Will a bed cover for 2018 crewmax fit a 2007 crewmax?
Discussion in 'Tonneau Covers, Caps and Shells' started by Seeingidawg, Mar 10, 2020.
  1. Mar 10, 2020 at 4:50 PM
    Seeingidawg
    Seeingidawg [OP] New Member
    Greg
    Looking for a 3 fold cover for 2007 crewmax
  2. Mar 10, 2020 at 5:24 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    2018 and 2007 are both 5'5" . They should be interchangeable.
    Hostage81 likes this.
  3. Mar 11, 2020 at 4:35 AM
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    Most bed covers that sit on top of the rails and or in the interior dimensions will fit. the main difference is that the 2014 plus has a lip at the top of the bed so the type that go over the tail gate wont fit. camper shells included. I have found that the rugger cover 2s for the 2014+ are slightly longer because of this, but they still work. They will just sit closer to the corners and you will have to push them a little closer to the cab.
    WVI likes this.
  4. Mar 11, 2020 at 4:41 AM
    timsp8
    NY
    Probably, but might leak. As prerunnerseth said the new ones are longer. A truck cap from 07-13 won’t fit a 14+, but a tonneau cover might. It could be too long too. If you are buying it from someone then lay it on top of your bed to see the size. Don’t have to mount it to see if it’ll line up.
  5. Mar 11, 2020 at 4:49 AM
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    I had the tie-down/rail system in my bed. I got rid of that because I had issues securing the tonneau cover with those stupid rails installed. I didn’t need the rails either so I removed them easy with a torque wrench.
    But those tonneau covered are interchangeable. So much that I even used the same 5.5 tonneau cover on my ram, tundra and f150’s as long as the bed size is same in length.
  6. Mar 11, 2020 at 5:03 AM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    Yes, they fit. I'm on my second Extang Encore tri-fold and wouldn't have it any other way.
