Whining noise when accelerating
Discussion in 'General Tundra Discussion' started by BigT1983, Mar 16, 2022.
  1. Mar 26, 2023 at 7:27 PM
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    How many miles do you have on the power steering fluid? I have an appt tomorrow for my 2020 sequoia with only 20k miles so hopefully it makes the sound.
  2. Mar 26, 2023 at 7:39 PM
    NDTundra18
    NDTundra18 New Member
    Andrew
    Fargo, ND
    2021 SR5 MGM CM
    My truck does this with every start in the winter. I have not taken my truck to the dealer for this yet. I did capture a video and it sounds identical. From all the threads I’ve found on this I don’t see any resolution which is why I’m not jumping to bring it in.
  3. Mar 26, 2023 at 7:46 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Oh maybe... 5k? Tops?
  4. May 5, 2023 at 2:52 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Mine has been making a whining noise for about a month now. Started out of nowhere and it is most noticeable right when I start it and then less once it’s warmed up but it’s always there when starting to accelerate from a stop. It follows engine speed and rpm’s while shifting, not vehicle speed. My first check was power steering fluid level as my old 4runner had a power steering fluid leak and the sound is almost identical to that of the power steering pump when low on fluid. No leaks and fluid level is normal on the Tundra. It sounds like the general area of alternator, water pump or power steering pump though. Anyone else find a fix for this yet?
  5. May 5, 2023 at 5:01 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    Subbed. Mine makes the exact same noise, but only when the truck has been sitting out in the cold.
  6. May 5, 2023 at 9:54 PM
    TRDpro4x4
    TRDpro4x4 New Member
    2016 TRD DC 5.7V8
    Surprisingly so many here waiting for a solution yet nothing, Isnt it possible to spray wd40 or something liberally at the fan bearing, may give some answer unless the oil doesnt penetrate (if sealed)..
  7. May 9, 2023 at 5:45 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    My spit balls would involve:
    Alternator
    Compressor
    Serpentine belt & pulleys
    Sounds like a wind-up flashlight or turbine; which is why I think alternator.
    My sister has an 07 liberty and the failing compressor sounds similar.
    Almost sounds like the belt is skipping or a pulley siezes up for a second.
    Idk, sounds like you all have checked a lot of other options off the box.
  8. May 26, 2023 at 8:38 AM
    N0RTH3RNB0YZ
    N0RTH3RNB0YZ New Member
    Taylor
    2016 Tundra TRD PRO
    Lift, spacers, 35 Toyo M/Ts, leds, steel front bumper with 50” led top mounted light bar, trd pro exhaust being replaced with muffler delete, side steps.
    I’m new to the group but have been reading on these threads for over 5 years. I sold my 16 trd pro 2 years ago and bought one recently that has had the same noise mentioned above.
    Mine sounds different under the hood as I’m assuming belt tensioner however the internal wine sounds the same. I am assuming fuel pump but the wine comes from rear of truck and I can hear more noticeably with rear window down, only when accelerating.
    tensioners are known in the Toyota world for tundras to go as well as the fans and water pumps around 60k. I will update with what we find later but hope this helps.
    New tundra is a 2016 trd pro white with 49256 miles.
  9. May 27, 2023 at 2:10 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I wouldn't spray WD-40 or any penetrating oil on anything that has a bearing, spins or has grease. Unless you have it apart on the bench and you're cleaning it. It's a solvent/penetrant, not a lubricant (yeah yeah, I know, it's advertised as,....yada yada).
    Sure, it helps to quiet squeaky hinges, etc,....until it evaporates. Anyway, penetrating oils are solvents and will dissolve the grease in bearings. Don't spray it on moving parts that have bearings/grease.
    Use it to get rusted nuts off of rusted bolts. Or, as a solvent/degreaser.
  10. May 27, 2023 at 2:16 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Sounds like it could be clutch fan.
  11. May 27, 2023 at 2:32 PM
    Markysharky
    Markysharky New Member
    Is the wife in the passenger seat, first thing I’d check?
    RichterScale and SWB Tundra like this.
  12. May 27, 2023 at 3:12 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    My wife and I used to wake up at the same time for work. She's wide awake as soon as she opens her eyes and 100mph. I'm more of a slow, coming out of a coma, I want everyone dead, kinda morning person.
    She would try talking to me as I did the zombie walk to the coffee pot and it sounded like R2-D2 on crack to me.
    She moved to a later schedule and I moved to an earlier one. I leave an hour before she even gets up now.
    We're still married.
    I did think about spraying her with WD-40 a few times. But I don't think it would've made the squeaking go away.
  13. May 27, 2023 at 4:11 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
  14. May 30, 2023 at 10:23 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Same.
    I tell people to not expect much from me until noon, and to be safe, make it 1 o'clock.
    RichterScale[QUOTED] likes this.
  15. Jun 18, 2023 at 9:21 AM
    N0RTH3RNB0YZ
    Taylor
    2016 Tundra TRD PRO
    The wind sound I had ended up being a belt tensioner and rear diff. Bought used so previous owner blew up rear diff.
    from what I had read, it could be water pump, fan, or tensioner if up front.
  16. Mar 18, 2024 at 5:46 PM
    Thundra96
    Thundra96 New Member
    Ricky
    2005 White Double Cab Tundra V8 4x4
    The '05 DC 4.7 I've owner for a couple weeks has had that sound since I got it. Only seems to have gotten slightly worse or I'm just noticing it more. Really bothers me as no other car has ever made such a loud and noticeable whirring sound under the hood, I almost thought it was a cracked manifold or exhaust leak but I'm not sure sure it's that anymore.
  17. Mar 23, 2024 at 2:19 PM
    Squeakyduck4
    Squeakyduck4 New Member
    Santa Barbara
    06 DC 4x4 V8 TRD
  18. Aug 20, 2024 at 3:32 PM
    Jswagg47
    Jswagg47 New Member
    2013 Toyota Tundra
    So mine has just started wining….wondering if there is anything anyone figured out. It does it when idling and when I start to pull away. I have a 2013 SR5. About 125k miles. Everyone is saying the fan bearing. It does sound like it’s coming from there but just cannot pinpoint it! Thanks!
  19. Aug 31, 2024 at 10:24 AM
    #49
    greentrbo95gst
    greentrbo95gst New Member
    Huntington Beach
  20. Aug 31, 2024 at 12:40 PM
    #50
    wcoastpi
    wcoastpi New Member
    Mario
    So CAL
    2024 Tundra Limited TRD Off Road 4X4
    This used to happen on my 2017 Tundra 5.7. It got progressively worst over time, until it was all the time. Turned out to be the alternator.
