear21
    Walker
    Wow, hope mine isn't that bad. That sounds like a lot to fix. What year is your truck? Mine was built in March of 2017.
    Jsena likes this.
  15. Jun 29, 2017 at 9:15 AM
    Sooner77
    Sooner77 New Member
    Todd
    Tulsa, OK
    2017 Cement TRD PRO
    Mine is a 2017 built in NOV. 2016. Still waiting to hear back from Toyota. Nothing noticeable to the eye but door defiantly doesn't fit up tight to the roof line or front pillar when compared to diver's door.
    Jsena likes this.
  16. Jun 29, 2017 at 10:56 AM
    xj2202009
    x
    Lutz, Fl
    I need to check mine then
    Jsena likes this.
  17. Jul 5, 2017 at 7:34 AM
    allybear21
    Walker
    Waiting on truck now. They said the front windshield was not even glued down on the passenger side. Not a sign of adhesive/epoxy on the entire right side of windshield. Almost like the robot that installed the windshield ran out of the adhesive on the passenger side. They called a windshield repair shop and are resetting the windshield. Kinda worrisome that this could get by quality control.
    NewImprovedRon likes this.
  18. Jul 5, 2017 at 11:45 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    just a tip...not sure it's been said before, but my wind noise from passenger side definitely comes from the antenna. removed the antenna, no more noise.
    Monkeyballs and Wynnded like this.
  19. Jul 7, 2017 at 11:06 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yea that was happening to me when I was driving home from Utah a few weeks ago.. I thought my window wasn't rolled all the way up so rolled it up n down, then moved mirrors around didn't help..'it was when I was going 75mph plus... I dont know what happened but it just stopped :notsure:
  20. Jul 7, 2017 at 11:14 AM
    allybear21
    Walker
    Mine is all fixed. Nice and quiet now. Truck is perfect!
    ColoradoTJ and Jsena like this.
  21. Jul 7, 2017 at 11:16 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What did they fix?
  22. Jul 7, 2017 at 11:17 AM
    Great to hear this.
    See what I did there?
    I figured it was the windshield. It actually happens a lot.
    Jsena likes this.
  23. Jul 7, 2017 at 12:27 PM
    allybear21
    Walker
    They had to reset the front windshield.
    Wynnded likes this.
  24. Jun 16, 2020 at 12:40 PM
    adrich89
    adrich89 New Member
    any luck, I recently purchase a 2017 Toyota Tundra and I am having the problem now.
  25. Jun 16, 2020 at 1:16 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Mine still does it , for some reason. It only does it on the highway going in and out of town. Never in the city. ¯\_(ツ)_/¯
  26. Jun 16, 2020 at 1:17 PM
    adrich89
    adrich89 New Member
    I see , and I guess their nothing we can do about it. I try calling Toyota and see if their was any recall , but no luck
    Jsena likes this.
  27. Jun 16, 2020 at 1:25 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I had a video of it so Toyota could hear it and they’d aid they didn’t know what to do.
  28. Jun 16, 2020 at 3:40 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Maybe this is why these trucks have such a noisy interior.
    Nowhere near as quiet as my 4Runners were/are.
    Figured it was just poor build quality, and even less aerodynamic shape.
    Maybe it's half installed windshields, and poor door sealing.
    Though with both issues, why don't we see any water intrusion, especially when driving in rain storms?
    Things that make you go hmmmm.....
  29. Jun 16, 2020 at 4:21 PM
    Monkeyballs
    Monkeyballs New Member
    Kelly
    2014 black platinum
    Lifted
    Same here!
