Who's gonna wait for 10k miles before 1st oil change?
Discussion in '3rd Gen Tundras (2022+)' started by Silver23, Jan 22, 2023.
  1. Jan 26, 2023 at 9:18 AM
    #91
    Reddhills
    Reddhills New Member
    ‘23 Army Green Hybrid 1794, TRD
    Why aren’t we rolling with magnetic plugs like we have on the diff?
  2. Jan 26, 2023 at 1:56 PM
    #92
    catalac
    catalac New Member
    Isn’t that what the oil filter is for?
    hagrid and Rb123 like this.
  3. Jan 26, 2023 at 4:47 PM
    #93
    Rb123
    Rb123 New Member
    Washington
    22 trd off-road crewmax mgm
    Bfg at 275/70r18 Lowmax Bumpershellz grill
    C4552062-D45E-4C4B-8E84-1D82793A6DD4.jpg The owners manual states, “perform these service items only if you drive PRIMARILY under the conditions indicated”. No need to change your oil early. The oil filter will do its job even during breakin. Here’s my dipstick at 7000 miles. That being said, do what makes you feel good. I’ll be changing at 10,000 miles. I’m 50 years old and I’ve been driving Toyotas all my life and I just follow the owners manual. Never had an engine or transmission problem.
  4. Feb 27, 2023 at 4:05 AM
    #94
    Hike5
    Hike5 New Member
    2022 Tundra Limited Crewmax
    I just did my 1st at 5K and will probably stick to 5K intervals, but the oil looked fine and should have no issue going the recommended 10k.
    Kap1 likes this.
  5. Feb 27, 2023 at 6:27 AM
    #95
    raylo
    raylo not so new member
    Frederick, MD
  6. Feb 27, 2023 at 6:47 AM
    #96
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    Manuals nowadays are different than what they used to be but mechanics have stayed the same I trust them or an engineer more than the manual because I'm sure Toyota like their competitors is just tryna lower maintenance costs at the expense of its longevity. Or just watch car care nut and you'll see why some owners really take care of their trucks because no one else will care for the truck the way you do.
    WAtundra4x4 likes this.
  7. Feb 27, 2023 at 7:10 AM
    #97
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Meh, I have had many 2.5 gen Tundras and never had an issue waiting 10K for first oil change (granted I haven't kept most of them beyond 30K). My current Tundra is 2.5 years old with 35K on the ODO and it has only had three oil changes, still running smooth, no issues!
    I suppose the 2022 is a bit different because it is Turbo, and supposedly those require more frequent oil changes? I guess it wouldn't hurt to do it more frequently, but maybe unnecessary, or even extend it to every 5K, I think 2500 is overkill. I have a Honda CRV 2022 with a turbo and even that only requires oil every 6K or so.
    -T
  8. Feb 27, 2023 at 8:04 AM
    #98
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    I did my first oil change @ 1k, will do one more for 2,500. Thereafter every 5k or 3k if I use some E85.
    it seems this engine does have a rather robust system to keep temps in check for what it’s worth.
    Here are couple videos that explain the new engines 40% thermal efficiency.
    Take it for what it’s worth.
    https://youtu.be/wwLxxZm_LRQ
    https://youtu.be/VzYbmDNNWRQ
    TundraDan723, pwpblue and Kap1 like this.
  9. Feb 27, 2023 at 2:23 PM
    #99
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    I talked to my dealer today about getting first oil change at 2500 miles. They told me that Toyota runs oil through the engine after assembly to wash out the debris. Then refills with the oil the vehicle comes with. So no need to consider anything earlier than 10k for the first change. I'm thinking a lot of people here will have an issue with that. But does anyone know if this idea of Toyota washing it out after assembly is true?
  10. Feb 27, 2023 at 2:33 PM
    #100
    Kap1
    Kap1 New Member
    San Francisco, CA
    My favorite person here may know @wedemmoez
    wedemmoez and Retired...finally like this.
  11. Feb 27, 2023 at 4:10 PM
    #101
    Aces and 8s
    Aces and 8s I Turn Wrenches
    2023 Tundra CM Ltd
    I'll be sticking with a 5,000 mile interval personally.
    iforceAZ likes this.
  12. Feb 27, 2023 at 4:22 PM
    #102
    wedemmoez
    wedemmoez New Member
    2022 Black Tundra TRD Pro
    10k miles for a service interval is fine, 5k is early for synthetic oils but honestly do whatever you want.
    if you really want to know what your ideal service interval is, send your oil to Blackstone Labs. After 4/5 oil changes, they’ll be able to nail down your perfect interval.
  13. Feb 27, 2023 at 5:52 PM
    #103
    Paul Moll
    Paul
    Idaho
    Thanks @wedemmoez
    I understand that 10k may be ok for the synthetic oil, in terms of how long the oil is doing the proper lubrication. But I think the question here is, are there really nasty bits, metal shavings etc, in the engine that are being pushed around in the oil and damaging the metal on metal points/surfaces? I would have also add in that these would not be captured by the filter too. After all, isn't that the filters job?
    So IF my dealer is correct that Toyota has mitigated the production/assembly nasty bits and the filter is doing it's job, then indeed there is no advantage to a pre-10k first oil change. Note that I said "advantage" rather than "need". I suspect that even if Toyota has done as advertised that some will still say there is a "need" because nothing is perfect at washing out and capturing the nasty bits. That logic I suppose would also carry on through the life of the engine as it seems to me that those nasty bits can always become dislodged and contaminate the oil even at 50k-100k miles. Maybe I'm dead wrong on that last part, just trying to be rationale about this.
    OK, let 'er rip, tear into me now :)
    :duel:
  14. Feb 27, 2023 at 6:23 PM
    #104
    wedemmoez
    you’re right, there’s no need for an early oil change. There’s 2 different mesh screens and an oil filter that oil passes through before it gets sprayed into the rest of the engine. Any metal shavings will get caught in those before they can cause any issues.
    But oil changes are cheap and if the user wants to do it, it’s up to them. No harm in having shorter oil change intervals except to your wallet.
    the metal shavings are also a largely overhyped concern. It’s such a minuscule amount of metal that it very very rarely causes issues.
    The reason you see metal shavings in failed engines is because those are the result of most failures, not the cause.
  15. Sep 16, 2023 at 12:05 PM
    #105
    Combatmedic23
    Combatmedic23 New Member
    Graham
    2023 tundra limited
    Lift and 20” wheels
    I just traded in my Tacoma for a tundra limited 23’. I’m at 1,900 miles. I’m gonna change mine as well. So check this out—— in the past 3 years I’ve had 2 brand new Tacoma off roads. Both came from the same dealer. I’m convinced the oil that these trucks come new with is lesser quality than “high grade” synthetic that you can go out and buy. 2023 Trd Tacoma running- you can hear a lot of the engine noise with the stock oil, then changed it to some random all synthetic oil brand……motor was literally “close to silent”. Additionally, I’ve seen the huge oil drums they use at the Vancouver Toyota dealer. They are like 500 gallon drums of what appears to be “hybrid synthetic or 50/50”. Just my opinion here. Love the tundra. So freakin cool. Mines on 35” bfg’s and I’m getting on average 18.7 mpg.
  16. Sep 16, 2023 at 1:18 PM
    #106
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Welcome to the forums!
    Combatmedic23[QUOTED] likes this.
  17. Sep 16, 2023 at 2:11 PM
    #107
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    Thank you @wedemmoez , it almost feels like people think there are gravel sized metal shavings floating around in their oil. But if you really have gravel sized metal shavings in there, perhaps 5k oil chang won't help it.
    Unrelated: Sweet, my odo is reading 1,111 posts, all on original oil!
  18. Sep 16, 2023 at 10:45 PM
    #108
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I am at 4,100 kms (~2,500 miles) and changed the oil today. The old oil was very dirty and dark. It had a noticeable smell of gas.
    Most of our kms are city and lots of idling.
    I can’t see that oil lasting another 12,000 kms that the service tech told me that it would.
    I put some Penzoil full synthetic in and hopefully it will last 5,000 kms.
    Combatmedic23, Kap1 and WAtundra4x4 like this.
  19. Sep 17, 2023 at 11:27 PM
    #109
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Changed mine today at 2000. It was a lot darker looking than 2000mi oil in my ‘16 Tacoma. Didn’t find any debris at all. Oil is cheap. I’ll sleep better tonight.
    PBNB and WAtundra4x4 like this.
