Which tundra is better?
Discussion in 'Canada' started by NorthernYota13, Apr 21, 2025.
  1. Apr 22, 2025 at 6:38 AM
    NorthernYota13
    NorthernYota13 [OP] New Member
    The service records look pretty clean on the 1794 edition, but there was an accident in 2018 or $5000. Something with the rear end
  2. Apr 22, 2025 at 7:50 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You could use that to negotiate a better price. I would be concerned if it was repaired properly. Was it bought damaged, repaired then being sold or did the previous owner have an accident and have it repaired? If it was purchased damaged with the intent to resale chances are that the repair was done to maximize profit. Also does it show a salvage title?
  3. Apr 22, 2025 at 8:09 AM
    NorthernYota13
    yeah it was in 2018. The truck was repaired right then and they still drove it. It only had like 20,000 km on it. It now has 117,000 so it was already repaired prior. It shows it in the Carfax.
  4. Apr 22, 2025 at 8:12 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    Judging by the repair prices on Toyota trucks, it was probably a scratch from a rogue shopping basket in grocery parking lot.
    Retired...finally and Ruggybuggy like this.
  5. Apr 22, 2025 at 8:39 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Should be fine then, a bad repair would have shown itself by now. Still use it as a negotiating tool and make sure it doesn’t have a salvaged title. Have it inspected if you’re serious about it.
  6. Apr 22, 2025 at 9:34 AM
    NorthernYota13
    oksounds good thanks!
  7. Apr 22, 2025 at 12:31 PM
    NorthernYota13
    well guys unfortunately it looks like only the 2013 is left available. I’m gonna look up the service records through Carfax. If everything looks good should this be a solid buy?
  8. Apr 22, 2025 at 1:23 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Be patient, something else would come along. The 2008 had more issues than the 2014-2018. Also being that old frame rust is a concern.
  9. Apr 22, 2025 at 2:06 PM
    NorthernYota13
    i will, im gonna wait it out, i have a little corolla for back and fourth to work right now anyways and my work truck
    Ruggybuggy[QUOTED] likes this.
  10. Apr 24, 2025 at 9:56 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just thinking, because you don’t tow heavy why not consider a Tacoma crew cab with the long box? You will be able to haul almost as much as a tundra with the 6’ box. You will also get better mpg and the truck will cost less. 2015 and older with the 4l engine are built proof but watch for frame rust. 2018 to 2022 Tacomas are not as reliable but still good.
  11. Apr 24, 2025 at 10:40 AM
    NorthernYota13
    I do have both kids so I’m probably gonna consider just a double cab tundra. I’m looking at one from a Lexus dealer with 111,000 km on it. It’s an SR 5+2019 5.7
  12. Apr 24, 2025 at 11:06 AM
    EmergencyMaximum
    +1 on tundar. When I was originally buying one back in 2010, my plan was to go for tacoma. But when I saw how close in price both pickups were, I opted for the tundra. I think most of the tacoma sales come from elderly homeowner folks or those who aren't sure why they need a pickup, but buy one anyway.:crapstorm:
  13. Apr 25, 2025 at 7:56 AM
    NorthernYota13
    How much more milage can i get outta this,? Its close to me, i need it for work and back and beating around town. Comes safetied
  14. Apr 25, 2025 at 9:23 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It you have all the service records and shows oil changes every 8,000kms, I wouldn’t worry about that mileage. Do have a look and see it the cam towers are seeping and make sure their isn’t a coolant leak at the heat exchanger. Also inspect the frame from rust. Also if they have a bed liner installed, check under the liner for rust. 2008-2012 were known to have bed rust holes and people cover them up with a bed liner. I would also have it checked out by an independent shop.
  15. Apr 25, 2025 at 12:47 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I just saw this on the FB marketplace. Looks clean.
  16. Apr 25, 2025 at 1:00 PM
    NorthernYota13
    very clean, but i need somewhere to dump my lease
  17. Apr 25, 2025 at 2:30 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would still message them. Chances are they are a dealer.
  18. Apr 25, 2025 at 2:46 PM
    NorthernYota13
  19. Apr 25, 2025 at 3:01 PM
    #49
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
  20. Apr 25, 2025 at 3:05 PM
    #50
    NorthernYota13
    it is toyota used certified! Would it be any good you think or should i await a 5.7
  21. Apr 25, 2025 at 3:40 PM
    #51
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The 4.6l is the same as the 5.7, just a smaller bore and less HP and torque. Toyota stopped offering the 4.6l because it didn’t really offer better mpg and most of the sales were going 5.7. There is nothing wrong with the 4.6 and just as reliable. You will take a bit of a hit when you sell it because of the DC and 4.6. If you don’t plan on towing heavy and don’t need the quick acceleration then I wouldn’t worry about it.
  22. Apr 27, 2025 at 4:35 AM
    #52
    NorthernYota13
  23. Apr 27, 2025 at 5:41 AM
    #53
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Looks decent. It looks to have a spacer lift which isn’t a good thing. Owners will spacer lift their truck and because of the lift you can never get the alignment back to spec. My dealership that I work at would spacer lift their trucks and when I performed the alignment you can’t bring it back to factory spec. Tires would wear on the outside edge. No running boards to getting in and out can be challenging. You can’t see it in the pictures but most lifted Tundra without running boards will have the left side of the seat cushion collapsing because they slide their butts on the edge as they get in and out. Also appears to have BFG tires, which are loud at highway speed. It’s also not a Toyota dealership so likely it’s an auction purchase. I think the 4.6l Tundra is the better buy. Less money, Toyota safety sense, Toyota used vehicle certification, newer and with less miles.
  24. Apr 27, 2025 at 5:51 AM
    #54
    NorthernYota13
    ok awesome!! thanks!
  25. Apr 29, 2025 at 5:03 PM
    #55
    NorthernYota13
    https://www.kijiji.ca/v-cars-trucks...d-crewmax-no-accidents-frame-recall/m10680812
    high milage but looks clean for back and fourth to work
  26. Apr 29, 2025 at 6:52 PM
    #56
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Looks pretty clean for 341,000kms. I see that it’s had a frame recall done. To fail the frame recall we would use a welding hammer and see if we could punch holes in the frame. Make a hole and it fails. Most of the trucks that came in had other rust issues as well. The truck looks very clean so be careful that it’s has been to a body shop for rust repair and paint. Tundras that were taken care of never qualified for a frame replacement because the owners did their due diligence and the truck was washed top to bottom often. See were I’m going with this?
    I wouldn’t pass on it, but it would need to be inspected very closely. If it’s been painted, pass on it. I would also peek under the box liner for holes in the bed. Box liners can be a quick way to cover up a problem and older Tundras a know to develop rust holes in the bed.
  27. Apr 30, 2025 at 12:49 AM
    #57
    NorthernYota13
    absolutely!! lol i may have to wait till my littlw car lease is done for a new SR5 TRD next year lol
  28. May 2, 2025 at 2:42 AM
    #58
    NorthernYota13
    the truck has service records from toyota its entire life so far which is good
  29. May 2, 2025 at 4:44 AM
    #59
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Make sure it has the original paint and no body work has been done. Have it inspected for issues. It’s worth the cost to avoid a problem.
  30. May 2, 2025 at 4:51 AM
    #60
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I think you’re going to find it’s been painted. Look at the bottom of the driver’s door on the inside. You can see rust at the door seam. There is a rubber gasket there that traps road salt against the door and causes it to rust.
