Why are all the drain plugs different???
Discussion in '2.5 Gen Tundras (2014-2021)' started by jmevis, Nov 12, 2017.
  1. Nov 12, 2017 at 2:09 PM
    jmevis
    jmevis [OP] New Member
    Nashville TN
    2017 Tundra Trd Pro
    Crawled under the truck today to change out the front diff fluid.
    And I was expecting to use my 24mm socket, when low and behold it's a 10mm allen??? Taking a look around under the truck and realise that nothing is the same when it comes to oil/trans/rear diff/front diff.
    Oil its 14mm socket (standard on most cars)
    Rear diff was a 24mm socket that required a 1/2 drive wrench
    Front Diff is a 10mm allen
    Transfer Case looked to be a 3/8 drive? (square)
    Transmission was something else I can't remember.
    My previous 2007 FJ SE was all 24mm except the trans which was 10mm.
    Anyways thought it was weird.
  2. Nov 12, 2017 at 2:39 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    FYI
    Make sure to use the correct fluid for your T-case, Borg Warner case does not call for the same fluid and the front/rear diff. Straight 75w. Check into the other thread going on regarding this.
    Cheers
  3. Nov 12, 2017 at 2:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The transmission on my '11 has:
    14MM drain
    24MM fill
    4MM Allen check tube
