Will this tire size and spacer kit combo work with my stock wheels?
Discussion in '2.5 Gen Tundras (2014-2021)' started by bdalton88, Oct 26, 2016.
  1. Oct 26, 2016 at 12:22 PM
    bdalton88
    bdalton88 [OP] New Member
    Brad
    2015 White Tundra SR5 CrewMax 5.7 L V8 4x4
    Line X grill & bumpers/Westin ProTraxx 4" Oval Nerf Bars/Stampede RuffRiderz Fender Flares
    I currently have a 2015 Toyota Tundra Crew Max V8 5.7 L Gas 4 WD that has 255 70/R18. Will the stock wheels work with 305/65/18 nitto terra grappler and the rough country 2.5-3 in front leveling kit? I just don't want to waste my money on all this if it isn't going to fit or it is going to rub, also, if I can go bigger tire wise, how much bigger can I go and still fit the stock rims and no rub?
  2. Oct 26, 2016 at 12:53 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Check with Nitto to be sure, but I think 305s need at least an 8 1/2 wide rim. The stock rims are only 8 inches wide.
    Law323 likes this.
  3. Oct 26, 2016 at 1:07 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Need wheel spacers if you're going to run that wide of a tire.
    Also, don't get level spacers. At the very least, go with bilsteins.
    joonbug likes this.
  4. Oct 26, 2016 at 1:43 PM
    JMB
    Chesapeake, VA
    What he said. I added 295-70-18 tires, 5100s on the top setting and 1.25 spacers with the stock steel rims. No rubs except on the spat in front, which comes off with two screws.
    Law323[QUOTED] likes this.
