Which tundra is better?
Discussion in 'Canada' started by NorthernYota13, Apr 21, 2025.
  1. May 15, 2025 at 6:26 AM
    #91
    NorthernYota13
    NorthernYota13 [OP] New Member
    sounds good i may hold off then since i plan on having it done in like 2 years..
  2. May 15, 2025 at 9:10 PM
    #92
    72GTS
    72GTS New Member
    Ontario, Canada
    2021 MGM Tundra DC TRD Sport Premium
    Interesting. Yours doesn't have the hood scoop either? And it came with black wheels? The wheels look great! This is my truck, but I had the wheels powder coated black (they were originally silver and grey like the OP's truck). My truck is Canadian too (sold in Sault Ste Marie new), as is my friends 2020 I mentioned.
  3. May 15, 2025 at 10:11 PM
    #93
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You going to have to save that cash for all the mods you need to do. Some must have modes are Katzkin leather seats, auto dim rear view mirror, leather wrapped steering wheel and leather cover for the centre console.
    You’re right in that I’d didn’t have the hood scoop which I didn’t mind. The black wheels on the 2020 are the same ones I have on my 2016 OR but not in black. I later replaced the rims with 20” which a powder coated myself.
  4. May 16, 2025 at 5:43 AM
    #94
    NorthernYota13
    i dont really need any of that, i may do the seat covers, but aside from that no, i work at a local mine and have a company truck to.. i needed this truck for towing, renos, and gravel road here and there.. i will be putting a set of summer bronze wheels on though
  5. May 16, 2025 at 6:08 AM
    #95
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Sorry, I didn’t mean to repost that. As far as mods go for the 2019 you may want a transmission cooler if you tow often and heavy. Also the rear suspension is pretty weak on the Sport so you may need airbags or Sumosprings if you haul heavy.
  6. May 16, 2025 at 6:59 AM
    #96
    NorthernYota13
    OK no problem and yeah for sure. I don’t tow super heavy or anything, but I might upgrade the leaf springs. I was looking at icon coil overs as well
  7. May 17, 2025 at 9:12 AM
    #97
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Coil overs are not a good option. The mounting points of the shocks are not designed to hold weight. They are designed to control suspension movement through the shock absorber. They will also affect your unloaded ride quality. Aftermarket leaf springs or adding an extra leaf will help with weight but will also result in a bad unloaded ride quality. Air bags don’t effect your unloaded ride quality as much and can be adjusted for the load your carrying. Sumosprings or Timbren work well and require no maintenance and are easy to install. They effect unloaded ride quality very little if you choose the right ones.
