Who's running an add-a-leaf?
Discussion in 'Suspension' started by OBXTundra, Mar 6, 2018.
  1. Mar 6, 2018 at 4:16 PM
    OBXTundra
    OBXTundra [OP] Member
    2018 Nissan Armada, 4x4
    Pretty simple. Who's running an add-a-leaf?
    Looks like toytec and tuff country are the two most common. Currently have a 1" block that I'm trying to replace with a better option.
    I am most interested in an AAL because it will increase the load carrying capability of the leaf pack. I frequently run with some sort of load or cargo in the bed, frequently carry dirt bikes, tow a boat through the summer, and pull a 28' camper.
    Not interested in shackles or an entire replacement leaf pack. Really looking for those with add-a-leafs currently installed on their trucks. If you have one....Brand? Estimated rear lift? Satisfaction?
  2. Mar 6, 2018 at 4:17 PM
    COMiamiFan
    COMiamiFan SSEM #3. Don't forget to try the search bar.
    Jose
    Parker, CO
    2016 White Crew Max TRD
    boardude likes this.
  3. Mar 6, 2018 at 7:07 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Had an AAL. Now have the RXT leaf pack
    1UPPER likes this.
  4. Mar 6, 2018 at 7:14 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    IMO, an AAL is a great cheap temp solution. It adds height and may increase payload. However they do have a tendency to "W" your springs over time especially if you carry weight. It's nothing more than an extended overload leaf. They also tend to squeak which drove me insane lol.
    Considering the loads you frequently run I would consider CB shackles (also had +2s installed) or a new leaf pack. Or even a leaf pack expansion.
    SouthBoundSteve likes this.
  5. Mar 6, 2018 at 7:17 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    And to answer your questions:
    Toytec AAL, about 1.25" rear lift (CM), made rear end stiffer with more "buck".
    Rica25 and dcsleeper408 like this.
  6. Mar 6, 2018 at 7:31 PM
    COMiamiFan
    Jose
    Parker, CO
    Oops :sorry:
    Rica25 likes this.
  7. Mar 6, 2018 at 7:32 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    I am running the Icon AAL it lifts the rear about 1.5 inches. It has only been on for few months but so far so good
    because_wumbo-truck likes this.
  8. Mar 6, 2018 at 7:33 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Lol no worries. Was a recent upgrade
    COMiamiFan likes this.
  9. Mar 6, 2018 at 7:34 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I have Deaver aal from Toytec. I got 1 & 3/8 inches of lift in the rear. I was worried about the ride (read a lot of reviews) but the ride is not bad at all. The rear doesn't sag as much when loaded.
  10. Mar 6, 2018 at 7:36 PM
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    I have the ICON 1.5 AAL purchased from Toytec. I went with that because it adds secondary leafs while keeping the factory main and overload leafs. They advertise it adds about 1.5" of lift but I got closer to 1.25". Since you retain the factory overload it supposedly has the same load capacity as stock. I also have the Coachbuilder +1 shackles for a total of about 2" of lift in the back. I think the ride quality and bed bounce is about the same with the AAL and shackles as it was stock.
  11. Mar 6, 2018 at 7:42 PM
    Vizsla
    Vizsla New Member
    Dave
    Arizona
    2018 Cement Crewmax
    Honestly, I’ve lived many places, and always lifted every truck I’ve owned. There has always been some kind of spring shop near enough to go to. Before you buy an add a leaf see if one is near. Call them, tell them what you want. Might be surprised what something made just for your needs cost with a little bit of your time.
    And I’ve tried many add a leafs, they all either squeaked, sucked, or both.
  12. Mar 7, 2018 at 4:33 AM
    OBXTundra
    The RXT leaf pack looks awesome, and if I wasn't frequently hauling things or hooking up to a trailer this would be the route I would go. Icon does advertise the RXT as decreasing the spring rate, so this wouldn't work for me, or at least not help me.
    The Icon expansion pack has a lower spring rate than stock. It initially looked like a really nice option, but ultimately I don't think it's right for my application.
    Shackles would be easy, but again, I'm left with a factory leaf pack that will still handle weight the same way.
    The add-a-leaf seemed like an easy solution to 2 issues. I want to remove my 1" block, keep the rear lifted, and I would like to improve load carrying ability slightly. But it looks like most have had mediocre results with an AAL.
  13. Mar 7, 2018 at 4:38 AM
    Black Wolf Addicted to petrified wood apparently
    Aurora CO
    2014 Blaaaaack, 5.7L DC Limited TRD 4X4
    Zone UCA's, Fat Bob's Vated, Pro Form Fab shackles, Patagonia M/T's, Ranch Hand Grill Guard, RC steps, SDHQ AIP relocation kit, RetraxONE MX, Jomax ABS armor
    My truck came with an AAL. Not sure at all what brand but at least an inch. No issues so far. Using ToyTec shackles. I plan on swapping to the Dakars at some point to complete my OME setup.
    OBXTundra [OP] likes this.
  14. Mar 7, 2018 at 6:52 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    The RXTs are multi-rate and configurable depending on the amount of constant weight you carry. This was one of the reasons I went this route since I constantly haul and tow as well. Many guys that have these are running bed racks and rtts. @dcsleeper408 just reconfigured his to account for his weight in the bed. I'll be doing the same when I get my chase rack and before boating season.
    AALs are a good option and def an upgrade from the block. Everyone's needs and setups are different so there isn't 1 "best" solution. The 1 common factor though is regardless of our setups we are all chasing that perfect rear setup lol
    OBXTundra [OP] and dcsleeper408 like this.
  15. Mar 9, 2018 at 4:51 PM
    OBXTundra
    Anyone else running an AAL or the RXT pack and towing regularly?
    Looking for longevity of options that frequently carry weight.
  16. Mar 16, 2018 at 5:55 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    i had one on my tacoma for about 150,0000 miles, i never had any issues with it. i towed trailers and threw way more weight in the bed than i should have on numerous occasions.
    i am going to put one on my tundra in a couple months when i lift it. i never had any issues with mine making noise. i remember seeing on Tacoma world of folks having issues with noise and they would cut a bicycle tube and put it between the leafs.
  17. Aug 25, 2018 at 9:25 PM
    newguy209
    newguy209 New Member
    Central CA
    I have the icon add a leaf 1.5" and its super bouncy in the back vs stock, is that normal? Could they have possibly installed it wrong because they did the first time by not removing the stock secondary leaf. It also looks like it added more than 1.5" of lift.
  18. Aug 25, 2018 at 9:43 PM
    newguy209
    Central CA
    no bounce?
  19. Aug 26, 2018 at 2:46 AM
    Twinky
    07 double cab work horse
    My truck came with the hellwig's AAL and leaf spring helpers. Previous owner i believe hauled horses.
    Currently i havent really had to load/haul anything other than the tools i use during a typical day. The LSH(leaf spring helpers) i ended up removing.
    The ride quality wasnt bad but on a few spots here and there that i travel it was noticable.
    Subjectively the ride quality a person experiences is a comparison vs their last vehicle. A truck with a little hop and a skip here and there is what i expect and am accustomed to. Someone who is coming from a luxury feeling ride probably wouldnt be able to stand being in a truck that felt like mine did.
  20. Aug 26, 2018 at 3:29 PM
    newguy209
    Central CA
    Holy crap I think I just found out why I’m getting bounce. Shouldn’t have trusted these guys a second time. 9546905A-4847-4921-97E4-8DDF7BF53612.jpg
  21. Aug 26, 2018 at 3:49 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Wow, luckily noone was hurt/killed.
    On another note, I added a wheelers add-a-leaf. Greatly reduced the sagging while trailering, rides just like stock. Only thing is it lifted 2" Instead of 1" as advertised. After a few thousand miles it has not settled. Not a bad thing, but with 5100s on top setting on the front, the rear is still 2" higher like the factory rake.
    newguy209 likes this.
  22. Aug 26, 2018 at 3:50 PM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    You caught it in time.
  23. Aug 26, 2018 at 4:02 PM
    TundraLaw
    TundraLaw Third Year Member
    Northern Nevada
    I have the Icon stage 2 with the 1.5 leaf pack, and like previously said, it keeps the bottom leaf and replaces the others. I think it’s great. I don’t tow anything though, and will likely never tow anything.
    Thinking about adding toytec shackles though. Would it work? @Toytec Lifts
  24. Aug 26, 2018 at 6:20 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    Just go buy a 3/4 ton truck and be done with it
    blackCat1 and TundraLaw like this.
  25. Aug 27, 2018 at 6:55 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    It's actually a nice ride for being stiffer then stock.
  26. Aug 28, 2018 at 9:43 AM
    TundraLaw
    Northern Nevada
    have the ICON 1.5 AAL right now on, and was thinking about the CB +1 Shackles. Did you notice the leaf pack got flatter when adding the shackles?
  27. Aug 29, 2018 at 11:21 AM
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    They may have flattened out a little. I only say that because the ICON AAL advertises 1.5" and I think the CB +1 shackles are supposed to be about .625". So together that should be 2.125" but when I measured I was just shy of 2" total. So either the AAL didn't provide the total advertised lift to begin with or they flattened out a little with the larger shackles. But just by look it isn't really visually noticeable if they flattened out.
    Rica25 likes this.
  28. Jul 27, 2020 at 1:26 PM
    majerrahim
    majerrahim New Member
    do you happen to have the secondary middle oem leafs?
  29. Jul 27, 2020 at 1:27 PM
    majerrahim
    do you happen to have the middle oem leaf that was removed?
  30. Jul 27, 2020 at 1:31 PM
    majerrahim
    does anyone her that have the icon aal or any leaf pack,, I am looking for that secondary leaf both sides to buy, thanks
