Winch, which one to take?
Discussion in 'Recovery & Gear' started by Beni36ti, Sep 2, 2018.
  1. Sep 2, 2018 at 1:44 AM
    Beni36ti
    Beni36ti [OP] New Member
    2017 SR5 CrewMax
    Dear all
    I would like to add a winch to my truck but have no experience in that field. I will get the slim bumper so the winch has to fit this part.
    Since our rigs normally are on the heavy side, I assume that one should better look at the 12k models, makes sense?
    Further on, what are the differences between the more low cost winches out there and the more expensive ones?
    Is a smitybuilt x20 winch something I should consider?
    Thank you for your help and input. Cheers from the old continent, Beni
    Y0TA PR0 likes this.
  2. Sep 2, 2018 at 1:56 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
  3. Sep 2, 2018 at 3:07 AM
    riley804
    riley804 New Member
    2018 toyota tundra
    I know its totally different, but when I used to ride sxs , I went through a few winches.....and then I tried Superwinch and they were probably the best one that I had. that thing would pull us out of some crazy holes. if something broke in it, you just call them up and they would send you the replacement parts for free. I would think that their truck winches would be the same.
    whatever winch you decide to get, I would go with the synthetic rope as you dont have to worry about the burrs that happen with the metal wire......plus the metal will kink up after a few uses. you can also get an extension of the synthetic rope and keep it in your truck and it wont take hardly any room.
    https://superwinch.com
    SoCal.Tundra.Guy, Sas and Tierhog like this.
  4. Sep 2, 2018 at 8:39 AM
    Beni36ti
    2017 SR5 CrewMax
    Thank you for your feedback
  5. Sep 2, 2018 at 9:01 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Had two superwinches and a hydraulic mile marker. Both were tough as nails. Warn started out outsourcing the budget line and the purists started defending them and the critics started bashing them. Warn is expensive, but avoid the cheap line.
    Superwinch is as easy as Riley mentioned.
    Sas likes this.
  6. Sep 4, 2018 at 8:12 AM
    zackbremer
    zackbremer New Member
    Da Z
    smittybuilt x20(10,00lb or 12.5) synthetic rope..had awesome luck
    Watt maker and Sas like this.
  7. Sep 4, 2018 at 8:17 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I would consider a Smitty with synthetic line. Protecting synthetic line from UV is a good idea.
    joonbug, Sas and GodlessPro like this.
  8. Sep 4, 2018 at 8:21 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Do you guys with synthetic lines wash them? I've read that sand, dirt and other particulates will break down the rope and compromise it over time.
    831Tun likes this.
  9. Sep 4, 2018 at 8:27 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You can wash synthetic line in your clothes washer, just put it in a mesh bag. Or use a 5 gal. bucket. If you use fabric softener it will make the line really nice and pliable. This is pretty commonly done on competition sail boats since salt crystals too break down the fibers. Even if you don't wash the line it will last a very long time. UV isn't good for synthetic line and it comes with a coating to inhibit UV. You can buy coatings like Samthane and paint it on to the line.
  10. Sep 4, 2018 at 8:30 AM
    Sas
    OKC, OK
    So when you wash it does it break down that UV coating as well?
    How often do you need to reapply UV protectant?
    831Tun[QUOTED] likes this.
  11. Sep 4, 2018 at 8:44 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, just like washing your clothes, washing causes a little wear but not much. Almost all single braid synthetic line comes with a hard wearing UV coating. For a winch line you'll probably never "need" to recoat unless you're opening it up for splicing the line. But if you see portions of the line turning white that would indicate the coating has worn off. Example: If you put a new hook on with an eye splice, you might wanna recoat the splice.
    joonbug and Sas[QUOTED] like this.
  12. Sep 4, 2018 at 8:50 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    another vote for superwinch. i have the talon 12.5i with synthetic line. also a huge fan of the gear from factor55.
  13. Sep 4, 2018 at 8:50 AM
    I've owned Warns and a Ramsey over the years. Very good winches historically. I've got a Smitty 10K X20 and quite pleased so far. 12K is a bit much but you can never have too much. I'm old school and prefer steel rope. Never had steel rope kink up on the spool. Steel rope usually kinks up when the rope isn't properly stretched/prepped before first use. Ask Hi Lead loggers what they use on their yarders. It's not synthetic. Synthetic rope is great for recovery situations and competitions but I'll take steel rope any day. Both options are good.
    Rbohno, ColoradoTJ, aperezsh and 4 others like this.
  14. Sep 4, 2018 at 8:50 AM
    Tierhog
    Tierhog SIG-AHOLIC
    I asked the tow truck guys about synthetic and they were enthusiastic about the lack of load if a line snaps, but didn't like the UV breakdown or abrasion resistance. Weight wasn't a factor for them. Now the tug guys and ocean going folks love them, 4wd guys are in the middle.. Depends on your priorities. I went steel. Lots of sun and rocks and mud in California. Never failed me. Never washed it or covered it.. Never sprayed it with sun protectant.
    NewImprovedRon and Sas like this.
  15. Oct 20, 2018 at 2:11 PM
    Mithrandir
    Mithrandir New Member
    mike
    2018 4x4 Tundra Color of Victorville Dirt
    I am a "Bunny Hill" kinda offroad enthusiast... are there any $450.00 winches for the rare occasions I might need a tug?
  16. Oct 20, 2018 at 3:43 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    20181016_081547.jpgAssembled properly, winch didn't fit in this slim bumper. Smittybilt 9,500lb X20 that's been submerged in water a few times, good customer service for replacement parts. This is the synthetic rope, previously had the steel cable which I snapped. I'm happy with the X20.
  17. Oct 20, 2018 at 5:29 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Unsure what kind of winch you're looking for but I paid less than $300 for mine.
  18. Oct 20, 2018 at 6:41 PM
    lc69hunter
    lc69hunter New Member
    Don
    2001 Black Tundra SR5
    gooseneck hitch, trailer brake
    This may get a few laughs, but Pirate 4X4 published a very extensive test on winches of different sizes, and different manufacturers. They, and many of us, were shocked that the Harbor Freight winches performed with the best of them.
    Gungho, Sas, ColoradoTJ and 3 others like this.
  19. Oct 20, 2018 at 7:52 PM
    Mithrandir
    mike
    Wow!!... a few hundy for a 12k winch! (Harbor Freight)
  20. Oct 20, 2018 at 8:07 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good to know!
  21. Oct 21, 2018 at 7:46 PM
    Mithrandir
    mike
    Would synthetic be an aramid or spectra fiber?
  22. Oct 21, 2018 at 8:40 PM
    COTundraRoamer
    COTundraRoamer New Member
    Dustin
    Denver, CO
    18' Platinum CM
    Fox 2.5 DSC front, Fox 2.5 DSC rear. JBA UCA. SCS Ray10 custom powder coated on 285/75r18 Duratracs.
    One important factor is the actual weight rating is based on the length of rope on the spool. The winch has maximum pulling power when on it's last layer. The more rope on the spool the less power you have for pulling. Also, a snatch block will double your pulling power but cut your line-in speed in half. Synthetic line has become super reliable and significantly safer (as well as repairable in the field). UV and abrasion are the biggest factor in it lasting. Finally, Slavin mentioned factor55. Closed system winching is far safer and much easier when you're alone.
    NewImprovedRon likes this.
  23. Nov 29, 2018 at 2:54 AM
    brimy311
    brimy311 New Member
    Kalamazoo
    2018 Tundra Platinum
    I ordered a Warn Zeon 10-s today for my truck. I’ve always said, no one regrets buying a Warn. I’ve used Warn on all my vehicles for the past 18 years!
  24. Dec 14, 2018 at 11:50 AM
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    Smitty Built x20 12k fantastic bang for your buck. 1k less than comparable Warn.
  25. Dec 14, 2018 at 12:31 PM
    Red_Leg
    Red_Leg New Member
    Will
    The Harbor Freight winch is a rebadged Smittybilt XRC winch.
    I ran a Warn on my last Tundra and run a Smittybilt X20 on my Jeep. I will probably run the X20 on my Tundra whenever I finally replace the bumper.
  26. Dec 14, 2018 at 12:32 PM
    Beni36ti
    2017 SR5 CrewMax
    I am about to pull the trigger for an SSO Slimline bumper and the Smitty x20 12k.
    Anyone with that setup who could let me know about fittment and the need for replacing the soleonid?
  27. Dec 17, 2018 at 12:02 PM
    Beni36ti
    2017 SR5 CrewMax
    No one here with that config?
  28. Dec 17, 2018 at 12:09 PM
    Sas
    OKC, OK
  29. Dec 17, 2018 at 12:25 PM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    I have the smitty x20 on a sdhq mount. I love the setup! I had to remote mount the control box for the winch and had plenty of lead to do so.
    Just make sure before you mount the x20 to replace the switch on the side of the control/solenoid box with a waterproof one. The smitty switch is not water proof... trust me.
  30. Dec 18, 2018 at 7:31 AM
    Beni36ti
    2017 SR5 CrewMax
    Thank you for the feedback.
    What do you mean by "sdhq mount"? Do I need other stuff to get the winch mounted to the slim bumper?
    Do you have a link to a waterproof switch you are referring to?
    Thank you, B.
