Which wire harness?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tndra789, Dec 28, 2017.
  1. Dec 28, 2017 at 1:52 PM
    Tndra789
    Tndra789 [OP] New Member
    14 Crew
    Undercover flex Spyder headlights Trd exhaust 24 in KMC Slides Nittos on factory wheels
    So received the 2018 headlights for Christmas. The question is which harness do I buy? Want the most plug n play but worried about DRL being on high all the time. Should I be worried? Want the most factory look. Any cons or pros for either harness being offered?
    Thanks
  2. Dec 28, 2017 at 1:58 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I would run a harness that dims he drl. The drl is pretty damn bright on high. @iHacker makes a great harness that dims.
  3. Dec 28, 2017 at 3:05 PM
    geno0506
    geno0506 New Member
    Michael
    @iHacker sent me a top notch and high quality harness, all plug n play is what I wanted for ease!
    Black Wolf, classic17 and Newm like this.
  4. Dec 28, 2017 at 3:11 PM
    Tndra789
    14 Crew
    I want easy too. How did the install go.
    geno0506[QUOTED] likes this.
  5. Dec 28, 2017 at 3:14 PM
    geno0506
    geno0506 New Member
    Michael
    I have yet to install, will soon! PM him @iHacker I PM'd iHacker before I bought and he walked me through the whole process and then some, he is a standup guy, I choose his after talking to him and the ease of setup! He has been with every one every step of the way and that helped in my decision when buying!
    In the end I paid extra for the full pnp setup and is well worth what he charged because I know jack about wiring but I believe a monkey could install this bad boy!
    757TUNDRA likes this.
  6. Dec 29, 2017 at 7:54 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    The 2018 LED headlights use the "horseshoe" surround for DRL, highs or lows are not used for that purpose. If you buy a conversion harness your lights your 2018 LED lights should work the same way they work on my truck.
  7. Dec 29, 2017 at 10:15 AM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Get it from ihacker. Great guy and if you have questions he'll be there to answer them. He helped me a lot. I just installed mine the other day. @iHacker IMG_5847.jpg
    CJ21, Berdine, geno0506 and 2 others like this.
  8. Dec 29, 2017 at 10:31 AM
    Hookee
    Hookee New Member
    2016 Toyota Tundra
    Order from iHacker. He takes care of business.
    boostedtrdpro, 619Tundra and geno0506 like this.
  9. Dec 29, 2017 at 10:38 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    ++++1
    geno0506 likes this.
  10. Dec 29, 2017 at 10:43 AM
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    The DRL on the 2018 trucks are dual brightness. High when headlights are off, low when headlights are on. AFAIK, the @iHacker harness is the only one that retains the factory function of DRL high/low. Other harness makers charge the same, but lack the additional relay for that function.
    619Tundra likes this.
  11. Dec 29, 2017 at 3:22 PM
    Beep88
    Beep88 New Member
    How much is the harness from hacker? Is the turn signal in the 2018 headlights led or incandescent?
  12. Dec 29, 2017 at 3:27 PM
    It certainly looks like iHacker does great workmanship.....
  13. Dec 29, 2017 at 4:31 PM
    dsimonl
    dsimonl New Member
  14. Dec 29, 2017 at 5:40 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Those look great with the mgm, this is what I was looking for
    Sting Ray[QUOTED] and 619Tundra like this.
  15. Dec 29, 2017 at 7:00 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  16. Dec 29, 2017 at 8:58 PM
    PermaFrost
    PermaFrost New Member
    Washington
    2017 CM MGM SR5 TRD
    Should have just bought the Platinum!
    Looks sharp @Sting Ray . That's the look I'm looking for too. Thanks for posting the pic and endorsement for ihacker.
    Sting Ray[QUOTED] likes this.
  17. Dec 29, 2017 at 9:22 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    CJ21 likes this.
  18. Dec 29, 2017 at 9:38 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Do you think the nsv is worth the coin? Are they bright when on full?
  19. Dec 29, 2017 at 9:47 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Yes worth the money for sure and I got a good deal buying through torc, on sale until New Years I believe. Gotta love an factory like fit and finish, no cutting, and it comes with the switch panel that replaces the stock one. Everything fit like a glove. Light output is very bright. I will try to get some out put shots here soon.
    BlueBottle[QUOTED] likes this.
  20. Dec 29, 2017 at 10:21 PM
    PermaFrost
    Washington
    2017 CM MGM SR5 TRD
    That's what I'm talking about! If there was a drooling emoji I'd insert it here. Haha
    Sting Ray[QUOTED] and geno0506 like this.
  21. Dec 29, 2017 at 11:45 PM
    geno0506
    geno0506 New Member
    Michael
    :drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool::drool:
    Sting Ray likes this.
  22. Dec 30, 2017 at 10:09 AM
    PermaFrost
    Washington
    2017 CM MGM SR5 TRD
    There they are! Thanks @geno0506 :thumbsup:
    Sting Ray and geno0506[QUOTED] like this.
  23. Jan 2, 2018 at 3:57 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    The Lights Look Amazing!!!!Make a huge Differances:transformer:
