Why no new posts in the engine failures thread?
Discussion in '3rd Gen Tundras (2022+)' started by BoulderGT3, Jun 15, 2024.
  1. Jun 20, 2024 at 9:45 AM
    #211
    testerdahl
    testerdahl New Member
    Journalist
    What I'm saying is Toyota already narrowed it down by VIN and then cross-referenced those VINs with the plant schedule. They can identify the time and day when those engines were built.
    For example, when I wrote the follow-up to the Million Mile Tundra story, they were able to tell me the day and time that the engine was built. They also know how fast an engine takes to be completed.
    The second part of the potential pool has to do with oil analysis IMO. Until they do an oil analysis of all 102k affected trucks, they won't be able to narrow it down any better. it isn't like the wrong part was installed. This is a lot tricker to narrow down.
    Newm, WesternDawg, Hobbes and 5 others like this.
  2. Jun 20, 2024 at 10:35 AM
    #212
    Exec_TRD
    Exec_TRD New Member
    2024 Tundra Limited TRD Off Road
    I think it’ll be fine. Your oil will tell the truth, at the end of the day. I plan on giving a black stone bottle to my service guy when I bring it in, December.
    CorpsMarine[QUOTED] likes this.
  3. Jun 20, 2024 at 10:47 AM
    #213
    kololas
    kololas New Member
    2023 Tundra Limited
    23 Hybrid here with 7/23 build date. Does the engine have a different build date then what is on the door sticker.
  4. Jun 20, 2024 at 10:53 AM
    #214
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    word on the street is the engines are a few weeks older
  5. Jun 20, 2024 at 11:28 AM
    #215
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    I would have expected that Toyota as part of the engine problem assessment and extent of condition would be analyzing oil samples for the trucks it services.
  6. Jun 20, 2024 at 12:21 PM
    #216
    Exec_TRD
    Exec_TRD New Member
    They may be. I forget the specific issue, might have been fords issue with the 2.7L ecoboost, there was talk of them partnering with blackstone for oil sampling.
    Other than that I’d be not surprised to find out that toyora dealers working on tundras are sending oil samples from customer units back to HQ for analysis. They already have the medium to do it and it’s the 2yr Toyota care.
  7. Jun 20, 2024 at 12:26 PM
    #217
    40man
    40man New Member
    I'm not sure how helpful an oil analysis would be. If it is a big chuck of debris, and it embeds/damages the bearing (as bearings are soft metal for this reason, but I assume the debris is too large to absorb without damage) to prevent it from getting proper lubrication, it may not show up in a sample until the bearing starts failing.
    It is also very possible that if any problematic debris was in the engine, it also could have been flushed out in prior changes, and the damage is done and the engine is a time bomb, which makes sense as Toyota admitted many good operating engines showed signs of bearing damage.
    So it seems like a physical inspection may be the right step. I assume they can get access to at least most of bearings with the oil pan removed.
  8. Jun 20, 2024 at 12:28 PM
    #218
    eddiefromcali
    Eddie
    100% Stock
    Arent I glad I've been sending samples all this time now :)
    Exec_TRD likes this.
  9. Jun 20, 2024 at 3:00 PM
    #219
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    The engines are built in Alabama and shipped to Texas where the truck is assembled, so no the engine build date is not the same as the vehicle build date.
  10. Jun 20, 2024 at 5:15 PM
    #220
    winchester44
    winchester44 New Member
    2016 1794 4WD
    did we determine if engine block is cast and machined in both Alabama and Japan? Or all cast and machined in Alabama and some shipped to Japan for final engine assembly?
  11. Jun 20, 2024 at 5:16 PM
    #221
    winchester44
    2016 1794 4WD
    Tim do you have a YouTube channel?
  12. Jun 20, 2024 at 5:42 PM
    #222
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    This guy knows. I’ve had people having sex, doing drugs, getting drunk, and generally doing nothing during those shifts. They look good on paper (we can utilize all of our capacity! they cheered with glee in the boardroom) but rarely are they productive. I spent a short lived stint with monstrous oil field services provider (not a manager) and we used to take naps when we had to work overnight. The main problem is finding qualified bosses who want to work a graveyard shift.
    Drew_Zee, ChucklesToy and tesilential like this.
  13. Jun 20, 2024 at 8:32 PM
    #223
    winchester44
    2016 1794 4WD
    Not one of those things would be tolerated on a Toyota assembly line......well maybe at NUMMI https://www.thisamericanlife.org/403/transcript
    22whatwedo[QUOTED] likes this.
  14. Jun 20, 2024 at 9:28 PM
    #224
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I get a phone call everyday about my 12 year old truck.
    Today is the last day to purchase your extended vehicle warranty. Please call us back to discuss your options.
    Retired...finally likes this.
  15. Jun 20, 2024 at 9:56 PM
    #225
    tesilential
    tesilential New Member
    Tampa bay
    ‘24 limited lunar rock hybrid TRD off-road
    pretty sure they said they put “1” because you have to enter a whole integer value in that field but they believe it is less than 1%. Too lazy to look it up tho.
  16. Jun 20, 2024 at 10:10 PM
    #226
    eddiefromcali
    Eddie
    100% Stock
    Nope, report says they put one because they have to put something but that they don't know
  17. Jun 21, 2024 at 5:29 AM
    #227
    winchester44
    2016 1794 4WD
    Not correct, nowhere does the filing state “they believe it is less than 1%”
  18. Jun 21, 2024 at 5:31 AM
    #228
    No one seems to care about or absorb any of the facts that have been presented here. Just make up whatever “feels” right however they interpret them whenever they want.
  19. Jun 21, 2024 at 5:35 AM
    #229
    Retired...finally
    I believe you are correct sir.
    tesilential[QUOTED] likes this.
  20. Jun 21, 2024 at 5:37 AM
    #230
    Retired...finally
    I think you missed the but. I don't think Toyota officially said it was <1%. That's the best estimate of forum members gathering as much information from social media.
  21. Jun 21, 2024 at 5:40 AM
    #231
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    A "1" entered in that field means "unknown".
    KNABORES and winchester44 like this.
  22. Jun 21, 2024 at 5:40 AM
    #232
    Retired...finally
    A friend of mine answers spam calls and once the caller is done with their BS, he tells them now that I have you let me tell you about our extended warranty program for your car. Click.
  23. Jun 21, 2024 at 5:50 AM
    #233
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Nature made a solid state battery. Called hydrocarbon. Go beat its energy density.
    Extracting hydrocarbons to refine and burn them to produce electricity, deliver over long power lines with vast energy losses, just to charge something on the far left lower corner? Hmm...
  24. Jun 21, 2024 at 6:12 AM
    #234
    2wheelsforfun
    2wheelsforfun New Member
    Foothills AB Canada
    Great chart, thanks for posting that.
    RG7 likes this.
  25. Jun 21, 2024 at 9:42 AM
    #235
    winchester44
    2016 1794 4WD
    Sorry you used the third person pronoun" they" twice and I assumed you were referring to the same group. I now understand the first "they" was a reference to Toyota and the second "they" was a reference to the forum members.
  26. Jun 21, 2024 at 11:47 AM
    #236
    WingedHussar
    WingedHussar New Member
    Midwest
    2015 4Runner Limited
    I visited my local Toyota dealership today, I checked if there were any Tundras waiting for repairs, I only saw one Platinum that was already waiting to get picked up by the owner, I don't know why it was there, might have been simple oil change. I live in a big metro area and if engine failures were common, I would expect to see at least a couple of trucks waiting for repairs.
    There were probably 20 new Tundras in their inventory sitting on the lot though.
    winchester44 and WesternDawg like this.
  27. Jun 21, 2024 at 11:56 AM
    #237
    testerdahl
    Journalist
  28. Jun 21, 2024 at 12:16 PM
    #238
    40man
    40man New Member
    Most of this is anecdotal. Your dealer could have had 5 tundras torn apart in their bays waiting for engines.
    We have seen reports of late 23s and 24s failing, but it does not seem to be a huge number (but we only see what is reported on the internet).
    It is possible that the enhanced issue with the 22s and early 23s puts the spotlight on failures that could be within the "acceptable failure rate" and those are failing for other reasons. We just don't know. So that is why there are many theories, people speculating, etc., but the only facts are we don't know how many trucks it will actually affect both inside (other than the roughly 900 we know have failed) and outside the recall. We also know that "good" engines torn down by Toyota showed signs of bearing damage that will likely lead to failure, so there are a lot of trucks that will likely still fail.
    Hell, even Toyota admitted that they put 1% as a default in the notice to the NHTSA noting that the 1% indicated they have no idea how many are actually affected from the recalled vehicles.
    Not having more data is frustrating, but eventually all the data will come out.
    winchester44 likes this.
  29. Jun 21, 2024 at 3:58 PM
    #239
    10at6
    10at6 New Member
    Randy
    New 2023 Tundra Limited
    Well my 2023 Tundra was purchased in 8/23. It runs very well. I did a 600 miles trip last weekend over 2 mountain passes. It made 22 mpg. I highly doubt that debris in the engine is the problem. I had my local guy do an EOC at 6000. Every thing looked good.
    I'm an engineer and I think it's bearing design or bearing lube issues causing the failtures
    PGW85706 likes this.
  30. Jun 21, 2024 at 6:39 PM
    #240
    DimSum07
    DimSum07 New Member
    Steven
    Annandale VA
    2024 Silverado 1500 LZ0
    I'm struggling to believe what I've been told too. I'm also struggling to determine what brand of truck I'd want more. I like my Tundra and honestly, would just buy a '24 if I thought it was fixed (which I don't).
