Will a dealership install this?
Discussion in '2.5 Gen Tundras (2014-2021)' started by redryder, Mar 6, 2020.
  1. Mar 6, 2020 at 8:52 AM
    redryder
    redryder [OP] New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    I want to get some aftermarket tow mirrors. Most like the trail ridge mirrors. I dont have the time to install them myself so I'm wondering if I bring them to dealership, they will install them for me? Has anyone else tried that?
  2. Mar 6, 2020 at 8:53 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Not sure how far ur dealership is but by the time u drop off ur truck and go back and get the truck u would of installed those mirrors
  3. Mar 6, 2020 at 8:56 AM
    redryder
    Ryder
    Louisiana
    Not far. But what I really dont have time for is to accidentally mess something up and have to start over or put my old mirrors back on and try again on a different day.
    fisherman951[QUOTED] likes this.
  4. Mar 6, 2020 at 8:59 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    It’s pretty simple mod takes like 15 min. Pull the door panel take the bolts off holding the mirror unplug the old one plug in the new bolt back on then put the door panel on.
    Black Wolf and jewsNbrews like this.
  5. Mar 6, 2020 at 9:00 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Watch some YouTube videos. You'll also have to wait in the dealership for them to finish it up or get a loaner or another ride to escape the dealership so you can run other errands. But call up your specific dealership and ask them. Most times yes, they will install but will not provide any warranty as you didn't buy the part from them. If they dropped they dropped the tow mirrors and mess it up or the tow mirrors come on the mail defective, you still have to pay for their labor.
  6. Mar 6, 2020 at 9:28 AM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    yes your dealership should/will do it.. at 100 bucks an hour.
  7. Mar 6, 2020 at 10:47 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Understandable
  8. Mar 6, 2020 at 10:53 AM
    timsp8
    NY
    All you do is pop the top of the door panel off and you can get to the screws. There are 3 per side. Takes 15 min. Like others said you won’t save time having the dealer to do it unless someone else takes your truck in. But it’ll probably cost you $100-$200.
    Its not hard to mess up.
    Pinay likes this.
  9. Mar 6, 2020 at 11:50 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    o_O You mean, it's hard to mess up?
  10. Mar 6, 2020 at 11:56 AM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    He must have meant that. I swapped in my tow mirrors in about 20 min total. If i was rushing i could have did it in 10. Unless you drop the dang mirror or something, u really cant mess it up
    Jaypown[QUOTED] and Pinay like this.
  11. Mar 6, 2020 at 12:57 PM
    timsp8
    NY
    It’s not not hard to mess up.
  12. Mar 7, 2020 at 8:06 PM
    2020TNtundra
    2020TNtundra New Member
    Just got my set from A1 Auto, installed in minutes, well, I dropped a nut inside the driver door and had to find it. That took longer than the install. Running Light, Blinker light, Power Mirror all worked as advertised, Install was really simple. Just be careful with the nuts. No there is not the closer than appear on the passenger side but with the lower mirror its so much better than the stock.
    1lowlife likes this.
  13. Mar 7, 2020 at 8:16 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I had to pull the stock mirrors a couple times making my custom puddle lights on my SR5.
    That was going to be my comment, make sure you don't drop one of those nuts down into the door.
    It won't fall to the bottom, it falls down into a little 'pocket' under the mirror bolts.
    Took me 30 minutes to fish it out with a magnet.
    There is no way I'd pay anyone to swap a mirror.
    Just be careful with the nuts, and don't let them fall into the door.
    Shouldn't take more than 45 minutes (that is being generous) for both sides.
    Short version..
    https://www.youtube.com/watch?v=QcHtGXjXENQ
    Long version
    https://www.youtube.com/watch?v=-0IrB5gtTSU
  14. Mar 7, 2020 at 8:20 PM
    2020TNtundra
    I never found mine!! Just gave up after not finding it or hitting the door have it fall. Tried a magnet and no help. figured it would at some time fall to the bottom and then I would poop the panel off and get it at that time. Its really easy to get the panel off.
    Oh and lower the mirror if your doing it by yourself!!
    Durania and 1lowlife like this.
  15. Mar 7, 2020 at 9:39 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    Just don't drop the nuts inside the door when you go to thread them back on. Like others are saying though, this is very easy to do with above videos.
    I've done it twice (three times actually) without issue.
    Just read above, ha! - yes, exactly what @1lowlife said.:hattip:
  16. Mar 8, 2020 at 6:18 PM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    I dropped one of mine down in the door when I was taking my tow mirrors off and putting the stockers on since I wouldn't be towing till spring. After an hour of trying to fish out the nut, I learned that it was wedged in a 2 piece portion of stamped metal. I ended up just going to a parts store and finding one of those metric nut/bolt/washer assortment kits and using a washer and nut on the stud.
  17. Mar 8, 2020 at 8:45 PM
    Silver4x4trd
    Silver4x4trd New Member
    2017 Tundra SR5 & 2012 Sequoia SR5
    Jba long tube headers, dirty deeds TRD exhaust (2x24), 19+ Pro lights and grill painted sky silver, TRD rear sway bar, TRD reusable air filter, PnP sliders, pnp full set skid plates, 275/70/18 ko2’s, bully dog bdx (trail setting), c4 hybrid bumper with DD lights(sae fog and driving)
    It’s so easy!
  18. Mar 9, 2020 at 8:55 AM
    redryder
    Ryder
    Louisiana
    Thanks guys. It does look a lot easier than I thought. I just need to pull the trigger on some mirrors and find time to do it myself.
    YeeYeeTundra likes this.
