Will 35X12.5R20 fit on a 3/1 level kit
Discussion in 'Wheels & Tires' started by Laz1388, Feb 1, 2018.
  1. Feb 1, 2018 at 6:43 AM
    Laz1388
    Laz1388 [OP] New Member
    Laz
    South Florida
    2019 1794 MGM
    Windows tinted, Spray-on bed liner, Chrome Delete, Roll-N-Lock retractable cover, Painted fender flares, TRD PRO Suspension, Front and Rear TRD Sway bar, Magnaflow Exhaust, ReadyLift 6" lift, Bronze KMC XD Grenade wheels 20X9-18, Toyo Open Country R/T 37X12.5-20
    Good morning fellow members, I'm looking to do my next mod on my 2015 SR5 TRD 4X4. I will be installing a Low Range Off-Road 3" leveling kit lrt-2007-2016-3-leveling-lift-kit-for-toyota-tundra.html I'm trying to decided whether to go with a 305/55R20 tire setup or a 35X12.5R20 Theres a couple of good deals to be had on some local wheel/tire combos for the 35X12.5 set up, However I'm just not sure how the larger tire combo would work or look, If anyone is running a similar set up I would very much appreciate sone insight as well some side pics of your steed for reference.
    This is my daily driver, work truck and spends a-lot of time being driven up to 8 different job locations per day, I'm aware that it will also have a negative impact on my MPG.
    Any input is appreciated
    Thanks
  2. Feb 1, 2018 at 6:49 AM
    35s will fit on a 3/1 kit...possible light rub on the skid plate at full turn lock
    Sunnier and Laz1388[OP] like this.
  3. Feb 1, 2018 at 6:57 AM
    ^^^ and may have to push forward front fender liners a bit.
    JoshuaA, zcarpenter92 and Laz1388[OP] like this.
  4. Feb 1, 2018 at 7:48 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    And may need/ want cab mount chop. Wheel offset is a huge factor.
  5. Feb 1, 2018 at 8:17 AM
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    35X12.5X18 already rubs. I can't imagine 20's wouldn't rub more. definitely BMC and also depends on type of brand of tires. More aggressive threads will make them closer to body which means more rub.
    Laz1388[OP] likes this.
  6. Feb 1, 2018 at 8:18 AM
    Laz1388
    Laz
    South Florida
    2019 1794 MGM
    All great info guys, thanks for all your input, keep them coming
  7. Feb 1, 2018 at 8:33 AM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    My 2008 with 305/55/20 MT ATZ's and a Rancho quick lift set up. Small amount of rub but not enough to trim anything.
    TUNDRA375 and Laz1388[OP] like this.
  8. Feb 1, 2018 at 8:50 AM
    Laz1388
    Laz
    South Florida
    2019 1794 MGM
    Thanks for the pic, I do like the way that the 305 size fills up the wheel wells, does anyone know if the 2014 up have bigger wheel well openings?
  9. Feb 1, 2018 at 11:29 AM
    Laz1388
    Laz
    South Florida
    2019 1794 MGM
    This is what I’m looking at, Wheel/tire package Nitto Trail grapplers 35X12.5 on fuel wheels 20X10 -18 offset
    619Tundra likes this.
  10. Feb 1, 2018 at 11:48 AM
    alext6
    alext6 New Member
    18 mgm cm
    Toytec radflo. Method. 35 ridge grapplers
    A 9in wheel with +18 offset will work and all you have to do is push the fender liner in. And take off your mud flaps.
  11. Feb 1, 2018 at 12:25 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    who's got a link for that fender liner thread? having no luck and i get rub all the time.
  12. Feb 2, 2018 at 5:44 PM
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
    Thanks for he photo..AWESOME TRUCK..Did you have to remove the mud flaps...That's the size I want to put on my truck but I don't want to have to cut or trim anything.
  13. Feb 7, 2018 at 8:59 AM
    Gibzki
    Gibzki New Member
    14 White Tundra DC TRD 4X4
    Bakflip Tonneau Cover Fibermax Amp Power Step Moto Metal M0961 Pro Comp Xtreme M2 295/55R20 2 8" Rockford Fosgate Punch Alpine MRP-M500 Mono Power Amplifier LED headlight, foglight, reverse light, license plate light, cargo light, map light, dome light, vanity and footwell Magnaflow 15304 with black tip
    No rubbing at all? I have 20" wheels with +18 offset and needed new tires. I wanted to do a similar set up that you have (35/12.5 r20).
    Do you think it will rub with mild off roading?
  14. Feb 7, 2018 at 10:52 AM
    alext6
    alext6 New Member
    18 mgm cm
    Shouldn’t be a problem as long as you properly push in or trim the fender liner in the front. I still get a little rub sometimes when turning full lock and moving. I’m having a custom sinister bumper built that will solve all problems though.
  15. Feb 7, 2018 at 10:27 PM
    Gibzki
    Gibzki New Member
    Do you have more front rear and side view pics of your truck? Thanks.
  16. Feb 7, 2018 at 10:34 PM
    TheBeast The Beach
    I believe the gen 2s have a slightly bigger wheel well opening
    Laz1388[QUOTED][OP] likes this.
  17. Feb 9, 2018 at 6:08 PM
    alext6
    alext6 New Member
    18 mgm cm
    35898F28-A315-46E4-A9C5-BE8E6DB8F9B5.jpg E6453EDC-9E1C-40B8-964A-878CC8246EA6.jpg FC19C193-F5C0-4668-8A73-4179540FAEE0.jpg
  18. Feb 9, 2018 at 7:45 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Fit??? Yes....
    MT - Deegan 38: 35X12.5 R20
  19. Feb 10, 2018 at 2:36 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    OKAY - that settles it. I want those rims. Which Method are those?
  20. Feb 10, 2018 at 3:31 PM
    alext6
    alext6 New Member
    18 mgm cm
    Method grid in titanium
  21. Feb 10, 2018 at 10:51 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    So I imagine a 3/1 will have no issue clearing 33's? With zero modification?
    eriksghost and Laz1388[OP] like this.
  22. Feb 14, 2018 at 10:19 AM
    Laz1388
    Laz
    South Florida
    2019 1794 MGM
    1E87EF55-D128-4911-8C6C-0D629DA5CDF7.jpg 2DD9EA92-29DE-43A8-8BFB-648888715B2C.jpg C93BECCD-93C9-4661-A42C-8047AAB8A0A1.jpg 8960AD2F-E0A2-4DF3-AEBD-8DD06B191137.jpg C235714F-B964-432C-866F-60629E92CC6F.jpg Pulled the trigger on the wheels/tires, ended up going with Fuel Black Wildcat 20X10 -18mm and Nitto 305/55-20 thanks to everyone who chimed in, I see fender flares in my near future.....lol
  23. Feb 14, 2018 at 12:28 PM
    TUNDRA375
    GA
    THAT IS ONE BAD ASS TRUCK...LOVE THE LOOK..THANKS FOR PHOTO'S:ohsnap: YOU GOT ME FIERED:bananadead: UP I'M GOING TO DO IT ....
  24. Feb 16, 2018 at 4:35 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    35.4" on a 3"/2", and yes they rub, body mount and inner fender. Fronts only, rears have plenty of clearance.
    h-attack54, Stroke250 and Laz1388[OP] like this.
  25. Feb 20, 2018 at 6:49 AM
    Laz1388
    Laz
    South Florida
    2019 1794 MGM
    DC31BC17-5922-42D5-A2D2-DE4556AC9C11.jpg Rough Country Fender flares came in yesterday afternoon and just finished installing them85F4F06C-F7F1-46E1-AF84-38C6D84FE23C.jpg
  26. Feb 20, 2018 at 7:10 AM
    Sunnier
    Sunny
    San Diego, CA
    Your truck looks great!
    Laz1388[QUOTED][OP] and =57= like this.
  27. Feb 20, 2018 at 9:50 AM
    Laz1388
    Laz
    South Florida
    2019 1794 MGM
    Thanks, it’s still a work in progress
    Sunnier[QUOTED] likes this.
  28. Feb 20, 2018 at 4:58 PM
    TUNDRA375
    GA
    Bro...You have set the bar high..The truck is awesome
  29. Feb 20, 2018 at 7:36 PM
    Laz1388
    Laz
    South Florida
    2019 1794 MGM
    Thanks, Next mod is getting the bumper caps wrapped in matching Cement Grey to finally get rid of the remaining chrome...
    Sunnier likes this.
  30. Mar 1, 2018 at 5:52 PM
    stsuda
    stsuda New Member
    2018 Magnetic Gray Tundra Double-Cab Limited
    What’s the word on the rub?
