Wikid's Tundra
Discussion in '2.5 Gen Builds (2014-2021)' started by Wikid, Jun 9, 2015.
  1. Nov 18, 2015 at 10:11 AM
    #211
    Wikid
    Wikid [OP] New Member
    Don
    Toyota Tundra Crewmax Platinum
    On order
    I am beginning the install of my Rocksmasher, 2 way air system.
    It's a universal kit that you can adapt to any truck including the Tundra.
    Typical installation would have all the control features under the hood, since some actually mount compressors there. I will be doing it slightly different and hard line the compressed air into the system from the bed. You can just use a CO2 tank as well Its just a typical comressor quick disconnect, to air up, if you don't hardpipe a compressor in That valve is to the right, on the bulkhead with one shrader valve
    Here is what the system looks like before install
    I have some additional stuff besides the universal, which can also be acquired from Rocksmasher.
    The gauge is and some fittings are extra. You can also use just a tire pressure gauge for pressure checks
    There are 5 tire shrader valves. One for each corner and one on the the bulkhead for pressure checks.
    One pressure valve (Brass) , that is adjustable to whatever you air up to. Even if the compressor keeps going, the valve will just blow off the over pressure until you stop it
    The quick connect fittings on the left are to attach to the corners with some quarter inch hose, not shown in the picture .
    I have one extra valve , with fittings to go into the compressor
    Plenty of 3/8th air line already protected with convoluted tubing. Then plenty of 1/4 air line to plumb into the vehicle.
    T's and connectors to make all the connections and even a plastic pipe cutter for clean cuts
    All fittings are high quality
    The fittings are laid out in the schematic, that it will be plumbed in.
    I need to acquire one more 3/8th tee fitting that will replace the 1/4 inch that the blue cap is sitting on .
    The idea is that install the valves in the fenderwells, that also have protective slip on caps. You can quickly connect all of your tire hoses, that are about 30 inches, each then air up and air down, right from where you place the bulkhead, either under the hood, or in my case in the bed. You always air up evenly and always air down evenly. Since there are schrader valves, you could also air up or down another vehicle, 2 tires at a time . Or a trailer too . You can make this system work for as many tires as you have. Even rv's and semi's use them . You just need to add hardware to expand it
    I will write a more detailed post when I actually install it. Then do some real world air sessions, to show you all how it works. At first it sounds like lots of fussing with hoses and stuff, but actually it will make this task much faster and you can enjoy talking with others or having a cold beverage, while doing the task
    Here is a link to the system 2 Way Air by Rock Smasher Engineering
    TRON likes this.
  2. Jan 11, 2016 at 2:06 AM
    #212
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Hey Don! :wave: nice to find you on here and follow the build more closely! Amazing journey for Artica thus far! Really like the full MT Expo build here and it is exactly what I intend to do with mine. One of these days ill have to meet with you and go for a ride, I'm really curious how those bypasses sound in the cab. As for the rear sorry if I missed it, but what leaf pack are you running?
  3. Jan 22, 2016 at 6:06 PM
    #213
    Wikid
    Don
    On order
    Nice seeing you here to Stefen . Thank you. I really can't hear the bypasses in the cab at all. As for the leaf pack, it's custom, since the weight is a little more, deaver just made it to adjust for the weight. It's still nice and soft, when you dial down the adjusters . Yes lets meet up and take a spin.
  4. Jan 25, 2016 at 5:54 PM
    #214
    Wikid
    Don
    On order
    While I am struggling to finish up a few of the projects above, I have something else cooking
    Having DBCustomz do a custom grill for me . I asked for it to be raw, so I can decide what colors to powder coat it.
    Since the top piece is aluminum, I can even anodize it, if I decide to.
    The cut out above the center is actually scalloped, to fit a Baja Designs 30" S8, That I already have
    The light awaits..
  5. Feb 1, 2016 at 9:39 PM
    #215
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    Love that custom grill, what did that set you back?
  6. Feb 4, 2016 at 4:47 PM
    #216
    Wikid
    Don
    On order
    thanks. It was in the high hundreds. The water jet threw a few dollar signs at it :)
  7. Feb 8, 2016 at 8:57 PM
    #217
    Wikid
    Don
    On order
    Wheels of progress have slowed with business stuff and delays, until last week. One of the projects that has been hanging out there is the front grill project that will house my 30" S8 . I have had that light in my office for an eternity, it seems, but I finally have something to show now.
    The idea was to create a grill that will accommodate the light, along with adding a little "unique" , to the project. DBCustomz, http://dbcustomz.com/ has been great to work with . A hard working guy that created some unique products and now it is beginning to ramp up.
    Here is the direction I went with the grill . I review from an earlier post
    The base grill is made , then the overlay is a piece of aluminum, water jetted, with this specific font and identity
    Here it is raw
    The S8's shape was scalloped into the upper portion of the grill. Then the overlay was done with the name of my truck , of course . I picked a special font to give it the look I wanted. I also asked for it to show it was Supercharged, then he added the little man on the left, blowing air. I liked it.
    It arrived Thursday Evening, but my truck was suppose to be displayed at the Super Cross Event in the pits on Saturday . Needless to say , since it was a custom install and the first one off, it took Friday and early Saturday to finish it up. Here is the direction I went with it
    I love the back lit feature
    A little montage, to show the different scenarios.
    The fact that it accomplished getting my light, where I thought it should be, then added some flare to the project, was a bonus . The back lit feature is tied into the back lit circuit on the rear S8. I feel like it came out better than I pictured it. In the panic to get it done for Saturday and also wanting to see how the color layout would look. I painted it. When I decide if this is how I want to look, it will be removed and powder coated. I may anodize the aluminum face piece. I just don't know yet
    mdavis, T-Rex266 and ToyotaTundraMike like this.
  8. Feb 23, 2016 at 6:08 AM
    #218
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    I'm envious of all the cool shows you get to experience and show off your toys! Looks good man! So full articulation in the front end with the 35s...any rubbing? I assume you had the cab mount chopped but otherwise everything else is basically stock dimensions right?
  9. Feb 23, 2016 at 5:14 PM
    #219
    Wikid
    Don
    On order
    Thanks. You have to put the work in to get it to shows and stuff, but I would be fibbing if I said I didn't enjoy most of it . You are correct cab mount or body mount is done and I get no rubbing., with the suspension I run
    TRON[QUOTED] likes this.
  10. Feb 24, 2016 at 6:28 PM
    #220
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    That grille is bad ass!
  11. Feb 25, 2016 at 4:55 PM
    #221
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Grill does look awesome!
  12. Aug 24, 2016 at 4:40 AM
    #222
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
  13. Aug 24, 2016 at 5:47 AM
    #223
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    This is an awesome build!!
  14. Aug 24, 2016 at 6:34 AM
    #224
    I'll see you at SEMA again!
  15. Nov 6, 2016 at 6:32 AM
    #225
    Oper8r
    Oper8r New Member
    Stuttgart
    Sold my 2016 TRD PRO - Currently in BMW 535d Wagon
    Did you end up doing any trimming to get rid of the rub?
  16. Nov 13, 2016 at 7:53 PM
    #226
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    No rub. It's a page or two later but he does the cab mount chop anyway
  17. Nov 6, 2017 at 9:44 PM
    #227
    650h1
    650h1 New Member
    Any updates here? recent pics, activity, anything?
  18. Nov 6, 2017 at 9:47 PM
    #228
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    He sold it and now has the newest PRO in cement color. He's onto another build, but nothing on this level.
    650h1 likes this.
  19. Nov 6, 2017 at 9:50 PM
    #229
    650h1
    650h1 New Member
    Sold? damn. Wonder what it went for.
