Will Bilsteins from a Chevy fit my Tundra?
Discussion in 'Suspension' started by newtundra16, Oct 6, 2016.
  1. Oct 6, 2016 at 12:07 PM
    newtundra16
    newtundra16 [OP] New Member
    Chase
    2016 Tundra Double Cab SR5
    Blacked Out
    found these rear bilstein 5100 shocks on craigslist; link below, and though they were taking off a chevy I am tryin to see if these would fit my 2016 double cab 2wd??
    Cant find anything online seeing if they are compatible
    they are really cheap the only reason I'm asking , any help is appreciated guys.
    http://houston.craigslist.org/pts/5807106705.html
    csuviper likes this.
  2. Oct 6, 2016 at 12:41 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    The GMC shocks will NOT fit a tundra. The top of the shock mount is different. Here's a quick pic for reference.
    Toyota style 5100 below
    Pic from GMC 5100 below
    Bob and TheBeast like this.
  3. Oct 6, 2016 at 12:45 PM
    newtundra16
    Chase
    Blacked Out
  4. Oct 6, 2016 at 12:53 PM
    Bannock452
    Brandon
    Murrieta, CA
    No problem! Check out http://downsouthmotorsports.com if your still looking for some shocks! Very good prices and awesome customer service. I think the rear 5100 are like $80 new!
  5. Oct 7, 2016 at 7:05 AM
    newtundra16
    Chase
    Blacked Out
    @Bannock452 if I wanted to get the adjustable bilsteins and put them at their highest setting up front and regular ones in the back would I still need to get a leveling kit? or shackles in the rear? im looking for a slightly lifted but level look. any help would be appreciated!
  6. Oct 7, 2016 at 7:52 AM
    Bannock452
    Brandon
    Murrieta, CA
    Getting the 5100 on all 4 corners would be perfect for a level lift at a great price! It is not advised to add another lift with the 5100 already set at the highest setting. Just keep in mind the higher you lift the more harsh the ride will be.
    As for the rear the 5100 will NOT lift the rear at all so you can add a shackle to lift the rear 1-3" depending on which shackle you purchase.
    Depending on your budget you can check out the 6112 for fronts which comes with a new spring special for the tundra. And 5160 for the rear will allow for more travel and lift capabilities. Just an idea.
    TheBeast likes this.
  7. Oct 7, 2016 at 8:31 AM
    newtundra16
    Chase
    Blacked Out
    oky sounds good! I think I will look at the 5100 first and maybe some coachbuilder shackles in the back... hopefully get this done pretty soon, if not, after the wedding! thanks for your help, and btw sweet ride man!!!
