Will 295/70 R18 Nittos rub?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Kilos, Oct 24, 2016.
  1. Oct 24, 2016 at 10:11 PM
    Kilos
    Kilos [OP] YotaPro
    Brett
    AZ
    2017 TRD Pro Barcelona Red
    Icon Stage 6 suspension Method NVs matte black w/Toyo Tires 35x12.5s SDHQ Sliders Cab mount chop Precision LED interior lights (6000k) GTR reverse LEDs 20% acrylic tint (heat resistant) Inyati spray in bedliner Black TRD Pro bed inserts Vivid Racing Leather wrapped steering wheel AJT Designs TRD shift knob AJT key fob Morimoto LED fog lights Full JL Audio sound system upgrade Kenwood 995S HU
    Anyone running these, Nitto Terra Grappler G2 LT295 /70 R18? Picking up my Pro this weekend and want to ensure they won't rub with the stock setup (no plans for a lift). Thanks in advance!
  2. Oct 24, 2016 at 10:24 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You'd be better off with a 275/70r18. Especially on stock rims.
  3. Dec 11, 2016 at 3:34 PM
    Beep88
    Beep88 New Member
    Curious to see if you had any rubbing? Just bought my pro and want to put on some 295/70/18 as well but I am not wanting to do any cutting or chopping
    HornetOne3 and Kilos[OP] like this.
  4. Dec 11, 2016 at 5:18 PM
    Kilos
    Kilos [OP] YotaPro
    Brett
    AZ
    Zero rubbing, went with 275/70.
    Marty McFly and Law323 like this.
  5. Dec 11, 2016 at 7:06 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I am running a 285/75R-18 Nitto G2's on oem wheels with no issues. Granted I have mods to my front bumper and skid plate, but love the tires.
    209TRDPRO and driverdog like this.
  6. Dec 11, 2016 at 7:43 PM
    Beep88
    Beep88 New Member
    I think I am going to try the 295's. I will let you know how it goes.
    Kilos[OP] likes this.
  7. Dec 12, 2016 at 4:15 AM
    syty12
    syty12 New Member
    Jeremy
    2013 Black on Black TSS Crewman
    I'm running on 305s with 20inch stock wheels no rubbing at all
  8. Dec 12, 2016 at 4:57 AM
    Glock17
    Glock17 New Member
    Helena, Al.
    2016 TRD PRO
    Fab Four bumpers, Warn Zeon 10, Line X, Toytec lift, Rugged Tri fold cover, Cooper SST, Weathertech liners, Weathertech vent guards
    295/70/18 ridge grapplers
    zcarpenter92 and Kilos[OP] like this.
  9. Dec 12, 2016 at 10:14 AM
    warwickscout
    warwickscout New Member
    tommy
    warwick ny
    16 pro
    tint 295/70/18 terras iron cross hd steps.wheel spacers,nder seat storage,l.e.d lights cut into rear bumper,spacers,
    im running them ,only issue is the little front mud flap
  10. Dec 12, 2016 at 7:17 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I just put a set of nitto exo grappler 285/70/18's on my 13 with stock 15 trd wheels and 2.5 inch lift and still have a little rubbing on the passenger side. I took off the little thingies and stretched out the inner fender wells with a heat gun and a 2x4. Need to work on the pass side a little more and it should be good. I also trimmed the skid plate. I don't think you can go any wider than that on stock wheels without getting into the ucas. Unless you have the 20s, guess they have a little more offset.
  11. Dec 12, 2016 at 7:19 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Guys he has a pro that has a 2" front level. Def different than stock.
    Patriot, zcarpenter92 and Kilos[OP] like this.
  12. Dec 12, 2016 at 7:26 PM
    csuviper
    Broomfield, CO
    The tire size is a ~34.5 x ~11.5". That is what I have on my 2012 with 3/1 lift, 1.25" wheel spacers for end back spacing of +18.24. Had to trim the front wheel well, trim the front skid plate and remove the front mud flap.
  13. Dec 12, 2016 at 8:59 PM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    :worthless:
    AnonVet likes this.
  14. Dec 12, 2016 at 9:41 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Brian, did you have to trim your bumper too? I was thinking about getting spacers but it looks like with the spacers it would be really close on mine. Then I'd probably need to get flares to keep rocks from flying out too.
  15. Dec 24, 2016 at 4:52 PM
    Kilos
    Kilos [OP] YotaPro
    Brett
    AZ
    275/70
    iHacker, CM-LENNY and driverdog like this.
  16. Dec 24, 2016 at 6:49 PM
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    Looks good, like a well-balanced, efficient set-up.
    Kilos[QUOTED][OP] likes this.
  17. Dec 24, 2016 at 10:31 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Shims and shackles do make it a bit easier to fit bigger tires, but I do seem to believe @TRON was able to fit 35's on stock wheels before he got Methods and ADS shocks.
  18. Dec 24, 2016 at 10:43 PM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Nope, never tried since I had the methods before even had the truck haha. Installed 35s on methods on stock pro
    iHacker likes this.
  19. Dec 25, 2016 at 8:06 AM
    BBradac9
    BBradac9 New Member
    2017 Cement Tundra TRD Pro
    Parts on order
    Did you run the factory Michelin's at all? How is the road noise compared to them if you know?
    Thanks
  20. Dec 25, 2016 at 9:22 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Ah! The whiskey last night had me thinking otherwise:drunk:
    CM-LENNY likes this.
  21. Dec 25, 2016 at 5:04 PM
    sean76710
    sean76710 New Member
    Waco, TX
    2017 TRD PRO on Readylift Pro Plus 6
    had nitto trailer grapplers, they are very noisy at first and acceptable after 1000miles
  22. Dec 31, 2016 at 2:46 PM
    Kilos
    Kilos [OP] YotaPro
    Brett
    AZ
    Only on the test drive. The Nittos produce more noise than the stock Michelins, but by no means are they loud.
    boardude likes this.
  23. Dec 31, 2016 at 3:07 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I've been running the G2s for about 10k miles and I wouldn't consider them noisy on street or highway
  24. Dec 31, 2016 at 4:55 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    The exos aren't loud at all, still only have a few miles on them. I think I stopped the rubbing by reshaping the front fender liners. Looks like what I've been hearing since is the traction control.turn it off, no noise. Time for the zero point calibration.
  25. Jan 9, 2017 at 5:16 PM
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    Just got my G2 in 35's Friday and not too noisy. They are smooth tho'
  26. Jan 9, 2017 at 6:07 PM
    CM-LENNY
    San Diego, CA
    Do you have pics with the new 35 G2's ?
  27. Feb 1, 2017 at 9:49 AM
    Sooner77
    Sooner77 New Member
    Todd
    Tulsa, OK
    2017 Cement TRD PRO
    Predator Pro Step Bar, BackFlip MX4, XPEL Paint Protection Film, Husky X-ACT
    Lots of discussion - So I'm ready to replace the stock Michelins with G2's. 275/70 on stock rims seams to be the recommendation for zero rub without modification? Anyone have the 275/70 with 1.25 wheel spacer? Would like to go bigger but don't want to cut the skid plate or wheel well
  28. Feb 1, 2017 at 11:45 AM
    209TRDPRO
    2016 Tundra TRD PRO
    Just lights for now
    CM-LENNY, WatTundra, J4RR3N4 and 2 others like this.
  29. Feb 1, 2017 at 11:58 AM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Looking to get Nitto Ridge Grapplers in the next 30 days. thinking 295/70/18
    dcsleeper408 and zcarpenter92 like this.
  30. Feb 1, 2017 at 12:39 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    That's what a I bought as well, looking forward to seeing how they look and ride.
