Will they fit?
Discussion in '1st Gen Tundras (2000-2006)' started by Eugene406, Jun 12, 2019.
  1. Jun 12, 2019 at 5:22 PM
    Eugene406
    Eugene406 [OP] New Member
    Montana
    2002 Toyota Tundra SR5 TRD
    Bone Stock.
    Decided to go ahead and order some 285/75/16's General Grabber X3 for the Tundra. It is currently setup with 5100's in the front at the third setting, and no lift in the rear. I am planning on mounting the new tires on another set of stock Tundra OEM wheels.
    Did I get too ambitious and return them now? Should I order spacers before trying? Or am I good to go?
    Thanks in advance,
    Sorry for being absent recently.
    ick23 likes this.
  2. Jun 12, 2019 at 5:27 PM
    Professional Hand Model
    Hand Protectors
    I’ve had that same size tire for 16 years with stock height. Slight rub at full turn. No biggie. Just be aware going into tight parking spots to swing wide.
    Not sure of the Generals, but the Michelins barely rub. You’ll be fine.
    ick23 and Casper421 like this.
  3. Jun 12, 2019 at 5:28 PM
    Casper421
    In the woods
    06 DC
    Speak of the devil. I was just tagging you.
  4. Jun 12, 2019 at 5:34 PM
    Eugene406
    Montana
    Bone Stock.
    Thanks bud, I will report back when I get them mounted some time this week.
    In the meantime...
  5. Jun 12, 2019 at 7:58 PM
    TVU682
    TVU682 New Member
    Houston, Texas
    ‘06 Limited DC Tundra
    I’m running 285/75 Nitto Grapplers on mine with 2” spacers, rubbed a shit ton, I had to grind down part of the back inside wheel wells & a part of the front bumper, also had to remove the mud flaps... all & all, I’d do it all over again! Go for it!!!
    Black Wolf likes this.
  6. Jun 13, 2019 at 3:34 AM
    Hand Protectors
    These big nobby tires look bigger than their reported size.
    speedtre likes this.
  7. Jun 13, 2019 at 8:56 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The Michelin Defender in 285/75/16 is 32.8" in overall diameter and ships with 13.5/32nds of tread.
    The General Grabber he bought is showing the same overall diameter but with 18/32nds of tread depth.
    I may be misunderstanding how this works but I think he's are going to rub more than yours. He might be into the plastic while you just rub the frame. They are going to look great though!
    Bulldog_tundra likes this.
  8. Jun 13, 2019 at 10:46 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I ran Nitto Tera Grappler 285/75/16s on my 2002 Tundra and the only thing I ever rubbed that I noticed was the mud guards. Admittedly I never stuffed the wheels lock to lock to test it, but in normal driving and on some pretty rough forest service roads I never noticed any rubbing.
    FirstGenVol likes this.
  9. Jun 13, 2019 at 10:49 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    ah just do it and see how it is. I'm willing to bet that you'll make it fit with trimming, but trimming honestly is simple and straight-forward should you even need it. Only issues I would watch for is frame and that's only affect with turning (normally full lock).
  10. Jun 13, 2019 at 1:47 PM
    Hand Protectors
    The side nobbys are substantial on some of these off road tires. Here is what 16 years of 285/75/r16 rubbing looks like.
    The stealer put on my first set of crappy Dunflops MT and a few years later I had the truck inspected at said stealer in which the mechanic/service guy called and said he was going to reject me for ‘oversized tires rubbing frame’.
    I said, ‘Oh yeah? Well, I’ll call the State Inspection Board because you guys put them on!’
    Hahahhaaa. Sticker went on the window without further ado.
    upload_2019-6-13_16-40-50.jpgG
    Toyotoholic and Darkness like this.
  11. Jun 13, 2019 at 7:58 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Trimming is easy and shouldn't be bad with that tire size. My 315 70 17s were not fun to fit with only 2 inch strut spacers up front. I actually think I did less to the firewall than some others have done, but it isn't minor work. It's do it and never go back territory.
  12. Jun 15, 2019 at 11:43 AM
    Eugene406
    Montana
    Bone Stock.
    Thanks for all the input, they are at the shop getting mounted and balanced right now and I should be able to put them on tonight. Does anyone know off the top of their heads if you can fit 285/75/16 on the spare under the bed?
    Thanks again.
  13. Jun 15, 2019 at 1:02 PM
    Hand Protectors
    Yes
  14. Jun 15, 2019 at 1:46 PM
    KarmaKannon
    Utah
    Some junk
    My 06 fit a 315/70/17 in the stock spare location. It hangs down and bit but still fits.
  15. Jun 15, 2019 at 2:29 PM
    Eugene406
    Montana
    Bone Stock.
    Picked the wheels and tires up from the shop a couple of hours ago and just got done putting them on the truck. Little to no rubbing under normal driving conditions with no trimming. No rubbing when turning the wheel to full lock, however, there is a slight rub when articulating under full lock (I can deal with it). No need to run a spacer to clear the upper control arm.
    Here are some pictures.
    Here are some progress photos. The first was December of last year.
    I think 285/75/16 in an aggressive lug pattern would be about as big as I would want to go.
  16. Jun 15, 2019 at 2:30 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That looks outstanding. Huge improvement!
  17. Jun 15, 2019 at 2:32 PM
    Eugene406
    Montana
    Bone Stock.
    Thanks bud! It has been a fun project.
  18. Jun 15, 2019 at 3:03 PM
    Hand Protectors
    Its the best size tire IMO for our trucks combining a bigger size (looks) while still maintaining the vehicle integrity (no cutting), and performance (heavier tire but can still be handled mechanically by our stout engine/trans).
    Looks good. I had no idea 16 years ago this was the best fitment and have to give props to the tire guy that recco’d this size.
    Dannydirtyfingers and Darkness like this.
  19. Jun 15, 2019 at 4:33 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    This looks so much more proper.
  20. Jun 15, 2019 at 4:53 PM
    Eugene406
    Montana
    Bone Stock.
    I agree.
  21. Dec 31, 2019 at 8:06 AM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Rather than starting a new thread for my simple question, I thought I would revive this one. I searched and found many threads like this one, but couldn't find my question (probably because it is obvious, but I want to be sure...). Anyhoo, I am moving up from my stock 16" wheels to a factory Toyota 17" size. My stock tire size is 265/70r16, and the equivalent size would be 265/65r17. However, many more selections available in 265/70r17. I realize the speedo and odo will be off if I use that size. Any problems fitting that size on my otherwise stock Tundra? I want NO rub (ever) and don't want to remove my front splash guards. Will they fit? I believe they will easily (with no rubbing), but wanted to double-check here before buying tires. Thanks in advance.
  22. Dec 31, 2019 at 8:19 AM
    Eugene406
    Montana
    Bone Stock.
    265/70/17 will fit no problem, assuming your front suspension isn't sagging.
    Good luck. Post some pics if you get some.
    Dog likes this.
  23. Dec 31, 2019 at 8:23 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm not an expert on this but I don't believe you will have any issues fitting that size(based on what I've seen here). Personally, I think it would look better if you went with 275/70/17 ;) but that may not meet your needs.
    Dog[QUOTED] likes this.
  24. Dec 31, 2019 at 9:28 AM
    Dog
    Dog sit!
    Thanks, not sagging as far as I can tell.
    I like the idea, but tire selection is really thin in that size (worse than 265/65r17).
    So, anyone disagree that 265/70r17 will fit with no rubbing?
  25. Dec 31, 2019 at 10:10 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I wanted to run 285's but the 265/75/16's I currently have rub and so did the other brand I ran previously. I did put on some Vision Turbine wheels with a +0 offset so that may have effected it. I had to remove the mudflaps and it still rubs just a tiny bit on the passenger front only when doing right 3/4+ turns.
    Dog likes this.
  26. Dec 31, 2019 at 2:25 PM
    truckee_mctruckface
    truckee_mctruckface New Member
    Charles
    Seattle
    2005 DC SR5 TRD off road Spectra Blue
    I just put 265/70/17 on my truck with stock suspension. No rubbing. I took my front flaps off but don’t think they would be a problem with these tires. I get a slight rub when I turn with flex, but it doesn’t bother me. The difference in speedometer and odo is pretty minimal.
    Dog likes this.
