Which would you pick?
Discussion in 'Performance and Tuning' started by balou, Dec 12, 2016.
  1. Dec 12, 2016 at 12:07 PM
    balou
    balou [OP] Texas Tundra
    2016 tundra cewmax 4x4 tss option
    bilstein 5100 adj front shocks led lights for bed
    I was going to get some retrofits from @eldobleu. But i have a chance to pick up a brand new eaton h/p limited slip at half cost brand new but i need to have it installed above my skill level. Im leaning toward ls just because i do use my truck off road alot. Not hard core mostly loose sand and muddy terrain,but i do tow a tt quite a bit. Just looking for an outsiders view point. Im pretty sure im going to get ls wait a few months then get my retrofit done. Does anyone have experience with this unit and do you think its a better choice at this time
    dcsleeper408 and ColoradoTJ like this.
  2. Dec 12, 2016 at 4:51 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Depending how much you drive at night, you may or may not use your headlights every day. I have a 4x4 and it works great for me without the aftermarket LS. Think you may like the headlight conversion a little better. Flip a coin ?
  3. Dec 12, 2016 at 4:54 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Have you struggled at all yet or actually gotten stuck yet where a limited slip diff would have helped?? If not do you really think you will get in one of those situations where limited slip would be of assistance?
    If no then don't get the limited slip.
    joonbug likes this.
  4. Dec 12, 2016 at 4:56 PM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    I say go for the lights!
  5. Dec 12, 2016 at 4:58 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    I would do the LS over the Headlight mod anyday. The LS is my next mod
  6. Dec 12, 2016 at 5:06 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Whichever will be more useful for you. If you will definitely do both, and one is a killer deal that won't last, maybe go for the great deal.
    @csuviper has a good point. Have you been in a situation in which an aftermarket LS would have made a difference? If not, how often do you expect that to happen?
    The lights will probably be used more often, but may not be as important.
    Good luck!
  7. Dec 12, 2016 at 5:08 PM
    csuviper
    Broomfield, CO
    I can say that slipping and sliding in snow and a bit of gas on the pedal, the truck does a decent job as it is to keep you straight in 2wd.
  8. Dec 12, 2016 at 5:50 PM
    balou
    The tundra is my toy and only goes out on weekends. When i go fish, hunt, or golf. The limited slip is just to good of a deal to pass up. Im going to get both but think im going to do limited slip first. The cost is about the same for both with ls installed. I will just have to save up a few months after this and then i can get my retrofits. Yes i am in situations in the tundra where an ls would be a big boost in confidence especially when driving around in loose sand to surf fish and i think it would help when i tow my trailer.
  9. Dec 12, 2016 at 5:54 PM
    csuviper
    Broomfield, CO
    Well there you go. At that cost installed I would go that route then too.
  10. Dec 12, 2016 at 7:15 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    +1 for the LS
  11. Dec 12, 2016 at 8:15 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yup, definitely LS over headlights.
  12. Dec 12, 2016 at 11:15 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
  13. Dec 13, 2016 at 3:21 PM
    balou
    Picked up ls today. Now just have to find shop that can install it. If any of you san antonio guys can recommend a place that does good work would like to hear about it.
