Widest tire?
Discussion in 'Wheels & Tires' started by Javy, Mar 27, 2014.
  1. Mar 27, 2014 at 3:19 PM
    Javy
    Javy [OP] New Member
    2012 Toyota Tundra Texas Edition 4X4
    Nothing yet ?
    What's the widest tire you can do on tundras .
    Leveling kit or 4 in. Lift
  2. Mar 27, 2014 at 3:30 PM
    JonasSacredTundra
    JonasSacredTundra New Member
    12.5 easily I even think you could do 13.5 depending on the offset and tire size etc.
  3. Mar 27, 2014 at 8:50 PM
    Javy
    Nothing yet ?
    Thanks for your help
  4. Mar 28, 2014 at 7:09 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    @Javy if you are thinking of using stock wheels then you may not fit wider than 305.
    My 17" RW wheels have an offset of +50mm and backspacing of 6.5". The stock 18" and 20" wheels have an offset of +60mm and backspacing of 6.85".
    I was able to fit the 315mm (12.5") width tires on my RW wheels but it was tight. I belive this width would not fit on the 18" or 20".
    If you go aftermarket get a smaller offset so you can fit the wider tires. Either that or get some wheel spacers.
    Check out this link for more help: https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
  5. Mar 28, 2014 at 2:10 PM
    Javy
    Nothing yet ?
    I have the factory 20's the upgraded Texas edition ones
  6. Mar 30, 2014 at 10:11 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Yours should be a +50 mm offset. Ive got the tss 20's and mine are 50. Everyone says you can fit 305's. I sure hope so. I'd rather not have to buy different rims!
  7. Mar 31, 2014 at 7:57 PM
    Javy
    Nothing yet ?
    Me either I paid more for theses rims and I wanna keep them for awhile. Rather spend the cash on tires or lift
