Who has installed retrofits already?
Discussion in 'Lighting' started by gdiep, Nov 15, 2016.
  1. Nov 16, 2016 at 2:47 PM
    gdiep
    gdiep [OP] I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Did not get switchbacks. I honestly don't like the look. I have it on my Durango when I modded the factory setup.
  2. Nov 16, 2016 at 2:47 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I dont know for certain, but I'd assume it taps into the current headlight fuse.
  3. Nov 16, 2016 at 2:48 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Humm.. I'm currently trying to figure out how I want to do it, delete factory DRL w/ switchbacks, or no switchbacks and keep factory. If you dont mind, how much did you pay for them? PM if you'd like.
    OH, and did you get the 4.0 projectors?
  4. Nov 16, 2016 at 3:05 PM
    gdiep
    Syracuse, New York
    I got the better of the two budget retrofits that start at $400. When you add the led strip, the panamera shroud which costs more, and the harnesses, it comes out close to $590. I think I am going to keep my oem lights, which costs $300. There are fees with using paypal and shipping charges for the lights. Overall, probably close to $1000 (if I keep my oem lights).
  5. Nov 16, 2016 at 4:04 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Yes I kept my amber DRL cause I like the look with the LEDs, just my thing. I wish I can find amber LEDs without the need of resistors. No my LEDs do not switch back. They stay on like that all the time.
  6. Nov 16, 2016 at 4:06 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    That goes in ur ignition fuse. You take out your ignition fuse and plug that one in. It's for DRL LED strip.
    iHacker likes this.
  7. Nov 16, 2016 at 4:38 PM
    gdiep
    Syracuse, New York
    So this replaces the ignition fuse? Anyone have the fuse location number?
  8. Nov 16, 2016 at 6:03 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Yes it sure does. Just look on the back of the fuse box cover, it tells you.
  9. Nov 16, 2016 at 6:26 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    With this harness your LED DRLs intensity dim while headlights are on or they are constantly at the same intensity?
  10. Nov 16, 2016 at 6:39 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Constantly same intensity. Looks awesome
    iHacker[QUOTED] likes this.
  11. Nov 16, 2016 at 6:47 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    In case this could help, if you check my sig (if on a mobile device, turn sideways to see sigs) I did a DIY on my retrofit. I used an add a fuse in my ignition fuse to power my demon eyes. Although they have switchback capabilities, I didn't want to use it, so they have nothing to do with my DRL's, they are wired independently and are always on if my ignition is on the on position. They do have a sensor that automatically turns them off if my headlights are on.
    iHacker likes this.
  12. Nov 16, 2016 at 6:51 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    Thanks for the info, retros are in my mods wish list :)
    Y0TA PR0[QUOTED] likes this.
  13. Nov 16, 2016 at 7:16 PM
    eledobleu
    eledobleu retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    That wire replaces the ignition fuse in the fuse box. The other two connectors will plug into the LED connectors on the lights (connectors in the corner of the lights by the orange side reflector). The oraange wire next to the LED connectors on the lights are the switchback wires. If you do decide to install them, you need to splice into the turn signal harness on both sides (red driver side, pink passenger side) and complete the Amber DRL Delete mod.
    The silver plug connected to the projector is the igniter. Its already connected to the bulb so you just need to plug it into the ballasts once you have everything setup. The black connector coming from the same location is the high beam and plugs directly to the relay harness. It will be labaled "high beam".
    Man I really need to make that how to thread for the install lol.
    stefan702, MotoTundra and TexasMofo like this.
  14. Nov 17, 2016 at 9:12 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    Love it...very OEM looking. Black painted bowl and chrome bezel.
    Question: In DRL mode, the NEW Halo and LED strip will be on. What about your OEM Amble light? Is it on or off?
  15. Nov 17, 2016 at 9:33 AM
    gdiep
    Syracuse, New York
    I am leaving the Amber light on. The lights are prewired to make the led strip a switchback in the event that I want to do the amber delete. See Eledobleu's post right above. However, I dislike the look of switchbacks (just my opinion) and I want the led's to be on all the time.
    Y0TA PR0 likes this.
