Wi-Fi extender/booster?
Discussion in 'Off-Topic Discussion' started by Bammer, Dec 3, 2020.
  1. Dec 3, 2020 at 4:41 AM
    Bammer
    Bammer [OP] I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Thinking about getting one, all the reviews seem to say they work? Anyone have one and what's your take on the actual benefit if any?
  2. Dec 3, 2020 at 4:58 AM
    lloydb82
    lloydb82 New Member
    Lloyd
    2021 tundra limited crewmax
    I didn't have any luck. Purchased a netgear indoor and it was junk. I also purchased a outdoor extender and it was also junk. good luck trying to find something that works.
    Bammer[OP] likes this.
  3. Dec 3, 2020 at 5:17 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    I've had a Netgear EX3700 for over a year and it really works well. Occasionally it may lock up and I just unplug it and restart it and I'm good to go again.
  4. Dec 3, 2020 at 5:33 AM
    I have the Orbi mesh system from Best Buy. Works great and no more weak signal to my Ring cameras.
  5. Dec 3, 2020 at 5:35 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I have the Google mesh and it’s been excellent for over a year and a half. Personally, I would skip the “booster” type stuff and look at a mesh unit. They basically cloud your entire home with strong WiFi.
    Bammer[OP] and fundra_goes_west like this.
  6. Dec 3, 2020 at 5:38 AM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    This 100% you want to connect a mesh network. Boosters are old school and mesh networks can be built for relatively cheap
    Edit: except I would avoid google as they are the scum of the earth and don’t need to collect any more data. Rant over
  7. Dec 3, 2020 at 5:40 AM
    PJR202
    PJR202 New Member
    I had a Belkin for a couple years to try and get some signal back to our bedroom area. It did an OK job but not great. It eventually died.
    Since I started working at home I replaced it with a Rockspace, which works a lot better and is very good about reconnecting. I use it to boost signal through concrete to the basement. Our connection upstairs peaks at 150m on a 150m connection, but usually runs around 60. Down in the basement I get a consistent 48-50 regardless of time of day. I've been pretty happy with how it's performed. It also boosts to the bedrooms well, which surprised me since it's farther away from them than the original Belkin was.
    https://www.amazon.com/Extender-Ext...rds=rock+space+extender&qid=1607002827&sr=8-4
  8. Dec 3, 2020 at 6:17 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Go with one of the mesh systems instead. I’ve never had consistent luck with extenders, as you’ll usually run into roaming issues where your device won’t jump to the right bssid and end up with a shitty signal. Mesh systems usually have logic built in that will handle all of that seamlessly. Netgear Orbi has worked great for me and you can find decent deals on the 3 pack of you check around. Google WiFi also works well, as does Uniquity if you feel like spending some money.
  9. Dec 3, 2020 at 6:22 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I agree that it will only mean heartache to try to extend an already outdated system yourself and in the last few years the cheap Mesh networking has gotten so good that it just makes sense to get a new system really.
    I have only had luck using an Amplifi Mesh Point as an extender which is a feature that it was designed for too but for about the same price you can just get the intro Amplifi Mesh System and be done with it too.
    https://store.amplifi.com/products/amplifi-meshpoint-hd
    They are about $100 a device and worth it.
    https://amplifi.com/instant
    The real difference between all other systems and the newer current Mesh is that there are extra radios in each Mesh device to let the units all talk to one another to mesh where the older systems need to divide radio time between WiFi and talking to create the mesh network.
    Because of this the older systems are about half as fast if they work to mesh at all and they are also not really less costly at the same time.
    This stuff just changes too fast and it is hard to keep up with for sure but this is what I do every day and it really makes people happy that have had bed WiFi for years and just had to live with it.
  10. Dec 3, 2020 at 6:22 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Linksys RE6700 AC1200 ~
    Range Extender
    Motorola MG7550 ~ Modem/Router combination
    I bought these two devices which linked together seamlessly to run my wireless network in my home.
    Required because the router is on one of the house and the Smart TV is downstairs and on the other.
    They have been working well for me ~ they've been in operation for one year now.
  11. Dec 3, 2020 at 6:24 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I had the Shaw (Canada) wifi extender pods which are exactly the same as the Xfinity (Comcast USA) xFi wifi extenders. They were successful at extending range but it severely slowed down speeds. Plus they are a monthly rental - not recommended.
  12. Dec 3, 2020 at 6:32 AM
    PJR202
    PJR202 New Member
    Not trying to sound like an a-hole here, but your data is being mined and collected everywhere by everyone. There literally is no getting around it. Apps on your phone are listening to everything you say. This is not me being paranoid. I've tested it many times. It really sunk in one morning when I was near my wife's phone and sneezed, and a couple minutes later she got an ad for tissues on her pandora screen. That's just how it is, and there's no going back. Data is more valuable than gold at this point, and google is probably the least of your worries. I did a mental face palm the other day after giving my wife my credit card info verbally. Like, how stupid can I be? Haha
    On a related note, the targeted ads related to my conversations basically stopped when I used a microphone blocking app, but it became inconvenient when I needed the mic for legitimate purposes.
    BravoDeltaRomeo likes this.
  13. Dec 3, 2020 at 6:39 AM
    timsp8
    NY
    But at the same time, if you’ve ever used your cc online or even at a gas station then it’s out there. I’ve read that even websites that claim they don’t store it have been hacked and the info was stolen.
  14. Dec 3, 2020 at 6:40 AM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    I have Google Fiber, and the wireless that was provided is garbage. I bought a Ubiquiti UniFi AC Longrange Access Point and have had no issues throughout the house or outside.
  15. Dec 3, 2020 at 6:46 AM
    fundra_goes_west
    Evan
    2022 SQ8
    Not an a-hole at all. I totally agree. And it’s not paranoia at all. I just try and avoid giving the king of data collection any more. And I agree again there’s not much you can do, but one thing you can is not put more monitoring devices in rooms in your house. I use Linksys for this reason to avoid google and Amazon. I think we’ll look back and see google is one of the worst companies to walk the earth (yes google is practically living, walking and breathing at this point). Sorry I’m done hijacking to each their own and nothing but respect
    kenomouth64 and PJR202[QUOTED] like this.
  16. Dec 3, 2020 at 6:50 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    WHere do you need signal at, is it a specific spot, or is it in general?
  17. Dec 3, 2020 at 6:51 AM
    shakezoola
    Kansas City
    I was speaking at a tech conference last year and was talking about how much storage the typical person generates is a single day. One of the many ways is from connected devices "listening" to everything you say, even when the microphone is off or disabled. I told a story about a conversation I had with my wife about buying a new mattress. The next thing you know, I had ads for purple mattresses in my e-mail and on web pages. After I was done speaking, a few members of the audience found me and said they had ads for purple mattresses on the mobile sites on their phones. One attendee had an ad for a mattress of a different brand.
    Devices are collecting data and listening. Be careful what you do and say... some can even see you.
  18. Dec 3, 2020 at 6:53 AM
    kenomouth64
    Tetrus
    I very much agree with you. Have you researched \Edward $no wden? Well, if you have not, you can watch his movie and get a good idea of the technologies that are being deployed against everyone, now it is not just the government (that was bad enough...). It is also tech companies who hope to manipulate our belief systems.
  19. Dec 3, 2020 at 6:55 AM
    kenomouth64
    Tetrus
    It is futile to worry about your credit card getting stolen... Just don't let your debit card get stolen! if you are really worried about it, get a cryptowallet and use that to make purchases online.
  20. Dec 3, 2020 at 6:57 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I hang "Smart? TVs every day and of course they are listening and often watching every room they are in all the time too.
    I try to explain to the customer both sides of this feature but most are much more interested in being able to talk to the TV instead of needing to pick up a Remote and operate it these days.
    Maybe they are just Lonely?
  21. Dec 3, 2020 at 7:11 AM
    shakezoola
    Kansas City
    Well, if they are lonely, they can mention a few key worlds that may provide a visit from members of a three letter organization.
    ezdog[QUOTED] likes this.
  22. Dec 3, 2020 at 7:14 AM
    timsp8
    NY
    I’m not worried. I use my cc and have had the # stolen before. The cc company was good about taking care of it. The person I quoted said he turned off his device’s microphones but accidentally said his cc # out loud. I was just pointing out that if you use your cc, the number is out there.
    kenomouth64[QUOTED] likes this.
  23. Dec 3, 2020 at 7:18 AM
    What the!?
    What the!? New Member
    2017 Pro
    Skip the extenders. I spent years chasing them between Apple/Netgear with different setups.
    I finally went mesh with a Netgear Orbi and have no drops/lags/etc. I know it’s a bit more expensive, but not having to deal with the frustration of dead spots and drops is well worth it over the long run.
    Bammer[OP] and YardBird like this.
  24. Dec 3, 2020 at 9:48 AM
    bft305
    bft305 New Member
    2016 tundra limited
    Another vote for netgear orbi, had it for about two years and it has been great!
  25. Dec 3, 2020 at 10:06 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Google "google ledger" and watch the video. Google has not blocked the link ass of today. If you find it blocked, use www.duckduckgo.com to search for it. Google is EVIL!
    I bought a "Smart TV" a couple of years ago, but it is still as dumb as ever. I just never connected it to any network. I also don't get the Samsung ads that others complained about since it has no access to the Samsung advertising network. I just connect my streaming device (Apple TV 4th gen) to it. No ads other than was is broadcast, and no sign of targeted ads.
  26. Dec 3, 2020 at 10:09 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  27. Dec 3, 2020 at 10:24 AM
    mountainpete
    Simple truth: if you get something for free, you are the product and not the customer. As a product, someone is paying for your data.
    fundra_goes_west likes this.
