Will 285/75 rub on bilstein top setting
Discussion in 'Wheels & Tires' started by 11CMGray, Feb 14, 2020.
  1. Feb 14, 2020 at 8:47 AM
    11CMGray
    11CMGray [OP] New Member
    I feel like I have spent hours reading threads on wheel and size and tires, and seen multiple opinions saying they will or won't rub, still just as confused as when I started lol.
    I have a set of icon six speed sitting in my cart( Keep changing my mind on the color)
    And in the process of picking a tire, I know a 285/70r17 will fit, but would a 285/75r17 fit without rubbing? All I have is front bilstein 5100 top setting. I'm fine with removing mud flaps. If anyone has a 2nd Gen with same set up including wheels, any advice? Will the 285/75 be noticable difference for the 70.
  2. Feb 14, 2020 at 9:20 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
  3. Feb 14, 2020 at 9:42 AM
    11CMGray
  4. Feb 14, 2020 at 10:06 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I had some 275/60R20(33/10.8R20) on +20 offset 20x9 wheels that would rub at full lock in reverse on a set of pro comp pro runner ss struts at leveled setup (2.5" lift i believe). thats pretty close to what you're looking at with. With the 285/75 being 33.8/11.2, i feel like with that offset/diameter/width you would rub just a lil bit. not extreme, but feel you may need to trim/mold some plastic liner
  5. Feb 14, 2020 at 10:15 AM
    11CMGray
    Thank you for the info. Might just be safe and go with the 285/70s. Dont really go off road other than hoping a few curbs to go fishing but prefer to have clearance without rubbing issues
    Fotnot[QUOTED] likes this.
  6. Feb 15, 2020 at 7:10 AM
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    I doubt the 285/70 is going to rub, but I do think it will look way to small with a lift on your truck. If those two are my only choices I'd go 285/75
  7. Feb 15, 2020 at 9:54 AM
    11CMGray
    I just have a front level so not really much of a lift. I definitely think the 75 would look better but havnt found any to comment if they have that wheel/tire level combo yet. This pic is a 285/70r17
  8. Feb 15, 2020 at 10:05 AM
    Hhtundra
    Hhtundra New Member
    Youll be fine with that offset and backspace, be cautioned however, i did the same and ended up stepping up to 35’s,
  9. Feb 15, 2020 at 10:10 AM
    11CMGray
    Thanks. With the 75s or 70s?
  10. Feb 15, 2020 at 10:17 AM
    jordan0317
    Jordan
    Martin, TN
    @Bailey was running 285/75r17 I believe and think he was around 2.5" lift
    11CMGray[OP] likes this.
  11. Feb 15, 2020 at 10:19 AM
    11CMGray
    Other than removing mud flaps, nothing rubbed?
  12. Feb 15, 2020 at 10:21 AM
    jordan0317
    Jordan
    Martin, TN
    Not sure, hes got a full build thread on his truck. If you go to his profile and click on his posts itll pull up
  13. Feb 15, 2020 at 10:24 AM
    11CMGray
    Thank you, I missed the Bailey tag. I'll check it out
    jordan0317[QUOTED] likes this.
  14. Feb 16, 2020 at 6:16 AM
    mahmer09
    mahmer09 SR5 4x4
    I’ve got 285/75/17s and I had some rubbing on the front wheel well covers, the plastic lining. Trimmed that up and I was good to go. I have 6112s up front at 1.9. I don’t know my rim off set, but my tires stick out about 1.5 inches from the fender. Not sure if that helps ease rubbing issues or makes them worse.
    I like the tire size but sometimes wish I had gone wider.
  15. Feb 16, 2020 at 6:44 AM
    11CMGray
    What wheels do you have, I could probably look up the offset
  16. Feb 16, 2020 at 6:49 AM
    mahmer09
    mahmer09 SR5 4x4
    That’d be cool! A buddy’s dad owns a shop and I gave him a list of what I wanted and he did the rest. We never really talked about off set. They are Method Grid wheels, 17s. Like I said, the wheels stick out about 1-2 inches from the side of the truck if that helps. Thanks!
  17. Feb 16, 2020 at 7:01 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
  18. Feb 16, 2020 at 7:03 AM
    11CMGray
    Good to know. Was leaning falken or toyo open country
  19. Feb 16, 2020 at 7:04 AM
    11CMGray
    Looks like those wheels are 18 offset with 5.75" backspace
    mahmer09[QUOTED] likes this.
  20. Feb 16, 2020 at 7:46 AM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    I’m running icons with 285/70/17 no lift, no trimming. Slight rub reverse full lock.
