Which Spyder Headlights?
Discussion in 'Lighting' started by TimtundraXP, Nov 21, 2016.
  1. Jul 25, 2017 at 10:03 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    With the Hikari LED bulbs installed in the spyder lights, did you just install them under the cover or did you have to cut a hole for ventilation/the fan to poke through?
  2. Jul 27, 2017 at 3:15 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    2007 Slate Metallic Double Cab
    Seconded. I followed Backsliders lead, and don't regret going from my retros to spyders with LED.
    Backslider[QUOTED] likes this.
  3. Jul 27, 2017 at 5:22 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    They fit fine under the dust/moisture boots. I've never had a problem with overheating at all.
  4. Jul 27, 2017 at 7:24 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Appreciate it, the bulbs that come in them are horrible. I already had a set of HIDs coming for them when I saw your post, just wanted to know about the LEDs in case I'm not happy with the HIDs.
  5. Jul 31, 2017 at 11:37 AM
    JJR14TUNDRA
    JJR14TUNDRA New Member
    So am I correct, need h11 leds for the spyder headlights?
  6. Jul 31, 2017 at 12:23 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Yes, H11(H8/H9) all the same base & plug. Just a heads up though, I ordered a set of the Hikari LED bulbs and they will not fit in the Spyder headlights. The diameter of the Hikari LED bulb is 18mm and the opening in my Spyders is only about 13/14mm. I don't know if either the headlights have been redesigned or if the bulbs have changed, but the 35w HID kit fit just fine and is enough to make me happy.
  7. Jul 31, 2017 at 12:47 PM
    Backslider
    Tooele, UT
    Interesting, I run Hikari LEDs on Spyders and had no fitment issues whatsoever..
    I agree that maybe either the bulb or the headlights might have undergone a design revision.
  8. Jul 31, 2017 at 12:56 PM
    Backslider
    Tooele, UT
    Can you post a link to the bulbs you ordered?
    If it is the same ones you do have to unscrew and remove the black aluminum cap.
    https://www.amazon.com/gp/product/B01LCE19OI/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    BenAZ likes this.
  9. Jul 31, 2017 at 1:30 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
  10. Jul 31, 2017 at 1:44 PM
    Backslider
    Tooele, UT
    Ha! Yup, messed with me too. I was getting pretty pissed off until I realized it came off. Saved me a lot of time when I put Hikari LEDs in the OEM projectors in my wife's 4runner - but then I had to remove part of the heat sink because those projectors are side-loaded. =\
  11. Jul 31, 2017 at 3:37 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Wait, you mean I could have unscrewed the end and they would have fit. Damn, I just dropped them off to be sent back. Oh well, maybe I'll give them a try again in the future.
  12. Aug 6, 2017 at 12:44 PM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    I am waiting for my Spyder's for 07-13 Tundras to be sent to me from eledobleu right now. He is almost done with them. Having ds2 Morimoto 4.0 projectors installed with RBG Led's swapped for the Spyder Leds. Maybe I will check out those LED H1 bulbs as well. Good to know
