Why won't some shops deal with spacers
Discussion in 'Wheels & Tires' started by Al D, Mar 26, 2018.
  1. Mar 26, 2018 at 6:05 AM
    Al D
    Al D [OP] New Member
    Al
    2018 Tundra Platinum
    I would like to add some spacers to my OEM rims for a better look. 2 tire shops I visited say they won't touch them. One claimed they are only legal for off-road in California. With so many on this forum using them, they must be safe. Any idea's why shops don't like them?
  2. Mar 26, 2018 at 6:10 AM
    Why don't you just install them yourself? I haven't heard of any safety issues here on the forum. Certainly don't think so at all with OEM rims.
  3. Mar 26, 2018 at 6:10 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    There are many cases of issues with them, wheels actually coming off the vehicle, in different ways, sometimes shearing lug bolts. Most of these cases are bad installations, or applications. Some shops just do not want the liabilty.
    NewImprovedRon and Black Wolf like this.
  4. Mar 26, 2018 at 6:13 AM
    This^^^. I've seen some pretty crappy one size fits all spacers I'd only use for a paper weight. There are some real good spacers out there that are made for 5X150mm only which some guys are using here without problems.
    Trooper2 likes this.
  5. Mar 26, 2018 at 6:22 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Wheel spacers are illegal in Utah. I still run them on the 4runner with zero issues for over 10k miles.
    As others have stated, make sure they are properly installed and torqued. Use a "permanent" thread locker and they are worry free. If you don't use thread locker you should check that they are properly torqued every 5k miles.
    Trooper2 and Black Wolf like this.
  6. Mar 26, 2018 at 6:30 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    there are risks but if you buy quality hub centric spacers, make sure they are torqued properly and use thread locker you should be fine. With that said if you are doing some hardcore off roading I would suggest new wheels with more backspacing but if pavement with some light off road is your primary use you should be fine.
    I don't have spacers on my Tundra but I ran 1.5 in G2 spacers on my Wrangler for over 100,000 miles with no issues. My use was primarily pavement with some off road mixed in but nothing like rock climbing.
  7. Mar 26, 2018 at 6:31 AM
    Trooper2
    JR
    Remember this from while back. I would personally not go over an inch (1") on any. if you want different look, get different offset wheels.
    Good Luck!
    Black Wolf likes this.
  8. Mar 26, 2018 at 6:34 AM
    Backslider
    Tooele, UT
    I have seen that post - I would bet my truck that those wheel spacers weren't properly installed.
    rons23 and Black Wolf like this.
  9. Mar 26, 2018 at 7:13 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    The OP in that threat posted later on that he had the lug nuts the wrong way around - i.e. they were not installed with the cone side towards the spacer, so the nuts were not installed 'centric' the way it is supposed to be. He admitted that it was his fault.
  10. Mar 26, 2018 at 7:43 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I would recommend Spider Trax or Bora wheel spacers as they're hub and wheel centric. Properly installed you shouldn't have to worry. I ran some Spider Trax for roughly 15k w/o any issues.
  11. Mar 30, 2018 at 6:03 AM
    Al D
    Al
    Thanks everyone. I’ll give the Bora or Spiders a try.
  12. Mar 30, 2018 at 6:16 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Its all about the install. I ran 1.25" on my Tacoma for a year+ without an issue and never even gave them a second look after I checked them when first installed. Lock tight on the spacer to hub and torque the wheel lugs to spec and it should be fine, especially if you rotate like you should...
  13. Mar 30, 2018 at 7:06 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Just to clarify terminology, spacers go in between the hub and wheel and reduce the amount of thread the lugs have to grab on to. Wheel adapters, such as spiders and Bora bolt up to the hub and then the wheel bolts onto the adapter. The adapter is torqued and maintains factory specs. I would never recommend running spacers especially when wheeling.
    I've ran spiders on multiple trucks for years with no issues on and offroad. As long as you use thread locker and torque. Discountnt has tried to tell me a couple times that they won't deal with the spacers. I just corrected them and told them they are adapters with the same lug pattern and that ends the conversation.
