Will this tire and wheel package fit TRD Pro?
Discussion in 'Wheels & Tires' started by Stelly, Sep 5, 2015.
  1. Sep 5, 2015 at 2:00 PM
    Stelly
    Stelly [OP] New Member
    2016 TRD Pro, Crew Max, Metallic Gray
    TRD Rock Warrior 17" Wheels, BFG Tires 315/70/17 KO2's, 1.25" front spacers, TRD Intake, N-Fab BAJA Pro Bumper, Hella Lights, LED fog bulbs
    Hi Guys (& Gals), I'm new to this Forum, but I have gained a lot of knowledge. I'd post a picture of my truck but it has yet to arrive at the dealer. I'm first in line for the first 2016 Metallic Gray Crew Max Tundra TRD Pro at the dealer my credit union hooked me up with. Anyway, like most Pro owners and/or admirers, I'm really disliking the wheel and tire package from the factory, so it's going to be the first thing to go. I have two trains of thought here on options I like.
    First would be Fuel Trophy Wheels 18X9 w/20mm offset and 295/70R18's. I have seen on this forum that the tires fit, but on this rim package will they fit? Thoughts?
    Second would be to use TRD Beadlock 17" wheels and like a 285/70 tire, which I know should have no fitment problems, but the rims are way to much money I think.
    Any advise would be appreciated
  2. Sep 5, 2015 at 2:05 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Welcome to the site. I'm in for seeing your new truck! I'll let someone with a PRO answer the tire question.
  3. Sep 5, 2015 at 2:08 PM
    Welcome from CO. Ditto on waiting for Pro guys input.
  4. Sep 5, 2015 at 10:17 PM
    295/70/18. Bet if u just trim the front mudflaps you'll be good to go. Order from DT and test fit them.
  5. Sep 5, 2015 at 10:23 PM
    DT is having a real good sale now. Some decent rebates going on (after getting the price on top of that)
    SMSmitty and T-Rex266[QUOTED] like this.
  6. Sep 10, 2015 at 6:37 PM
    Stelly
    OK, I'm thinking outside the box here now. I really like the Toyo Open Country R/T, and I really like the idea of running 17" wheels like the trophy trucks. So now I'm thinking a 17x8.5 wheel, 0 offset, 295/70r17 tire. Tell me what you think, the offset is what has me worried.
    My truck is not due to arrive until mid/late November so I have plenty of time to second guess me decisions, which could be a bad thing
  7. Sep 10, 2015 at 7:06 PM
    Flobrandx
    Flobrandx New Member
    Brandon
    2015 TRD PRO
    Working on them now...
    Offset could be an issue
  8. Sep 11, 2015 at 7:17 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I know a lot of guys, run and like 17s, but I think these trucks look right with at least an 18x9 wheel. What about 1.25 inch wheel spacers and whatever larger tire you want to run? Just a thought.
    You may get by with the offset since it comes leveled from the factory... At least with the right size tire. An offset of +12 to +35 is usually the range where you won't run into much trouble leveled.
  9. Sep 11, 2015 at 7:48 PM
    TruckyTruck
    Gary
    No, the stock wheels are usually +60, +50 and sometimes +35. I'm not 100% sure on the pro wheels other than they are definetly a positive offset, but I believe they are +50. The lower the number in the positive offset range, the more they will stick out. After you reach a zero offset, the higher number in the negative range, the further they stick out. So +60 = tucked way under and -24. = sticking way out.
  10. Sep 11, 2015 at 7:56 PM
    Flobrandx
    Brandon
    2015 TRD PRO
    Ok thanks...I couldn't remember and got it backwards
    TruckyTruck likes this.
  11. Sep 11, 2015 at 7:58 PM
    TruckyTruck
    Gary
    It can get confusing
  12. Sep 11, 2015 at 8:00 PM
    Flobrandx
    Brandon
    2015 TRD PRO
    Yeah no kidding!
