While I was doing a valve cover gasket change….
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Oct 28, 2022.
  1. Oct 30, 2022 at 6:18 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    There's some question about the contents and whether it should be used as an oil additive. It is, however, a good penetrating oil and has a long history in radio controlled aircraft and car engines as an after run oil to prevent corrosion.
    https://en.wikipedia.org/wiki/Marvel_Mystery_Oil
    shifty`[QUOTED] likes this.
  2. Oct 30, 2022 at 6:24 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Weagle likes this.
  3. Oct 31, 2022 at 9:56 AM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Many years ago I worked as an aircraft mechanic. I worked in mainly
    Radial engines. Most of the work was resurrection of parked and pickled
    obsolete Military warbirds. The owner used to get a gallon of Marvel Mystery
    Oil. He removed every spark plug and sprayed in the oil. Not a lot, maybe 3 pumps.
    when it got time to start the engine, the MMO really smoked. We never had a cylinder
    not come back to life after decades of sitting. Considering the length of inactivity,
    the pre oil really worked.
